Old 04-25-2020, 09:40 PM   #3795
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
Originally Posted by Scracho View Post
Hi guys!
I'm on my 4th 86 (Yes 4th) and have played with various suspension setups. I'm in the market for a $1500 street occasional track coilover and all roads have led me to a couple options.
IMO the largest improvement in ride/handling/lap times happen when you go from stock to DECENT coilover setup then from there unless you go to a full on pro setup the lap times aren't improving relative to cost from your decent "entry level" to medium tier coils. Thus the savings can be used for so many other items that will yield a faster, flatter and more enjoyable ride.
So that being said... CSG Tein Flex A OR RCE SS1????
Used v3s/rce t2s/ohlins, at some of these prices you can get a full refresh within budget.
https://www.ft86club.com/forums/showthread.php?t=139867
https://www.ft86club.com/forums/showthread.php?t=135058
https://www.ft86club.com/forums/showthread.php?t=139615
ineedyourdiddly
Scracho (05-01-2020)
Old 05-04-2020, 02:18 PM   #3796
oldlostcory
oldlostcory's Avatar
Drives: 2013 WRB BRZ Limited
I'm not sure if this is something with my setup or just the car itself. My car is running RCE Yellow springs and 17x9 245's, rear spc lca's. My alignment is at -1 up front and -2 in the back. I'm not happy with my initial turn in feel when autox or spirited drives. It almost feels slightly delayed. Is this due to my wider tires? Electric steering?
The only other car I've ever driven aggressively was my old integra back in the day. It was immediate when I turned the wheel aggressively.
oldlostcory is offline   Reply With Quote
Old 05-04-2020, 02:59 PM   #3797
churchx
churchx's Avatar
Drives: 2014 GT86
Imho front camber is insufficient, but turn-in .. what are your front toe settings?
Old 05-04-2020, 03:06 PM   #3798
oldlostcory
I think my front toe is close to 0? I'm guessing I'd need camber plates to get more camber up front? I'm just using camber bolts right now and they are maxed.
Old 05-04-2020, 03:16 PM   #3799
Racecomp Engineering
Originally Posted by RToyo86 View Post
@ Racecomp Engineering
Any ideas on when RCE yellows will be available to order?
Looking to order through FT86Motorsports. They're special order which I assume will go directly through you.
I think we PMed...but end of May for more Yellows.
- Andrew
RToyo86 (05-04-2020)
Old 05-04-2020, 03:19 PM   #3800
Yeah more front camber would help.
What kind of camber bolts are you using?
Something like the Perrin steering rack lockdown does improve "feel" but you might be looking for more. Still nice.
-2 is real good for a street car.
- Andrew
oldlostcory (05-04-2020)
Old 05-04-2020, 03:25 PM   #3801
oldlostcory
- Andrew
I'm using Whiteline bolts. I could get -1.5 out of the drivers side but only -1.0 from the passenger so I had both set at -1.0. I had a local shop set all this up.
Old 05-04-2020, 03:40 PM   #3802
One option is the Pedders offset strut top mounts that add a little caster and camber. I have not used them myself yet, but I plan to try them.
- Andrew
Old 05-04-2020, 03:42 PM   #3803
timurrrr
timurrrr's Avatar
Drives: 2022 GR86
Try a bit of toe out, and definitely more negative camber in the front, something around -2.5º.
Depending on your budget, you might consider using two adjustable bolts per strut, adjustable top hats, coilovers, or offset strut mounts. At least in theory those offset mounts seem like a good idea, especially for a daily driven car, and together with camber bolts you should be able to get a good range of adjustability. I have to admit I haven't met anyone having non-adjustable strut mounts though.
The Following 2 Users Say Thank You to timurrrr For This Useful Post:
oldlostcory (05-04-2020), strat61caster (05-04-2020)
Old 05-04-2020, 04:01 PM   #3804
Decep
Drives: 2013 FR-S Series 10
And the obvious, check tire pressures. You did add a lot of weight to the suspension so it'd be normal the response would be dulled but it should still feel better than most cars.
I would post your alignment numbers in the thread
2013 FR-S 10 Series ~75k (SOLD)
RCE SS-1 Coilovers
Corsa Catback
Edelbrock Supercharger installed @ 50k
The Following 2 Users Say Thank You to Decep For This Useful Post:
oldlostcory (05-04-2020), Racecomp Engineering (05-04-2020)
Old 05-04-2020, 04:22 PM   #3805
oldlostcory
Thanks for the replies. I'm going to do some more research into the options you've given me. I think i'm gonna shoot to get my front camper to at least -2.0. Might pick up the Perrin Steering Rack Lockdown as well because why not? Not that expensive and easy to install.
Old 05-04-2020, 05:17 PM   #3806
churchx
churchx's Avatar
Drives: 2014 GT86
oldlostcory: More camber as in for more front grip in turns (and less understeer bias) .. that will net less for initial turn in imho though. That perrin lockdown, why not, didn't notice much NVH illeffects, indeed cheap & simple enough to install .. then again, it didn't change much steering feel either. Toe (but wouldn't want toe out for street driven car, as while may make quicker turn-in, will also make less stable/more nervous steering)/what type of tires (eg. sidewall stiffness, slip angles)/pressures imho will affect turn-in more.
One thing is what tire sizing .. but what model of tires you are using?
Old 05-04-2020, 05:31 PM   #3807
Yoshoobaroo
TRACKBREAD
Yoshoobaroo's Avatar
If your biggest complaint is turn in feel, rather than corner entry understeer, you'd probably be better off ditching the 9" steam rollers up front and get some sticky 215's instead.
Unless lap times are important to you, I don't see the need to over-tire the car for spirited drives and auto-x.
The Following 3 Users Say Thank You to Yoshoobaroo For This Useful Post:
CSG Mike (05-06-2020), Ohio Enthusiast (05-07-2020), why? (05-07-2020)
Old 05-04-2020, 05:57 PM   #3808
strat61caster
Sounds like you want more front roll stiffness (which was probably relatively high in the old Honda) and aside from maybe front toe change you'll get what you want out of a stiffer front swaybar. Camber and steering rack bushings won't help the car take a set any quicker imho. RCE Yellows are too soft for competitive autox tires.
Dampers would be next on my hit list to tackle a lazy front end after toe and swaybar (assuming you plan on sticking with the RCE Yellows). Although still do the camber, your tires will thank you.
ineedyourdiddly
Air Suspension Discussion Thread - Let's Get Nerdy Andrew@ORT Suspension | Chassis | Brakes -- Sponsored by 949 Racing 174 02-13-2016 04:17 PM
RallySport Directs Everything Suspension thread!! RallySport Direct Brakes, Suspension, Chassis 21 07-02-2014 06:31 PM
The OFFICIAL Ohlins Coilover Suspension thread - High End Competition Suspension ModBargains.com Suspension | Chassis | Brakes -- Sponsored by 949 Racing 63 05-22-2013 09:15 AM
2012 Team USA vs the 1992 Dream Team ERZperformance Off-Topic Lounge [WARNING: NO POLITICS] 1 09-14-2012 07:19 PM
Team build thread; PROJECT.STH trueno86power Other Vehicles & General Automotive Discussions 0 03-02-2010 11:13 AM
