Old 04-17-2020, 04:22 AM   #1
Eazy-V
What’s the newest EcuTek RACEROM?
I’m currently running EcuTek RaceROM 9.1, but wanted to know what the newest version is for the FRS/GT86/BRZ? Also, anyone have change logs or feature differences since version 9.1?
FBM Base Turbo Kit with GTX2867R and FlexFuel Kit with Walbro 485 / 550cc Injectors
EcuTek Tuned witih Greddy Profec @ 12PSI Shell 91-E73 and 18PSI E73
1993 Mazda MX6 N/A Fully Built on MegaSquirt (work in progress)
2023 Chevrolet Corvette Z51 Stock
Eazy-V is offline   Reply With Quote
Old 04-17-2020, 04:59 AM   #2
tomm.brz
Drives: brz 2017 hksv2
you have quite old revision
in june 2018 they released racerom10 which added as an important feature, the closed loop fuel control during open loop state, and lot of precompiled features for flex and wastegate/boost control
Recent one is racerom 11.1, while the master tuners already got racerom 12 too which adds Live tuning for dyno only, to make tuner do the job a lot quicker if he gets the car for real and not remotely
Seeing the mods you got, i definitely 100% suggests you to upgrade your tune.. a lot of benefits for your actual modded car, i would get rid of the profec or use it auxiliary and hook up and electronic boost controller to the ecu
Eazy-V (04-20-2020)
Old 04-19-2020, 03:49 PM   #3
erebuswarrior
Drives: 2015 Asphalt BRZ
RR10 was very buggy as I understand. I'd suggest hitting up some local dyno tuners and see if they have RR12 installed so you can go in for a full RR12 tune and get your boost control hooked up like tomm said, so it can be controlled in the tune better. RR11 and 12 are huge updates over 9 especially for FI cars.
erebuswarrior is offline   Reply With Quote
The Following User Says Thank You to erebuswarrior For This Useful Post:
Eazy-V (04-20-2020)
Old 04-20-2020, 08:15 PM   #4
Eazy-V
Ok thanks for the info, I'll see what my tuner has
ecutek racerom map switching trevorthepanda Software Tuning 7 06-25-2018 09:17 PM
ECUtek RaceROM Think Tank Kodename47 Software Tuning 10 07-06-2017 04:54 PM
E85 + ECUTEK & RACEROM GT86_PRAGUE Software Tuning 11 08-22-2015 12:01 AM
ecutek racerom brz exam2300 Software Tuning 1 12-20-2014 06:55 AM
EcuTek RaceRom Questions. feldy Engine, Exhaust, Transmission 7 02-12-2014 04:07 PM
