Old 04-21-2020, 08:52 AM   #68965
That was my normal price for 93..
Oooooh I don't want to talk about anything higher than 91 here
Tcoat is offline
Old 04-21-2020, 09:04 AM   #68966
ichitaka05
Site Moderator
ichitaka05's Avatar
Drives: ichi 86 Project
Originally Posted by Boomerang View Post
Assume brass fittings are OK(1650 deg F)?
Ebay has heaps, unless I am getting it wrong..
https://www.ebay.com/itm/5-16-X-3-8-...-/254153992268
https://www.ebay.com/itm/HOSE-BARB-E...-/173936974851
First one doesn’t show temperature rating... unless I’m missing it
Second one do show it, but it show up to 160F.
ichitaka05 is offline
Old 04-21-2020, 09:25 AM   #68967
Boomerang
86
Boomerang's Avatar
Stainless Steel has a higher temp rating;
https://www.usplastic.com/catalog/it...x?itemid=90865
This shows SS temp rating at 200F, maybe you need SS?
https://www.aliexpress.com/item/32904682631.html
Boomerang is offline
Old 04-21-2020, 09:50 AM   #68968
ichitaka05
Site Moderator
ichitaka05's Avatar
I wonder if they mistaken some of description. Instead of 160C they put 160F?
This one claim temperature rate of 120C, which is 248F
https://www.ebay.com/itm/223529785054
Old 04-21-2020, 09:58 AM   #68969
p1l0t
p1l0t's Avatar
Jet fuel doesn't get hot enough to melt steel!
p1l0t is online now
Old 04-21-2020, 10:07 AM   #68970
Boomerang
86
Boomerang's Avatar
It's possible, what do you need the elbows for?
Brass will melt first, followed by SS.
If 160F is your max temp then go metal not plastic.
Old 04-21-2020, 10:13 AM   #68971
ichitaka05
Site Moderator
ichitaka05's Avatar
I need it for FXT oil cooler hose connecting to throttle body. From the info I got, throttle body hoses are 5/8” (8mm), FXT oil cooler hose lines are 3/8 (10mm) & 1/2” (12mm). So I need adapter to connect it. Of course, you can force em in all of em using smallest hose... but prefer not.
Max temp expected from our car is 260F (w full track time) w average of 190F normal. So I need adapter that can handle 250F~260F temperature just in case.
Old 04-21-2020, 10:20 AM   #68972
Boomerang
86
Boomerang's Avatar
SS will do that no problem
Old 04-21-2020, 10:39 AM   #68973
WOW Random is boring.
Car stuff.
Oil temp
Blah blah blah.
This is supposed to be the fun section.
Tcoat is offline
Old 04-21-2020, 11:18 AM   #68974
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Okay Alex Jones.
NoHaveMSG is online now
Old 04-21-2020, 11:20 AM   #68975
p1l0t
p1l0t's Avatar
Okay Alex Jones.
It's all just a conspiracy theory until you are locked in your house waiting for your turn to get "tested..."
p1l0t is online now
Old 04-21-2020, 11:33 AM   #68976
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
How else are they going to check to see if what they are putting in chemtrails is working
Old 04-21-2020, 11:41 AM   #68977
p1l0t
p1l0t's Avatar
They have to change the batteries in the birds first.
p1l0t is online now
Old 04-21-2020, 11:43 AM   #68978
weederr33
Airborne at your service
weederr33's Avatar
Drives: '17 BRZ Series.Yellow
Bwahaha finished my new business cards! Oh how quarantine has made such a trivial task grand.
MS, CSCS, TSAC-F, CPT
weederr33 is offline
