Old 05-04-2020, 03:45 AM   #1
Pil
Drives: 86
Pil is offline   Reply With Quote
Old 05-04-2020, 08:50 AM   #2
What year car? Are there any CELs or codes?
Old 05-04-2020, 09:01 AM   #3
Lantanafrs2
Drives: 2013 frs red
Both valves leaking quite a bit. Head has to come off. I would suspect valve springs as well given the circumstances of the failure
Lantanafrs2 is offline   Reply With Quote
Old 05-04-2020, 09:13 AM   #4
Pil
Drives: 86
Late 2013, just right outside the recall range.
CEL was blinking intermittently when it happened.
P0304 showed up (for me), not sure if any other codes popped up at the workshop.
The Following User Says Thank You to Pil For This Useful Post:
Tcoat (05-04-2020)
Old 05-04-2020, 09:16 AM   #5
No audible rattles or other strange noises? A broken or week valve spring could indeed cause a misfire.
Old 05-04-2020, 09:20 AM   #6
Pil
Drives: 86
None out of the ordinary.
Car started spluttering in stop-go traffic with no warning beforehand.
Old 05-04-2020, 09:31 AM   #7
Sorry for all the questions! Stock? no mods?
Could be a weak spring but it would be very unusual when outside the recall window.
jcw99 (05-04-2020)
Old 05-04-2020, 09:40 AM   #8
Pil
Drives: 86
No need for apologies! Happy to supply answers.
Cooling mods like radiator & oil cooler, suspensions, brake, fluids. Nothing to increase stock engine output.
Old 05-04-2020, 09:47 AM   #9
The only thing that has me really questioning valve spring issues is that they usually show up at higher RPMs but you said it is mostly at lower.
Old 05-04-2020, 09:48 AM   #10
Pil
Drives: 86
Yeah, that's what they told me too. That's why they didn't believe it would be the springs at the beginning.
Old 05-04-2020, 09:52 AM   #11
Pil
Drives: 86
When you say it shows up at higher RPM, does that mean that the misfiring should have started only at high RPMs? or just the symptoms (strange noises as you mentioned)
Old 05-04-2020, 10:08 AM   #12
Lantanafrs2
Valve springs generally fail at high rpm when they're under stress but a flawed or overworked spring can fail anytime regardless of rpm.
Old 05-04-2020, 10:12 AM   #13
Pil
Drives: 86
Ah! Thanks for the clarification. Would make sense since the car has been tracked regularly for the past 5 years.
Lantanafrs2 (05-04-2020)
Old 05-04-2020, 10:42 AM   #14
Opie
Opie's Avatar
Drives: 2020 GMC Canyon Denali Diesel
How many miles on the car? Any chance of carbon buildup causing valves to not seat?
2020 GMC Canyon Denali Duramax, 2021 Forester Sport, 2000 Subaru Legacy B4 RSK 5MT (JDM Import) and random 86 chassis rebuilds....
Opie is offline   Reply With Quote
Possible recall on the 86 regarding valve spring tanner CANADA 84 11-28-2019 10:32 PM
Valve float after valve spring recall mswbrz Issues | Warranty | Recalls / TSB 5 11-22-2019 08:03 PM
Valve spring recall meadowz06 Issues | Warranty | Recalls / TSB 115 06-09-2019 12:38 AM
valve spring issue? nikitopo Issues | Warranty | Recalls / TSB 1037 05-01-2019 11:55 PM
Valve Spring Recall venturaII New England 13 02-25-2019 08:41 PM
