#21799 | |
So, being back in the day when I did things up right, I took the door off, installed a temp door, and took the metal door down into the basement where I stripped it, sanded it, primered it and sprayed on 3 coats of paint (that looked really nice under the basement lights). When it was good and dry, I took it out of the basement and installed it. I noticed my wife and a few neighbors had gathered out on the road to admire my work. As I was walking toward them, I noticed they were all shaking their heads - noooo. I turned around and found out why. That color was hideous in the natural light of day! I took it down right away and when I painted it again, this time I did it near an open garage door. THE END (of me doing things the proper way) |
#21800 |
Sittin' Sideways
Drives: 2016 Toyota FR-S
Went on a little LED lighting spree:
Also added a relay with tap-turn to get rid of the hyperflash and add that handy function. Signal housings look just a little nicer now without the amber bulb reflection inside them, and having a bright white pair of running lights up front makes me feel a little more visible on the road. Everything's working great, and I've got an OEM-style fog light kit on deck for my next project.
-O/D
2016 FR-S, Hot Lava |
| The Following User Says Thank You to Overdrive For This Useful Post: | Kaotic Lazagna (05-03-2020) |
#21801 | |
Drives: GR Corolla
I installed the Tap-Turn in both my cars. The Wig-Wag feature cracks me up for some reason: |
#21802 | |
It is like somebody ran out into the plant in the middle of production and said "HOLD UP. I got this great deal on head units now we have to make them work. Oh just bypass the whole amp for the woofers? DO IT"
#21803 |
Drives: 86 GT
The door handles would give a little before pulling to close them, I tightened the two screws under the handle and the screw at the door latch - adds to that solid feel.
Had some extra time after that, so I took another look at my EQ settings on my Kenwood head unit. Someone had done a frequency response sweep on our cars previousl and I was comparing them to my current EQ setting was based on trial and error based on my preferences. Turns out that I fixed the low and low-midrange almost rather accurately, can't say the same for the mid-highs and highs, though... Time alignment came next, which I got out the measuring tape to measure the distances between the speakers. After all was done, imaging is slightly better and I noticed less fatigue when running all of those tests, guess fixing the EQ really did the trick. But now I'm wondering if this is the best I'm going to get, or there is more room for improvement...
#21804 | |
Drives: 17 Asphalt 86
I got them into the light. 2/4 were perfect. Hair one, plus one with two runs. They weren't noticeable until you were up close, my fault I probably shouldn't have been consuming beverages the entire time I ended up sanding down the spots, and decided to experiment and repaint one by masking off the areas and touching up. Ended up with tape lines as expected but they cleaned up nice. I will revisit in a week and see if color sanding out and buffing the tape lines works with this paint before I decide what to do with the other one. |
| The Following User Says Thank You to RToyo86 For This Useful Post: | humfrz (05-03-2020) |
#21805 | |
#21806 | |
He sold and installed for me a Kenwood DNX ????. OK, fine, until about a year later, the GPS part told me that I needed to update the maps. So, I looked at the instructions and it was apparent that was waaay over my capability. So, I took the car back to the Geek Squad guy and for $35 he was to update the GPS maps. Well, he got it all screwed up and had to send my unit back to the factory. During transit the screen got broken, so they had to install a new, newer model. Fine. Now, my maps are due for updating again. What to do? I'm thinking I'll try to do it myself. No hurry though, I already know my way to the pharmacy and the grocery - and the girl in the unit still knows where "home" is -
#21808 | |
#21809 |
Wheels for Brains
| The Following 2 Users Say Thank You to EndlessAzure For This Useful Post: | humfrz (05-03-2020), Ultramaroon (05-05-2020) |
#21810 |
| The Following User Says Thank You to humfrz For This Useful Post: | EndlessAzure (05-04-2020) |
#21811 |
Site Moderator
Drives: ichi 86 Project
Installed Depo taillights. I have Diode Dynamics Tail-as-Turn, so Depo lights works out well.
| The Following 4 Users Say Thank You to ichitaka05 For This Useful Post: |
#21812 |
ProCrastinationConsultant
those look much better!
| Tags |
| :popcorn:, :popcorn: funny tags, nsfc, rice rice baby |
| Saw My First FR-S Today | Marrk | Scion FR-S / Toyota 86 GT86 General Forum | 26 | 05-15-2013 12:40 PM |
| Got My Car Today!!!!! First 86!! #81 | Juanito08 | Scion FR-S / Toyota 86 GT86 General Forum | 7 | 05-22-2012 04:54 PM |
| If my FRS was here already, today I would... | bestwheelbase | Scion FR-S / Toyota 86 GT86 General Forum | 101 | 05-12-2012 06:20 PM |
| Sat in a FRS today!! | Ladnerd | Scion FR-S / Toyota 86 GT86 General Forum | 12 | 04-30-2012 01:48 PM |
| Got my VIN today... | Enemies | BRZ First-Gen (2012+) — General Topics | 63 | 04-12-2012 10:19 PM |
