Old 04-18-2020, 04:21 AM   #15
JD001
JD001's Avatar
Drives: Subaru BRZ
Originally Posted by gpvecchi View Post
The Eibach DE website has no Sportline in catalogue.
You are not in EU... :-D
What's the part number you got?
I can't remember the part number as I bought them over 5years ago from Fensport (they installed them too).
Old 04-18-2020, 08:51 AM   #16
J95
J95's Avatar
Thank you for your help!
Definitely I will try Eibach pro kit, and maybe in the future upgrade with Bilstein B6 or some coilovers
J95 is offline   Reply With Quote
Old 04-18-2020, 12:09 PM   #17
Grateful Dave
2nd 86 member
Grateful Dave's Avatar
Drives: 2013 Asphalt AT FR-S
Originally Posted by Busybee View Post
Not sure where I read it but maybe I am wrong. Aren’t the Eibach pro kits same with the TRD?
Also Is the sway bar in the Eibach pro kit plus also the same that TRD is using ?
Thanks
I also heard that Eibach makes the North America TRD springs and antisway but not sure which Eibach kit they are comparable to. One lowers 1' and the other @2"? I used to know I forget that was seven years ago. Eibach was my aftermarket choice. I went with TRD because they might have a better spring rate & swaybar because of more testing possible by Toyota by Toyota engineers. I didn't care about adjusting them. I trusted their set up. 1" lowers plenty for me. It gives you the feeling that you are sitting in a real sports car than sitting in a sporty car. It enhances the car not change the car. While you are there, get the Bilstein B-8 shocks & Whiteline camber bolts. I did those and more Whiteline bushings and Cusco bracing when I did my suspension.
Grateful Dave is offline   Reply With Quote
Old 04-18-2020, 03:57 PM   #18
gpvecchi
gpvecchi's Avatar
For those interested, this is the Eibach de page for 86 (strange address, but it's a redirect from eibach.de):
http://web2.carparts-cat.com/default...07&14=4&12=130
No ARB, too...
Old 04-18-2020, 05:59 PM   #19
Infinity
Drives: 2016 Scion FR-S
How much drop do you want? I would think that would be the main determining factor in which lowering springs to get.
Infinity is offline   Reply With Quote
Old 04-18-2020, 06:32 PM   #20
ZDan
ZDan's Avatar
Drives: '23 BRZ
FWIW, Swift BRZ Sport springs lowered my car about 30mm. Rates are well suited to stock PP Sachs dampers and well balanced at 3.8/4.5 kg/mm front/rear.
Note: combined with camber plates (which further reduce front bump travel), the lost front travel led to terrible ride as the fronts would bottom over the tiniest bumps. With the stock front strut top mounts, no problem.
Old 04-20-2020, 09:48 AM   #21
Racecomp Engineering
Remember that not all camber plates reduce bump travel...most of them just raise ride height a little (some more then others). Your raceseng plates reduced travel due to their unique upper spring perch for OEM style shocks.
- Andrew
ZDan (04-20-2020)
TRD lowering springs LordTaikun Suspension | Chassis | Brakes -- Sponsored by 949 Racing 68 01-29-2017 12:03 PM
TRD lowering Springs nammie81 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 32 12-20-2016 01:43 AM
WTB: Lowering Springs pooch Want-To-Buy Requests 1 03-29-2016 11:50 AM
WTB: Lowering Springs Stealthy Want-To-Buy Requests 3 01-17-2015 07:55 AM
lowering springs - if you did it tell me more.. rikdrt1 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 79 09-23-2013 11:50 AM
