#4985 |
The stock car has dynamic geometry that is achieved via asymmetrical bushing deflection. It's quite trick, and allows for the stock car to perform above expectations for the presented geometry based on straight articulation.
#4986 | ||
Drives: Miata
Is this all common knowledge? Should I search? Quote:
My initial question was about ackerman. Without me having to take an engineering class, can you tell me if the 86 has what at least acts like normal ackerman? |
#4987 | |
This behavior is eliminated when the factory asymmetrical bushing is eliminated, but also leads to what most feel to be a more linear car. |
| The Following User Says Thank You to CSG Mike For This Useful Post: | racingfool (11-27-2020) |
#4988 |
Drives: Crapcan
Are you refering to the front lower control arm bushing? The big bastard up front, bolt mounts vertically.
#4990 |
I think the MotoIQ sticky at the top of the suspension forum has more details but it's been a while since I looked at that. I'm not sure 100% of the information in that article was correct but it at least has some good info.
- Andrew |
| The Following User Says Thank You to Racecomp Engineering For This Useful Post: | NoHaveMSG (04-17-2020) |
#4991 |
Drives: '14 BRZ Limited
I ran Barber today and ran into something I’ve never felt before with the car, in certain corners the steering becomes heavy as if it was not powered. Any other place on the track it works fine. Is this normal for the car? I’m running the tracbox, a friend told me the nannies are still kicking in and it’s expected.
Thoughts? Want to see if it’s ok to keep running the car like this or if it’ll eventually break the rack |
#4992 |
Drives: '13 FRS - STX
Failsafe mode where the power steering motor overheats/overloads and shuts down to protect itself.
Less caster can help if you have aftermarket caster adjustment but otherwise most people just power through it iirc. |
| The Following 2 Users Say Thank You to strat61caster For This Useful Post: | peaches (11-02-2020), treedodger (11-02-2020) |
#4993 |
Drives: Subaru BRZ
Happens at Road Atlanta coming out of 5 and going uphill, I just power through it.
| The Following 2 Users Say Thank You to Code Monkey For This Useful Post: | peaches (11-02-2020), treedodger (11-02-2020) |
#4994 |
Drives: 2016 BRZ
Mike, got one for you. New to the forum and somewhat new to the car. My wife runs 86cup in Colorado. We’ve done a ton of HPDE, instructing, and lemons racing in mix of BMW, Camaro, and the BRZ. I do most of the needed wrenching, but this has me a bit stumped:
Her BRZ had 20k miles when we got it and had a bunch of modifications from prior owners (notably Tein Flex A, rear Perrin sway bar, bunch of stiffeners etc.). I don’t think the car had seen the track much before we got it. When she first started tracking we noticed the Left rear wheel nut loosened itself by about 1/2 turn and the bearing also seemed a bit loose. I replaced the hub/bearing assembly with a Subaru part from dealer and installed a fresh nut torqued to 140ftlbs. We did 5 track days since then and I had to re-tighten the axle nut again (was trying to back off even w the dimple, maybe 1/16th of a turn.) I just put the car up and L rear wheel bearing feels loose again!? Very subtle rocking, but it’s only been 1000 miles... In post 863 you mentioned something about “if you don’t replace the hub, you’ll keep loosing bearings”. We replaced the whole bolt-on unit, but should we be looking at more? Hope you can point me in the right direction... cheers! Edit: we usually run w full pedal dance. (I.e. shouldn’t be getting a ton of heat from rear brakes dsc etc... car is running CSG ap racing BBK w/ DTC60s up front, stock callipers w dtc60 out back. Last edited by Fschlottau; 11-26-2020 at 10:10 PM. Reason: More info |
| The Following User Says Thank You to Fschlottau For This Useful Post: | Pat (11-27-2020) |
#4995 | |
Drives: 2013 BRZ, 6MT, WR Blue
This was happening to me a few weeks ago at High Plains Raceway, lap after lap on an uphill, 80 mph sweeper. Glad to hear it isn't a big deal, but is there any way to prevent it? Other than going slower, which isn't really option. |
#4996 | |
2013 Series 10 FRS #553
#4997 |
Drives: '22 GR86
Is there a rough ride height estimate for 2.2-2.5 degrees of rear camber on stock LCA's? Trying to not take the .5 hit in NASA TT5 for replacing control arms.
2022 Toyota GR86 Halo NASA TT5
2015 Subaru BRZ Crystal White Pearl NASA TT5 SOLD |
#4998 |
Drives: '14
Mine were in that range with the rear pinch welds at 130mm
Always learning.
| The Following User Says Thank You to itschris For This Useful Post: | staples323 (12-07-2020) |
| Simple question, hard to find answer... | Mango22 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 5 | 05-16-2013 06:23 PM |
| Silly question about protecting track rims | sw20kosh | Tracking / Autocross / HPDE / Drifting | 16 | 04-25-2013 12:34 PM |
| Asking the question that I already know the answer to. Are the engines the same? | Bigmaxy | Engine, Exhaust, Transmission | 10 | 01-19-2013 07:47 PM |
| Random dog-related question for those who have their BRZ | GMU-BRZ | BRZ First-Gen (2012+) — General Topics | 11 | 05-31-2012 07:48 AM |
| Got my answer - BRZ comes with HID headlights as STD | Z_Rocks | BRZ First-Gen (2012+) — General Topics | 20 | 01-10-2012 09:54 AM |
