Old 04-25-2020, 02:34 PM   #1
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
PP Sachs shock assembly pictures -- anyone have it?
I've been searching for some time, and I am trying to get clarification...
Are the Sachs dampers on the Performance Package the same dimensions as the regular shocks? Specifically, the front struts, are they the same?
I know the STI dampers are different than regular BRZ Showa shocks. The STI dampers are same as the Showa Tuning Evolution series, and (most likely) are probably both made by Showa.
Any help is appreciated.
Alex
Old 04-25-2020, 03:24 PM   #2
Espi
Espi's Avatar
Drives: 17 BRZ
Took this yesterday. Showa and Sachs side by side
Espi is offline   Reply With Quote
The Following User Says Thank You to Espi For This Useful Post:
mav1178 (04-25-2020)
Old 04-25-2020, 04:42 PM   #3
asdf
Loading...████████] 99%
asdf's Avatar
Drives: #0517
Are the PP dampers slightly longer at the bottom?
R1 3 5
. 2 4 6
asdf is offline   Reply With Quote
Old 04-25-2020, 04:48 PM   #4
solidONE
solidONE's Avatar
Drives: FR-S Whiteout
looks the same total length but the strut mount flange is a different design so it looks longer.
Intent > Content
Old 04-25-2020, 05:08 PM   #5
mav1178
mav1178's Avatar
Thanks for the pic.
Espi (04-25-2020)
Old 04-25-2020, 07:49 PM   #6
Espi
Espi's Avatar
Drives: 17 BRZ
if i remember correctly its the same size.
PP Sachs suspension vs tS Sachs supspension FindOphion Suspension | Chassis | Brakes -- Sponsored by 949 Racing 21 05-24-2020 04:35 PM
Sachs PP Shock & Eibach Spring Combo - Roll Center Correction? x_hawker Suspension | Chassis | Brakes -- Sponsored by 949 Racing 23 07-18-2019 03:41 AM
Adjustable Coilovers - Loose Shock Assembly and Spring Unloading EndlessAzure Issues | Warranty | Recalls / TSB 14 09-27-2017 10:23 AM
Raceseng Shock Top - Rear Upper Shock Mount with 1” Increased Travel RJasonKlein Brakes, Suspension, Chassis 2 01-18-2017 05:33 PM
What can you learn from a shock dyno chart? Or shock dyno 101 Racecomp Engineering Suspension | Chassis | Brakes -- Sponsored by 949 Racing 30 03-01-2016 08:40 AM
