Southern California SoCal
Old 04-27-2020, 02:28 PM   #13007
youngdriver94
Drives: none
*Bump
youngdriver94 is offline   Reply With Quote
Old 04-27-2020, 02:31 PM   #13008
youngdriver94
Drives: none
Originally Posted by youngdriver94 View Post
Stock OEM Tail lights from my 2016 scion frs. They have been off my car for a little over 3 years and were individually wrapped in bubble wrap while stored in a box in my garage during that time. They are basically flawless and look brand new. They never had any condensation problems. I am located in San Diego, CA.
$150
*Bump
Old 05-01-2020, 04:24 PM   #13009
Weapon86
Weapon86's Avatar
Drives: 2014 Scion FRS monogram series
Pmd you.
Originally Posted by Akuma-ZN6 View Post
Still Available! Bumper tow cap included.
Weapon86 is offline   Reply With Quote
Old 05-04-2020, 05:41 PM   #13010
Krazy
Krazy's Avatar
Drives: FR-s
Originally Posted by Krazy View Post
WTS ACT SB7-HDG6 6 puck clutch kit.
Purchased back on August 22nd 2018 used about for a year. Daily driven to work and spirited driving about 7k-8k miles
$450 OBO
Bump
Krazy is offline   Reply With Quote
Old 05-05-2020, 02:08 PM   #13011
nextcar
Guilt free parts vulture!
Drives: 2024 GR86 Trueno Halo 6MT
Covid special! Price reduced to $300
SOLD
Price reduction! Pictures in this post: https://www.ft86club.com/forums/showthread.php?postid=3311544
Originally Posted by nextcar View Post
TRD 18-In. Black Alloy Wheels
From the Toyota website:
This Fits Your Scion FR-S/Toyota GT86
Part Number: PTR5618131
Never underestimate the transformation an aggressive set of TRD alloy wheels can give to the stance of your 86
18-in. x 7-in. front and 18-in. x 7.5-in. rear staggered fit; (both with 35-mm. offset, a 5-on-100-mm. bolt circle (P.C.D.) and a 54-mm. center bore) cast alloy wheels designed specifically for the vehicle
Incorporates the proper weight, offset and brake clearance to ensure proper fit, finish and reliability
Wheels feature TRD logo center cap
Slight curb rash on two wheels - see pictures. Original list price $259.00 each Asking $300 for the set of 4.
PM me if interested...
Not interested is trades of any kind. Cash only.
Originally Posted by drewbot
Pull out
nextcar is offline   Reply With Quote
Old 05-05-2020, 08:19 PM   #13012
Krazy
Krazy's Avatar
Drives: FR-s
WTS: OPEN FLASH FLEX FUEL KIT
Everything sold as is comes with everything needed to install the kit.
$450 OBO
Old 05-08-2020, 11:48 AM   #13013
degozaru
Drives: 2016 oceanic frs
$450 OBO
I wonder if OFT will give you a tune with second hand kits
degozaru is offline   Reply With Quote
Old 05-08-2020, 12:45 PM   #13014
Krazy
Krazy's Avatar
Drives: FR-s
Yes they do, all you do is email open flash and they will send you an off the shelf tune.
Old 05-10-2020, 02:08 AM   #13015
Jordan Silveira
Jordan Silveira's Avatar
Drives: 2016 Subaru Series.HyperBlue #631
can confirm this to be true
Jordan Silveira is offline   Reply With Quote
Old 05-10-2020, 06:15 PM   #13016
lztex
SOCAL: Local FS/FT
Seibon C style trunk plus Apr gtc-200 wing
for $1400
Unable to ship located in Irvine
lztex is offline   Reply With Quote
Old 05-11-2020, 01:19 AM   #13017
DGMlJDlBRZ
DGMlJDlBRZ's Avatar
Drives: 2014 DGM BRZ
BUMP
Updated parts list. Many parts already sold, plenty still available.
Originally Posted by DGMlJDlBRZ View Post
Hey guys, I've got an extensive list of parts that I'm looking to part out from my 2014 BRZ. The time has come for me to move onto a more practical daily and my '69 Mustang needs a motor swap and manual transmission conversion .
Bought my car new in 2014 and was a daily driver for the first couple of years (~25k miles). In the last 4 years or so it slowly became a garage queen/weekend cruiser/show car, therefore the majority of the parts have low mileage on them (my car only has about 32k miles currently).
These are all the parts that I can remember off the top of my head, but there's likely more that I will find as I move on with the part out process.
NO TRADES.
Feel free to ask me any questions about the condition or pics any of the parts if you're interested.
Any color matched parts are painted 61K Asphalt/Dark Gray Metallic.
Cash ONLY and parts can be PICKED UP in OXNARD, CA.
ENGINE/DRIVETRAIN
- Sprintex 210 SPS Stage 2 Intercooled Supercharger with their tuning tablet for their CARB tune. Tablet is pretty much like an OFT. New owner must send their stock tune to Sprintex if they plan to run their CARB tune. Installed June 2018 and only put about 3,500 miles on it since. Map sensor plate is tapped with a fitting for a boost gauge. $3,200
- P3 Gauges Multi Gauge OBD-ll version that reads CEL codes. Comes with analog boost sensor and tubing kit $340
- Motiv Overpipe $120
- HKS Dual Resonated Front Pipe $180
- JDM OEM Exhaust Tips $80
- TOMS Drop In Air Filter '13-'16 ONLY $50
- Verus Engineering Bell Housing Cover $20
- IRP Shifter Red Button with new unopened Anti-Rattle Gasket Kit $420
- HKS Oil Cap $50
- APR CF Radiator Cooling Plate $80
- Downstar Gold Engine Bay/Strut tower Dress Up Kit $80
- Racer X Master Cylinder Brace $50
EXTERIOR
- CWEST Lip Kit. Front lip, sideskirts, rear lip. Scrapes on bottom of front lip and a couple minor cracks from scraping. $850
- Side quarter window louvers $30
- LegSport CF Duckbill $480
- BeatSonic Shark Fin Antenna $60
- Pro Composite Type 2 CF Fender Fins with turn signals. Clearcoat job was crappy and so it has started to crack/flake off. Just needs new coat of clear. $500
- OEM BRZ Premium model fog light delete covers. Modified them to be functional with black mesh screen. Perfect for use with oil coolers. $30
- TRD Fender Extensions. Crappy cracked clearcoat job so they could use new coat of clear. Paint color match is pretty spot on. $350
- OEM Door Handle Key Hole Keyless Cover. Used on my driver side handle to delete the key hole. Can also use on passenger side door handle $20
- Yellow Lens Foglights with H11 3000K HIDs and H11 conversion harness $100
INTERIOR
- TOMS Steering Wheel. No airbag just the wheel. $450
- Autowear Seat Covers. Slight wear mark on drive side seat bottom cover. Rest are perfect as I rarely have passengers with me $280
- Emdom USA Seat Belt Covers Black with red stitching $30
- JDM OEM Red/Black Side Sills $80
- OEM JDM Red STI Push Start Button without status light. For cars with factory push start ONLY $120
- JDMStation Aluminum STI Sill Plates $40 plus your stock sill plates
- Sweidit Perforated Black Alcantara/Red stitch Upper Door Panel Armrests, Lower Door Panel Armrests, E-Brake Boot, and Shifter Boot $380
- GCS Red HVAC Knob Covers $20
SUSPENSION/UNDERCARRIAGE
- Perrin Adjustable Front and Rear Sway Bars with bushings $320
- Racer X Gold Rear End Links $50
- HKS Kansai Service Rear Strut Bar. Goes around the spare tire. $160
- Carbing Front Strut Bar $140
- Carbing Front Strut Tower Braces $120
- Carbing Rear Side Cross Member Brace 2 $150
- Cusco Rear Bumper Power Brace $80
- Whiteline Rear Differential Bushing Inserts $25
- Perrin Steering Rack Lock Down $40
DGMlJDlBRZ is offline   Reply With Quote
Old 05-11-2020, 02:01 PM   #13018
Steves_nuts
Drives: 2016 Subaru BRZ
BUMP
Rear and side louvers available?
Steves_nuts is offline   Reply With Quote
Old 05-11-2020, 02:06 PM   #13019
tazma61
Drives: 85 AE86
WTB: SoCal
Looking for 2018+ OEM BRZ front passenger seat in black.
Please let me know if you have one collecting dust in your garage.
Thanks!
tazma61 is offline   Reply With Quote
Old 05-11-2020, 02:43 PM   #13020
DGMlJDlBRZ
DGMlJDlBRZ's Avatar
Juat the side louvers. Rear louvers are long gone
