Old 04-29-2020, 05:39 PM   #5447
CSG Mike
CSG Mike's Avatar
Originally Posted by mrg666 View Post
JR factory tune works with stock MAP sensor; it even throws a CEL if you upgrade the MAP sensor. If the tune is not factory, you need to ask this question to your tuner. They will tell you which sensor is required since tune needs to be calibrated for the specific sensor.
Yes, but only because it works on a set of assumptions. When every factory tuned car is running the exact same setup otherwise, you can do this.
This is also why even a header swap will make the Jackson Racing factory tune not work.
imprezive (04-30-2020)
Old 04-29-2020, 10:54 PM   #5448
Randoman5
I’ve got a high flow second cat. If I want to run the carb tune I need to switch back to the stock pipe correct?
Randoman5 is offline   Reply With Quote
Old 04-29-2020, 11:19 PM   #5449
CSG Mike
CSG Mike's Avatar
Yes.
Old 04-30-2020, 05:52 PM   #5450
mrg666
pessimistic skeptic
mrg666's Avatar
FYI: CARB tune is running fine with my catless HKS dual resonated front pipe and 2017+ stock header since almost a year. More power at high rpm and more mpg with normal driving, and no CELs.
Old 04-30-2020, 06:59 PM   #5451
Randoman5
I'd be interested to see what the actual effect is. I suspect the concern is that it would cause greater exhaust flow to a level that affects air/fuel ratio and causes many minor knock events. Conceivably the computer could be automatically pulling timing out to compensate... But it's also possible I have no idea how the ECU actually works.
It seems like an unnecessary risk with questionable reward.
Old 04-30-2020, 07:51 PM   #5452
mrg666
pessimistic skeptic
mrg666's Avatar
Knock is less likely after reducing exhaust back pressure by removing the second cat which reduces the cylinder pressure. We are talking about the second cat which has no oxygen sensors. So, AFR is controlled by the oxygen sensors on the first cat which is still there. Second cat shouldn't have much of an effect on AFR. Again, my engine is fine. But you should of course do as you feel less risky. I am just someone on the internet after all.
Old 04-30-2020, 07:55 PM   #5453
CSG Mike
CSG Mike's Avatar
More flow = more intake air = leaner mix. Remember, the engine/ecu has no idea there's more air going in. The tune works on the assumption that every car has the same flow with the same factory exhaust setup.
ybotspawn (04-30-2020)
Old 04-30-2020, 07:56 PM   #5454
mrg666
pessimistic skeptic
mrg666's Avatar
There is a MAF sensor for that purpose. There is no such assumption.
Old 04-30-2020, 08:01 PM   #5455
ybotspawn
ybotspawn's Avatar
Drives: 13 Subaru BRZ
Jackson Racing Supercharger Owners Thread
Correction map sensor, different principle entirely. I’m not going to attempt to debate you on what you’re doing and why it’s bad. Generally though I tend to believe guys like @ know more than I do. Good luck with the ticking time.... ummm motor
ybotspawn is offline   Reply With Quote
Old 04-30-2020, 08:04 PM   #5456
tomm.brz
Drives: brz 2017 hksv2
your in-house tuner keeps CL fuel control active it won t run leaner or richer, maybe just transiently because of the integral/proportional corrections, but anyway afr is going to be quite spot on all the time
only bad things I would think of about upgrading to catless without returning, is the performance left on the table
ecu won t rise ign timing more than it is allowed to, and cam timings could be made more aggressive and with less overlap at higher rpm
also at lower rpm and loads it could need some fix
Old 04-30-2020, 08:09 PM   #5457
mrg666
pessimistic skeptic
mrg666's Avatar
By not retuning, I left that performance on the table on purpose. My main purpose was to increase engine reliability by reducing the exhaust back pressure.
The Following User Says Thank You to mrg666 For This Useful Post:
tomm.brz (04-30-2020)
Old 04-30-2020, 08:09 PM   #5458
tomm.brz
maf doesn t pick up all the airflow differences, specially if there are unexpected changes of volumetric efficiency
Also, it relies entirely to a pre-set scaling
Primary lambda is what catches AFR fluctuations
but the ecu must be in a closed loop mode (either stock logic, or ecutek CL fuel control) to take action and correct that AFR to follow the target
CSG Mike maybe forgot, but the master tuner of his company is already enabling closed loop mode all the time at all rpm
Old 04-30-2020, 08:10 PM   #5459
tomm.brz
yoy were right about knock relief when going catless, but to take effectively advantage of its scavenging potential, needs to be retuned again
mrg666 (04-30-2020)
Old 04-30-2020, 08:13 PM   #5460
mrg666
pessimistic skeptic
mrg666's Avatar
It is *really* fine. I will not retune.
Edit: I actually did. Worked with one of the most popular places. They sent me a tune which was garbage that I couldn't even drive. Second iteration was no better. I said keep the money and cut the chase, installed the stock MAP sensor and flashed back the JR factory tune which is working great.
Jackson Racing Rotrex Supercharger System Info and Discussion Jackson Racing Forced Induction 827 04-06-2020 04:56 PM
Jackson Racing Supercharger Press Release and Info CounterSpace Garage Forced Induction 110 01-03-2017 09:04 PM
jackson Racing engine oil cooler - modular to fit the Jackson Racing Supercharger! CSG Mike Forced Induction 24 04-27-2016 12:59 PM
Jackson Racing supercharger NoppyNop Forced Induction 241 06-26-2014 03:05 PM
Jackson Racing Supercharger Pre-Order Sale, $200 off! Xero-Limit Forced Induction 2 03-05-2014 04:14 PM
