Old 04-23-2020, 07:50 AM   #29
ToySub1946
ToySub1946's Avatar
Drives: 15FRS, 05MustangGT, 85Toyota truck
Though the OP did not ask...and I believe no one else even mentioned...
In manual mode the vehicle is gonna get worse fuel mileage.
That would be the big difference.
Most auto trans vehicles are designed to upshift early, boring, yet saves fuel.
ToySub1946 is offline   Reply With Quote
Old 04-23-2020, 07:59 AM   #30
ToySub1946
ToySub1946's Avatar
These trannys were great in the snow country.
Go directly from L to R or vice versa, rock the car, to get out of stuck conditions.
Geezer memories...LOL
The Following 2 Users Say Thank You to ToySub1946 For This Useful Post:
Dadhawk (04-23-2020), humfrz (04-23-2020)
Old 04-23-2020, 09:19 AM   #31
mrg666
pessimistic skeptic
mrg666's Avatar
I have compared mpg. There is no difference when I shift manually for saving gas. I can also shift for performance driving, then all bets are off.
The Following User Says Thank You to mrg666 For This Useful Post:
ToySub1946 (04-23-2020)
Old 04-23-2020, 09:45 AM   #32
Spuds
The Dictater
Spuds's Avatar
Drives: '13 Red Scion FRS
Ignorance may be bliss but knowledge is power.
If OP wanted power, they would have bought a Mustang. They bought an 86, they already chose bliss.
soundman98 (04-23-2020), Ultramaroon (04-23-2020)
Old 04-23-2020, 09:46 AM   #33
JoeC
Drives: Subaru BRZ Limited
serious question. Is is damaging to manually shift an automatic that doesn't have a "manual mode"? Every auto I've ever seen still has manual gear selections. Is it bad to use those to row through the gears or are they just made to hold the car in a certain gear?
JoeC is offline   Reply With Quote
Old 04-23-2020, 10:16 AM   #34
mrg666
pessimistic skeptic
mrg666's Avatar
Unless you shift to opposite direction gear or park while the vehicle is still moving, manual gear shifting is never a problem. Automatic transmission shifts perfectly every time since the shift is actually done by the transmission itself. Just engine/transmission wear can be a problem when you hold the gear at low and drive at very high rpm for extended periods, not mentioning the waste of gas.
Spuds (04-23-2020)
Old 04-23-2020, 10:28 AM   #35
Depends. Some would be fine and others would lead to disaster. Can't really give a yes or now answer.
Try shifting from D to L at about 50MPH with a 64 Chev two speed Powerglide tranny and watch the show as everything locks up as the engine screams (believe me).
Modern computer controlled trannies on the other hand would deal with it just fine.
Old 04-23-2020, 02:05 PM   #36
juanlien
Drives: M5
The car will be fine, you will be better.
With practice, you might be able to get a real transmission if your own one day!
(That was a joke, the classic AT vs MT arguments entertain me).
nice argument
juanlien is offline   Reply With Quote
Old 04-23-2020, 04:13 PM   #37
No replacement for the complacent?
soundman98 (04-23-2020), Spuds (04-23-2020)
Shifting Problem (Automatic) FRSure Issues | Warranty | Recalls / TSB 61 05-09-2021 07:38 PM
Automatic Supercharged Gt86 Shifting Issue Nawar Forced Induction 9 02-10-2019 02:25 AM
Automatic BRZ down shifting eric2523 Engine, Exhaust, Transmission 12 08-20-2015 06:30 AM
Automatic Transmission Kick/Choke when shifting gears Tech Gremlin Engine, Exhaust, Transmission 13 06-16-2015 01:54 AM
Paddle shifting automatic downshift FR-YES Scion FR-S / Toyota 86 GT86 General Forum 15 08-06-2012 09:18 AM
