Old 04-22-2020, 10:17 AM   #3781
Racecomp Engineering
Originally Posted by Spacemane969 View Post
I've been running TRD springs for a while now and I want to upgrade to BC coilovers. I want moderately more stiffness but I'm so hesitant to make drastic changes in the overall engineering so I'm thinking 5k front and 8k for the rear to simulate the OEM FR-S 2.3k and 3.8k rates. Anything wrong with this idea of matching the spring rates F/R? Thanks
5k front and 8k rear is a pretty aggressive rear bias. Those that do run that much rear bias in spring rate usually have a clutch LSD that behave differently than the OEM LSD.
For the spring rates, it's important to remember that the OEM suspension is very bumpstop active, so the spring rates are only one part of the equation. And then there's the effects of the dampers. Coilovers are usually a lot less bumpstop active. Another factor, the front and rear suspensions are a completely different design. Increasing the front by 10% will have a different effect than increasing the rear by 10%.
Spring rates are usually chosen after considering tire choice and intended usage. What tires are you using?
- Andrew
solidONE (04-24-2020), Spacemane969 (04-22-2020)
Old 04-22-2020, 10:35 AM   #3782
Takumi788
JHerbert Racing
Takumi788's Avatar
Drives: 2013 Scion FRS
Thanks for the answer guys. My OCD is going to drive me to purchase the SPL lower control arms to fix this but it is good to know it isn't a huge issue.
- #813 2013 Scion FRS Build Thread
- JHerbert Racing Website
Takumi788 is offline   Reply With Quote
Old 04-22-2020, 10:43 AM   #3783
churchx
churchx's Avatar
Drives: 2014 GT86
Takumi788: what top mounts you have? Raceseng should be able to adjust also caster. Whiteline ALC should change it too. Imho SPL LCAs are expensive overkill unless you go for them for other reasons (eg. changing bushings to pillowballs and insane adjustability of everything) instead of just to even caster. My OCD would have lost the fight against cost of $1.3K for those LCAs, even if they are such quality piece of work
Old 04-22-2020, 12:33 PM   #3784
Takumi788
JHerbert Racing
Takumi788's Avatar
I should mention it is a track car. I plan on sticking with the chassis for a while and don't care about street-ability.
I am still on a modified prototype top mount from YCW Engineering.
My OCD leads me into horrible and often costly places. lol. Its an issue and I am aware. On top of that I am also competitive, and if there is a few tenths to be gained by correcting my caster, I'm in. Maybe the raceseng top mounts would be a more cost-efficient solution. Thanks!
Old 04-22-2020, 01:48 PM   #3785
Spacemane969
Spacemane969's Avatar
Drives: 2013 ARGENTO A/T
- Andrew
I get a lot of flak but I'm actually a fan of OEM primacies. I haven't found a tire that has a sidewall as stiff and communicates as accurately. I'm considering the new PS4S after the coils if I need the grip. This is for spirited/occasional track.
Spacemane969 is offline   Reply With Quote
Old 04-22-2020, 01:58 PM   #3786
Pat
Pat's Avatar
Drives: 2023 BRZ
I'm surprised. What other tires have you tried?
Old 04-22-2020, 03:34 PM   #3787
Spacemane969
Started with hankook v12 Evo 2 and that was a disaster. I was about to pull the trigger on pilot super sport but I read too many remarks about mushy sidewalls to justify the risk of being unhappy. I have more confidence in the PS4S now that it is the OEM option for the brz ts and 86 trd.
Old 04-22-2020, 07:50 PM   #3788
AndreC
Drives: Fast track beast
The factory Primacys have a much softer sidewall than the Pilot Sport 4S, which is still on the soft side. Hankooks are a medium stiffness sidewall typically, like the V12 and RS4 and more communicative. Stiffer but not ultra stiff are the Firestone Indy 500 (Bridgestone Re003), and super stiff tend to be the case with "most" BFG's and Dunlop's.
Sent from my SM-G965W using Tapatalk
AndreC is offline   Reply With Quote
Old 04-24-2020, 12:40 PM   #3789
Spacemane969
So for a mild spirited driver setup, what would be wrong with a 5/6k coilover setup? Ft86speedfactory stocks BC coils at 8k/8k, with anything else a special order. I just don't understand why this would be the default if the OEM spring rates are different front and rear. I understand there are tons of variables but surely those OEM numbers mean something right?
The Following User Says Thank You to Spacemane969 For This Useful Post:
sato (04-24-2020)
Old 04-24-2020, 12:46 PM   #3790
solidONE
solidONE's Avatar
Drives: FR-S Whiteout
6K in the rear with the right amount of damping pressure can be comfortable and even ride like a boat. 5K~6K range is a good range for spirited street, IMO. 8K is far from mild on this car. The main function for such high spring rates on the BC, i believe, its a sort of bottom out prevention. That should give you an idea on the ride quality on this.
Intent > Content
The Following User Says Thank You to solidONE For This Useful Post:
Spacemane969 (04-24-2020)
Old 04-24-2020, 01:41 PM   #3791
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
The motion ratio is different front and rear(Mac Strut vs. Multilink), which changes your effective spring rate. Most of the aftermarket has chosen to use the same rate front and rear. It works so
BC's and 8k. Please don't. Look at ST's, RCE SS1's, Flex A's. There are much better options out there.
Old 04-24-2020, 07:22 PM   #3792
Grady
Grady's Avatar
My setup now is I have a 2017 PP with Ebach pro springs, 225 MP4s tires, Verus top hats and Ventus 3. Plus other minor changes. On the track my boost seething is low probably 250ish WHP. I daily the car and am satisfied with the ride now. Not sure about the Sach dampers but my experience most factory struts are shit in 30k miles. What would be the better upgrade for performance? I am ok with losing some ride quality. B6’s, Koni, or should I just buy $2k coilovers? I would prefer to keep the top hats and springs I have already purchased. I may run the pilot sport cup 2 tires at one point also. But I will not go to wide tires.
Old 04-24-2020, 08:14 PM   #3793
Scracho
Drives: 2018 Subaru BRZ
Hi guys!
I'm on my 4th 86 (Yes 4th) and have played with various suspension setups. I'm in the market for a $1500 street occasional track coilover and all roads have led me to a couple options.
IMO the largest improvement in ride/handling/lap times happen when you go from stock to DECENT coilover setup then from there unless you go to a full on pro setup the lap times aren't improving relative to cost from your decent "entry level" to medium tier coils. Thus the savings can be used for so many other items that will yield a faster, flatter and more enjoyable ride.
So that being said... CSG Tein Flex A OR RCE SS1????
On my fourth 86... and everything in between
Scracho is offline   Reply With Quote
The Following User Says Thank You to Scracho For This Useful Post:
CSG Mike (05-04-2020)
Old 04-25-2020, 11:09 AM   #3794
RToyo86
RToyo86's Avatar
Drives: 17 Asphalt 86
@ Racecomp Engineering
Any ideas on when RCE yellows will be available to order?
Looking to order through FT86Motorsports. They're special order which I assume will go directly through you.
Air Suspension Discussion Thread - Let's Get Nerdy Andrew@ORT Suspension | Chassis | Brakes -- Sponsored by 949 Racing 174 02-13-2016 04:17 PM
RallySport Directs Everything Suspension thread!! RallySport Direct Brakes, Suspension, Chassis 21 07-02-2014 06:31 PM
The OFFICIAL Ohlins Coilover Suspension thread - High End Competition Suspension ModBargains.com Suspension | Chassis | Brakes -- Sponsored by 949 Racing 63 05-22-2013 09:15 AM
2012 Team USA vs the 1992 Dream Team ERZperformance Off-Topic Lounge [WARNING: NO POLITICS] 1 09-14-2012 07:19 PM
Team build thread; PROJECT.STH trueno86power Other Vehicles & General Automotive Discussions 0 03-02-2010 11:13 AM
