Old 04-26-2020, 04:36 PM   #1
saltywetman
Drives: 2020 Toyota 86 GT 6M
Cat-free header systems with hi-flow cat in frontpipe
From a quick search I can find that APEXi, HKS, and fujitsubo offer catfree header -> front pipe systems with high flow catalyzers in the front pipe. However, APEXi seems to be the only manufacturer that bothered to relocate the second O2 sensor to after the high flow cat.
Anyone know why HKS and fujitsubo didn't bother to relocate the sensors? From the experiences shared by APEXi owners, they did not get a CEL after installing their system.
Is it because all header upgrades should follow with a tune which will take care of the CEL anyways?
saltywetman is offline   Reply With Quote
Old 04-26-2020, 04:40 PM   #2
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Most likely.
Old 04-26-2020, 05:54 PM   #3
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
Ideally you'd get a tune.
Having the O2 relocated to after the secondary cat is no guarantee you'd get no CEL. Most that don't relocate just provide you with an O2 spacer.
Old 04-26-2020, 10:45 PM   #4
Turdinator
Señor Member
Turdinator's Avatar
If you get a non-oem header you would be crazy not to get a tune also. You are leaving drivability, reliability and power all on the table.
1974 TA22 Celica
2013 86 GT
Old 04-26-2020, 11:09 PM   #5
weederr33
Airborne at your service
weederr33's Avatar
Drives: '17 BRZ Series.Yellow
HKS does relocate the second sensor behind the cat. It also includes an extended bung for the sensor. Though it also comes with a plug if you don't want to relocate it. That's what I did with mine.
MS, CSCS, TSAC-F, CPT
Old 04-27-2020, 12:47 AM   #6
saltywetman
Oh interesting i didn't know that. i wonder what the difference is between HKS and APEXi then because they look exactly the same with similar sized cat
HKS comes with overpipe and frontpipe as well right?
Old 04-27-2020, 04:47 AM   #7
weederr33
weederr33's Avatar
No overpipe unfortunately. Just the header and front pipe. But you won't gain anything from an aftermarket overpipe. But HKS does make their own now.
I'm sure there are some slight differences. I know the muffler design is different, but the catalytic might be sourced from the same company. I'm sure you would like either one, though the HKS is the cheapest of the three.
Old 04-27-2020, 09:45 AM   #8
Ernest72
Get a tune with a header. No good reason not to. An extended bung just takes the O2 sensor out of the stream which can stop a CEL. But get a tune it’s worth it, even an OTS tune.
JDL UEL header and over-frontpipe Yoshoobaroo Engine, Exhaust, Bolt-Ons 13 03-07-2019 06:00 PM
Double (high flow) catted frontpipe? JoeHK Engine, Exhaust, Transmission 22 01-10-2016 07:34 AM
Depo Racing Hi Flow Cat Frontpipe & Overpipe $279.99 Depo Racing Engine, Exhaust, Bolt-Ons 8 02-06-2015 06:21 PM
TEIN Coilover Systems On Sale Through 12/31 - Free $25 Gas Card - Free Shipping! Anthony@RWHP Brakes, Suspension, Chassis 6 12-25-2013 08:07 PM
