Drives: Black
Turbo Frs CEL
So this is my first post but I have a Jdl turbo FRS tuned via Ecutek and I got a check engine light for the first after having the car turbo’d for 4 months and the engine codes were P0171 and P1171 I contacted my tuner and he said more than likely it’s the AFR and O2 sensors or the maf. So I decided in the mean time to Clear the CEL codes with my OFT and now my car is having really bad throttle response and feels like there’s no boost at all could that be that the OFT messed with the ECU? I know it was a stupid mistake to use the OFT to do that.
#2 |
Rust bucket enthusiast
Check for exhaust leaks at your header. Check for leaks at the evap solenoid under the intake manifold (straight under it, directly in line with the a/compressor)
Check all your intercooler piping. Also, datalog and post the logs here using datazap. Your tuner cannot help you if he's remote; find someone in person who can help resolve them. It's likely the car has no throttle response because it's yanking timing due to your fuel trims |
#3 | |
Sent from my SM-G975U using Tapatalk |
#4 |
Drives: Black
Okay I will do all that and see what’s up thank you for the advice
#5 |
Drives: brz 2017 hksv2
do you have logs? can you do them
#6 |
Also use ecutek. Did you buy the full kit with cable or Bluetooth? You can clear codes with either.
2013 Series 10 FRS #553
#7 |
Drives: '17 BRZ Series Yellow Edelbrock SC
What year? You sure it's P1171, I'm not seeing that listed.
I am working through P0170 P0171 P117B for my supercharged 2017 BRZ. This should link you to the manual for TS-ing https://demos.starbase7.net/t3Portal..._rm_index.html Definitely agree with logging. If you haven't used datazap it's amazing. |
| Tags |
| cel, check engine light, jdl turbo, p0171, p1171 |
| To Greddy Turbo Owners (or SBD/Zage Turbo).... Melted Radiator Fans? General Opinion? | xuimod | Forced Induction | 106 | 09-01-2016 08:33 PM |
| FBM Stage 1 Base Turbo Kit Starting @ $3995 Garrett or PTE Turbo Choices | FullBlown | Forced Induction | 588 | 12-02-2015 03:41 PM |
| Bren5279's Full turbo partout (JDL uel turbo, Greddy Evo 3, AEM gauges, + More) VA | bren5279 | Engine, Exhaust, Bolt-Ons | 69 | 06-29-2015 11:56 PM |
| Geneva Preview: Techart to debut 911 Turbo, Turbo S | vh_supra26 | Other Vehicles & General Automotive Discussions | 1 | 02-22-2010 07:20 PM |
