, dpfarr
Old 04-28-2020, 11:40 AM   #3473
tomm.brz
Drives: brz 2017 hksv2
Do you have an external wideband?
because of the two stock o2 sensor, just one is a (widerange) AFR sensor, the second one is just a simpler o2 sensor that can detect stoich and nothing more
this one is used just for small post-corrections in closed loop mostly and you won t get an afr value from it in the logs
Old 04-28-2020, 12:54 PM   #3474
snowtaipan
snowtaipan's Avatar
Drives: '17 BRZ Series Yellow Edelbrock SC
Negative, no external. I'm referring to the wideband and o2 sensor. On my log the wideband comes in as A/F sensor #1 and the other as o2 sensor #2. What I'm seeing is the wideband reads pretty normal according to the manual, but the #2 sensor top range for rich is .55v and its sitting at .7
https://datazap.me/u/snowtaipan/fina...=0&data=52-121
https://demos.starbase7.net/t3Portal...modelyear=2017
snowtaipan is offline   Reply With Quote
Old 04-28-2020, 03:20 PM   #3475
tomm.brz
they are completely 2 different sensors, with different function and scalings
They aren t comparable and you only must look at "afr actual" calculated from the first lambda only
Old 04-28-2020, 04:00 PM   #3476
snowtaipan
snowtaipan's Avatar
There's nothing happening that I see to cause the FTs to go up. My FTs look at my perfectly normal AFR and go "screw that, lets max out the LTFT for no reason." https://datazap.me/u/snowtaipan/fina...zoom=1171-1602
Old 04-28-2020, 04:45 PM   #3477
tomm.brz
the reason why it creeps up it is because it is told the ecu to inject a certain amount of fuel for that airflow measurement/calculation
but that fuel isn t enough so the ecu adds
Need a maf scaling
snowtaipan (04-30-2020)
Old 04-30-2020, 05:02 AM   #3478
S0crates
Drives: 2017 BRZ Limited PP
Just finished installing Edelbrock SC into a 2017 BRZ PP. I have a leak coming from the coolant surge tank. From what I can tell, it appears that both connectors are leaking. I tried rotating the clamps and moving them in a bit towards the tank, but the leaking is still occurring. None of the other coolant lines are leaking. Maybe I am missing something. Recommendations?
S0crates is offline   Reply With Quote
Old 04-30-2020, 07:22 AM   #3479
BirdTRD
Simply Forgotus
BirdTRD's Avatar
Drives: 2014 Supercharged SSM BRZ Limited
First verify that the surge tank does not have a defect/imperfection or a small split where it's seamed together.
I would also try moving your clamps outward slightly so they are squeezing right next to that raised part on the end of the inlet pipe.
You could get different clamps, worm screw type.
Another thing I personally might try is a dab of pipe thread compound on the inlet pipe then clamp, that may help seal it, just try to do it in a manner so it doesn't get into the system.
BirdTRD is offline   Reply With Quote
Old 04-30-2020, 08:46 AM   #3480
BertoFT
Drives: 13 FRS Firestorm
Originally Posted by BirdTRD View Post
...I would also try moving your clamps outward slightly so they are squeezing right next to that raised part on the end of the inlet pipe. ...
This is what fixed my leak.
Sent from my SM-G9600 using Tapatalk
BertoFT is offline   Reply With Quote
Old 04-30-2020, 05:31 PM   #3481
snowtaipan
snowtaipan's Avatar
The supplied Edelbrock house clamps are ridiculously strong. Mine actually made little folds in my EGR solenoid hoses. Try pulling them, residing the house a bit to reseat it, and reclamp right after the barb.
Old 05-05-2020, 01:04 AM   #3482
shr133
shr133's Avatar
Drives: 2013 FRS
Before I get a shift kit or valve body does any have any tips for the slow shifting after you add the supercharger on the automatic.. I know blah blah.... But when I fix this look out...
Enkei TS9 18 X 8, Michelin Sport 4S 225 40 18, Flex Fuel, Edelbrock Supercharger, P & L header, Nameless front pipe, V1 cat back, Aluminum Driveshaft, pvc delete, med duck bill, KW V3, Whiteline 20 and 18 mm bars, Buddy Club and SPL control arms, Toe Arms, motor and trans mounts, Whiteline bushings, SHR stage II tune.
shr133 is offline   Reply With Quote
Old 05-13-2020, 11:54 AM   #3483
aKaGorganZola
aKaGorganZola's Avatar
Drives: 2017 BRZ Series. Yellow
Quick question for you guys. Any tips on which coolant to use in the SC loop? All I've seen is the recommendation to use a different color than the vehicles coolant. The Subaru super coolant or whatever is blue so I've been looking around for a good coolant for the SC that's not blue. Engine ice is blue as is the mishimoto liquid chill. The Evans waterless coolant is yellow but I have no experience with it so I don't know how well it cools or if it would agree with the Edelbrock internals. Any help or tips are appreciated!
aKaGorganZola is offline   Reply With Quote
Old 05-13-2020, 12:46 PM   #3484
B T
Drives: 15 BRZ, 2003 MR2, '70 Elky, 06 TBSS
just dont go cheap and you'll be fine. I've got Prestone at 15% right now, but it never freezes here.
B T is offline   Reply With Quote
Old 05-13-2020, 01:09 PM   #3485
BirdTRD
Simply Forgotus
BirdTRD's Avatar
Edelbrock simply calls for 50/50 coolant/distilled water mix. The only real reason to use a different color is to quickly identify which system is leaking should you develop one. Just so I didn't have to have 2 different brands, I've been using the Subaru blue in mine for 3 years now and no issues.
Old 05-13-2020, 01:48 PM   #3486
aKaGorganZola
Thanks @BirdTRD. That's what I was thinking about doing. Just didn't know if there was any other high quality coolants that did happen to be a different color
And thanks @B T
Edelbrock E-Force Supercharger itsibarra Forced Induction 938 07-31-2021 04:48 PM
Most annoyingly over-asked questions on FT86 forums mit_peid Off-Topic Lounge [WARNING: NO POLITICS] 36 01-16-2014 02:48 PM
