Old 04-22-2020, 11:35 AM   #1
Roopert
Roopert's Avatar
Drives: 2015 Scion FRS
Automatic shifting yay or nay?
Is it damaging to an automatic FRS to be consistently in "manual mode" ? I use it for my commute every day because it's a lot of fun but recently thought about potential damage. Anyone have insight? I spend about 10-15 minutes of my commute on really fun winding roads.
Purchased 12/2019
2015 FRS-Automatic
13,500 odometer
Stock
25 mile commute round trip
Sent from my PH-1 using Tapatalk
Roopert is offline   Reply With Quote
Old 04-22-2020, 11:56 AM   #2
HKz
Reformed
HKz's Avatar
Drives: '23 GRC, '11 Prius, '04 RAV4
why would manual mode change anything? it is still a computer shifting..the only potential damage I could see would be going into manual mode straight away and banging the limiter before your engine has a chance to warm up but keep in mind it is no different than keeping it in automatic mode and going full throttle, the computer will keep it in lower gear and go to redline.. so in short, after it is up to operating temp, the mode should not make a single difference when you have an automatic trans and you ain't doing any damage to the engine..more wear perhaps, but if you aren't putting extra wear then you're doin it wrong.
HKz is offline   Reply With Quote
The Following 5 Users Say Thank You to HKz For This Useful Post:
humfrz (04-22-2020), soundman98 (04-22-2020), Spuds (04-22-2020), Tcoat (04-22-2020), why? (04-23-2020)
Old 04-22-2020, 11:56 AM   #3
mrg666
pessimistic skeptic
mrg666's Avatar
There is absolutely no problem with manual shifting. I always drive in manual mode.
The Following User Says Thank You to mrg666 For This Useful Post:
why? (04-23-2020)
Old 04-22-2020, 12:04 PM   #4
86TOYO2k17
Drives: 2017 toyota 86
Potentially more damaging not using it
Old 04-22-2020, 12:09 PM   #5
What HKz said.
Old 04-22-2020, 12:44 PM   #6
86TOYO2k17
Auto mode likes to lug the engine in certain scenarios, manually downshifting in anticipation when you know it’s going to lug will be better for your engine, if its a scenario that lasts long enough to where it will auto up shift again after manually downshifting and lug the engine putting it into manual mode for the duration of the scenario to hold the gear will be better for the engine.
The Following 3 Users Say Thank You to 86TOYO2k17 For This Useful Post:
mrg666 (04-22-2020), NWFRS (04-22-2020), Spuds (04-22-2020)
Old 04-22-2020, 12:51 PM   #7
Spuds
The Dictater
Spuds's Avatar
Drives: '13 Red Scion FRS
The car will be fine, you will be better.
With practice, you might be able to get a real transmission if your own one day!
(That was a joke, the classic AT vs MT arguments entertain me).
The Following User Says Thank You to Spuds For This Useful Post:
Old 04-22-2020, 01:34 PM   #8
mrg666
pessimistic skeptic
mrg666's Avatar
Exactly! Automatic transmission reacts after the effect. When I am shifting manually, I manually downshift before the effect which reduces engine wear and also saves gas ... much more efficient. That is the way to avoid torque dip, I don't have it but still that is the way to drive our twins.
Old 04-22-2020, 01:39 PM   #9
Sasquachulator
Pavement Grey
yeahhh........no
Its designed to shift gears....its not gonna break.
And even still the computer will prevent you from doing something stupid like downshift to the wrong gear and overrev the engine
The Following User Says Thank You to Sasquachulator For This Useful Post:
guitarman (04-22-2020)
Old 04-22-2020, 07:52 PM   #10
guitarman
Drives: 2016 Scion FR-S
Yup....I've ah-hem...."tested" this failsafe myself. The dashboard lights up like a xmas tree and blinks "you idiot" but the computer does not let this happen.
The other problem I sometimes seem to have is when I switch back and forth and "forget" that I am in manual mode-until I'm redlining in 1st and looking like an idiot. Maybe I should just keep it Manual-mode all the time. Maybe I'm just going senile....hard to say
guitarman is offline   Reply With Quote
The Following User Says Thank You to guitarman For This Useful Post:
Dadhawk (04-23-2020)
Old 04-22-2020, 07:57 PM   #11
Roopert
Roopert's Avatar
Thank you all for the responses. My mind is put at ease. Time to go have some fun.
Old 04-22-2020, 08:50 PM   #12
I disagree with most of the above comments because, in fact, we don't have enough information to determine whether or not there are any relevant functional differences between the two modes.
But it doesn't really matter because, by now, we would likely have seen failures that could be attributed to using one mode over the other. That was how the design flaw in the first gen five-speed hondamatic transmission was discovered. The manual mode was more aggressive in its timing and didn't wait sufficiently for rev match. The root cause was actually insufficient cooling of the - iirc - third gear brake band but they went with a firmware patch at first.
Old 04-22-2020, 08:52 PM   #13
Roopert
Roopert's Avatar
And just like that... paranoia
Old 04-22-2020, 08:54 PM   #14
Spuds
The Dictater
Spuds's Avatar
I wish I could say you were full of it, but everything you said is technically true...
But also bullshit.
The Following 4 Users Say Thank You to Spuds For This Useful Post:
86TOYO2k17 (04-22-2020), soundman98 (04-22-2020), Tcoat (04-23-2020), Ultramaroon (04-22-2020)
Shifting Problem (Automatic) FRSure Issues | Warranty | Recalls / TSB 61 05-09-2021 07:38 PM
Automatic Supercharged Gt86 Shifting Issue Nawar Forced Induction 9 02-10-2019 02:25 AM
Automatic BRZ down shifting eric2523 Engine, Exhaust, Transmission 12 08-20-2015 06:30 AM
Automatic Transmission Kick/Choke when shifting gears Tech Gremlin Engine, Exhaust, Transmission 13 06-16-2015 01:54 AM
Paddle shifting automatic downshift FR-YES Scion FR-S / Toyota 86 GT86 General Forum 15 08-06-2012 09:18 AM
