Old 04-14-2020, 01:43 AM   #1
deku
Drives: 2017 subaru brz red, 93 FD RX7
Installing the Kenwood DDX919WS
Hey guys,
I just ordered the Kenwood ddx919ws and will be installing it in a couple of weeks when it arrives. i've read through some forum posts and it sounds like i will need a few additional connectors.I'd like to keep the steering wheel controls, backup camera input, and the usb port connection. here's what i've found below,
PAC USB-TY1 Toyota/Lexus OEM USB Port Retention Cable (for OEM usb connection)
https://www.amazon.com/PAC-USB-TY1-T.../dp/B00F0YJ49O
Metra 40-LX11 Toyota antenna adapter(for OEM antenna)
https://www.amazon.com/Metra-40-LX11...sr=1-2-catcorr
Steering control connector is included with the headunit.
does anyone have a recommendation for the connector i will need to connect the factory back up camera?
deku is offline   Reply With Quote
Old 04-14-2020, 01:57 AM   #2
Drifter X
Drifter X's Avatar
Drives: 2019 Toyota 86 TRD SE
Originally Posted by deku View Post
Hey guys,
Check out my post. Relocate Mirror display for backup camera to aftermarket HU
https://www.ft86club.com/forums/show...1&postcount=52
Drifter X is offline   Reply With Quote
Old 09-15-2020, 01:27 PM   #3
idanvan
idanvan's Avatar
Drives: WRB BRZ
Hey guys,
Wanted to bring this back to life. How did the install go? Thinking of getting one myself and wasn't sure if there were any wiring differences installing in US Spec BRZ.
idanvan is offline   Reply With Quote
Old 09-15-2020, 07:02 PM   #4
deku
I actually ended up going with the DDX920WDABS, I was able to get it with a harness from carbon car systems. was a bit challenging but with the wiring diagram i got it installed. their harness was ok i just had to rearrange pins for the steering controls, amp power and the polarity for one of the speakers was reversed. if you go for it just double check the pins on the harness. im enjoying the radio though.
Old 09-15-2020, 07:57 PM   #5
timurrrr
timurrrr's Avatar
Drives: 2022 GR86
What kinds of problems did you have before rearranging the pins? Do you believe it's the 920 vs older models difference, or was the harness just messed up?
Asking because I have a 918 and everything works but not confident in my ability to hear reverse polarity if it only affects one of the speakers.
Old 09-15-2020, 08:47 PM   #6
deku
one of the speakers had no audio. it was just the harness, i think the 920 is the same harness as the older models(i know its the same as the 919)
Old 09-16-2020, 12:14 AM   #7
Copy
Copy's Avatar
Drives: GR Corolla CE
Pics of it installed?
IG: grcwicks
Copy is offline   Reply With Quote
Old 09-18-2020, 12:35 AM   #8
deku
How do i attach pictures?
KENWOOD DDX917WS snk828 Want-To-Buy Requests 0 03-14-2018 02:50 PM
Kenwood DDX916WSL JBezugs Electronics | Audio | NAV | Infotainment 5 12-10-2017 11:58 AM
FS: Kenwood dnx890hd mmn3js Audio/Visual, Electronics, Infotainment, NAV 3 05-11-2014 09:41 AM
FS: Kenwood HU + JL sub / box KRAZYK Audio/Visual, Electronics, Infotainment, NAV 6 06-10-2013 04:20 PM
NAV on a Kenwood headunit? i_4got Electronics | Audio | NAV | Infotainment 13 12-31-2012 02:42 PM
