Old 04-30-2020, 08:18 PM   #5461
tomm.brz
Drives: brz 2017 hksv2
Originally Posted by mrg666 View Post
It is *really* fine. I will not retune.
yeah, no big deal
maybe if you have Ecutek Blurtooth EVI, you can ask the tuner to build a timing slider for you in the ecutek app
Maybe also a knock alert with the CEL blinking on dash
you can then have more torque on demand, if you are now tuned for a catted header
Catless header enjoy less overlap (less cam advance, less cam retard) at high rpm while catted like more overlap.. but again no big deal
but keep in mind that when boosted, this kind of exhaust upgrades are more effective than on a NA car, it s pretty noticeable if well tuned
i wrote just for info, i m ok with you keeping oem jrsc tune... i read that last part just after,
i actually thought you had a tune from CSG Garage, sorry about that
Old 04-30-2020, 08:22 PM   #5462
mrg666
pessimistic skeptic
mrg666's Avatar
Originally Posted by tomm.brz View Post
yeah, no big deal
I still have a catted stock header (just upgraded to 2017+). Only the second cat was removed. I have edited my previous post to mention my experience with one of those tuners. I don't have the patience to go through that again. JR provides a really great tune from the beginning anyway. I want to stick with it.
Old 04-30-2020, 08:26 PM   #5463
tomm.brz
if you are happy, that s already good enough
in that case, if you have stock header, the tune does t need t change much, the first cat is still there blocking everything
when i switched to *Only* catless front pipe (all rest stock) while still NA i barely could rise timing from 5.5 to 6.5-7k rpm.. with supercharger it s similar behaviour
as you said, at least you gain in knock relief
Old 04-30-2020, 08:46 PM   #5464
CSG Mike
CSG Mike's Avatar
your in-house tuner keeps CL fuel control active it won t run leaner or richer, maybe just transiently because of the integral/proportional corrections, but anyway afr is going to be quite spot on all the time
only bad things I would think of about upgrading to catless without returning, is the performance left on the table
ecu won t rise ign timing more than it is allowed to, and cam timings could be made more aggressive and with less overlap at higher rpm
also at lower rpm and loads it could need some fix
We're referring to the factory tune. There is no "custom" to the factory tune.
Old 04-30-2020, 08:46 PM   #5465
CSG Mike
CSG Mike's Avatar
There is a MAF sensor for that purpose. There is no such assumption.
The MAF sensor is maxed out with the factory tune long before you hit peak boost or redline.
Old 04-30-2020, 08:47 PM   #5466
CSG Mike
CSG Mike's Avatar
Originally Posted by ybotspawn View Post
Correction map sensor, different principle entirely. I’m not going to attempt to debate you on what you’re doing and why it’s bad. Generally though I tend to believe guys like @ know more than I do. Good luck with the ticking time.... ummm motor
The MAP sensor is also maxed out before redline or peak boost with the factory tune.
Old 04-30-2020, 08:47 PM   #5467
CSG Mike
CSG Mike's Avatar
maf doesn t pick up all the airflow differences, specially if there are unexpected changes of volumetric efficiency
Also, it relies entirely to a pre-set scaling
Primary lambda is what catches AFR fluctuations
but the ecu must be in a closed loop mode (either stock logic, or ecutek CL fuel control) to take action and correct that AFR to follow the target
CSG Mike maybe forgot, but the master tuner of his company is already enabling closed loop mode all the time at all rpm
We are strictly referring to the factory tune.
Old 04-30-2020, 08:51 PM   #5468
tomm.brz
@CSG Mike
i'm sorry
i really thought it was tuned by you, my mistake
Old 04-30-2020, 09:01 PM   #5469
CSG Mike
CSG Mike's Avatar
@tomm.brz no worries; it's easy to get mixed up with a thread that's going quickly.
for those reading the thread:
tl;dr factory tune works on assumptions of a universally identical setup, which is why deviating will potentially make your car not run right. A GOOD custom tune will always yield more power and more reliability when you add supporting mods.
Old 04-30-2020, 09:58 PM   #5470
mrg666
pessimistic skeptic
mrg666's Avatar
So are you replacing the MAF sensor with your custom tune?You don't, right? That MAF sensor is still maxed out in a custom tune. At high boost, does your custom tune rely on MAP sensor instead?
Old 04-30-2020, 10:04 PM   #5471
mrg666
pessimistic skeptic
mrg666's Avatar
Are you saying that factory tune is not good? How much more power and reliability you are offering with a custom tune on the stock configuration of JRSC? Can you please specify?
Old 05-01-2020, 12:40 AM   #5472
CSG Mike
CSG Mike's Avatar
This is why an aftermarket MAP is required for a CSG tune. Without it (or a MAF upgrade), there is no way to measure air.
Old 05-01-2020, 12:41 AM   #5473
CSG Mike
CSG Mike's Avatar
The factory tune is perfectly reliable. I'm saying MORE power can be unlocked with a custom tune without compromising reliability.
Old 05-01-2020, 07:34 AM   #5474
stacyu18
Drives: 2014 subaru brz
self install
for anyone thinking about installing the c38 supercharger by yourself let me tell you that it is no easy process. I work on cars for a living and know what i am doing but to the normal person it will be a bitch. the best thing to do is break it down into days.day 1 take off the tires,fender wells,the under cover then the bumper.day 2 install the super charger. day 3 install the inter cooler and piping for me this was the most time consuming job due to the fact you had to make sure that the piping was set well enough that you could fit your headlights in and make sure that you have a screw gun or electric screwdriver and tape measure this will help a hell of alot. day 4 install the oil cooler and lines. day 5 install the tune check all hoses for leaks make sure that nothing is going to rub the fans or engine to burn anything and take car for test drive. day 6 if all is good and car is not leaking reinstall the bumper,fender wells,under cover and make sure that you didn't forget anything. some people may just say or take it to a shop to have done,well you can do that also but a extra 1000 dollars is a lot to some people.so i hope this help some people out. good luck on your adventure if you do it yourself.BTW each day maybe up to 3 hours.
stacyu18 is offline   Reply With Quote
Jackson Racing Rotrex Supercharger System Info and Discussion Jackson Racing Forced Induction 827 04-06-2020 04:56 PM
Jackson Racing Supercharger Press Release and Info CounterSpace Garage Forced Induction 110 01-03-2017 09:04 PM
jackson Racing engine oil cooler - modular to fit the Jackson Racing Supercharger! CSG Mike Forced Induction 24 04-27-2016 12:59 PM
Jackson Racing supercharger NoppyNop Forced Induction 241 06-26-2014 03:05 PM
Jackson Racing Supercharger Pre-Order Sale, $200 off! Xero-Limit Forced Induction 2 03-05-2014 04:14 PM
