Old 04-12-2020, 03:28 PM   #1
dholloway543
Software Hobbiest
Drives: 2015 FRS
MAF Tuning
I have made a simple windows program to help me get average fuel trims so i can edit the MAF map.
This program requires you have an OFT .csv or ECUTEK .csv data log with the parameters
STFT
LTFT
MAF Volt.
It adds the STFT + LTFT together averaging the whole .csv at specific MAF Volt.
It also shows how many samples it took so you can determine if the sample size is big enough for you to trust the outputted value.
It looks bad because i didnt care if it looked nice. Only if it works.
I thought id share it including source incase anyone else wanted to use it
Feel free to share with other people, im leaving this as open source.
https://drive.google.com/file/d/13Yw...ew?usp=sharing
dholloway543 is offline   Reply With Quote
The Following User Says Thank You to dholloway543 For This Useful Post:
NoHaveMSG (06-30-2020)
Old 04-12-2020, 04:14 PM   #2
dholloway543
Software Hobbiest
Drives: 2015 FRS
This is a sample of the output data
Old 04-12-2020, 05:21 PM   #3
QTR FMS
Drives: brz
thia is using ecutek log file .csv
See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
System.FormatException: Input string was not in a correct format.
at System.Number.ParseSingle(String value, NumberStyles options, NumberFormatInfo numfmt)
at System.Convert.ToSingle(String value)
at CSV_STFT.Form1.openFilePopup_FileOk(Object sender, CancelEventArgs e)
at System.Windows.Forms.FileDialog.OnFileOk(CancelEve ntArgs e)
at System.Windows.Forms.FileDialog.HandleVistaFileOk( IFileDialog dialog)
************** Loaded Assemblies **************
mscorlib
Assembly Version: 4.0.0.0
Win32 Version: 4.8.4121.0 built by: NET48REL1LAST_C
CodeBase: file:///C:/Windows/Microsoft.NET/Framework/v4.0.30319/mscorlib.dll
CSV-STFT
Assembly Version: 1.0.0.0
Win32 Version: 1.0.0.0
CodeBase: file:///C:/Users/qtr-f/Downloads/CSV-STFT/CSV-STFT/CSV-STFT.exe
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms/v4.0_4.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System
Win32 Version: 4.8.4001.0 built by: NET48REL1LAST_C
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll
System.Drawing
Win32 Version: 4.8.3752.0 built by: NET48REL1
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Drawing/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
System.Configuration
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Configuration/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
System.Core
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Core/v4.0_4.0.0.0__b77a5c561934e089/System.Core.dll
System.Xml
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Xml/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.dll
************** JIT Debugging **************
To enable just-in-time (JIT) debugging, the .config file for this
application or computer (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.
For example:
<configuration>
<system.windows.forms jitDebugging="true" />
</configuration>
When JIT debugging is enabled, any unhandled exception
will be sent to the JIT debugger registered on the computer
rather than be handled by this dialog box.
QTR FMS is offline   Reply With Quote
Old 04-12-2020, 05:37 PM   #4
Kodename47
Kodename47's Avatar
Drives: UK GT86
I'll leave this here:
VGI's MAF (and everything else) tool
.: Stealth 86 :.
Kodename 47 DJ:
Apoc (04-18-2020)
Old 04-12-2020, 06:28 PM   #5
dholloway543
Software Hobbiest
Drives: 2015 FRS
If you send me the ECUtek data log i can update it the application to suit your needs as well
Old 04-12-2020, 06:45 PM   #6
dholloway543
Software Hobbiest
Drives: 2015 FRS
Originally Posted by Kodename47 View Post
http://www.romraider.com/forum/viewt...p?f=32&t=10481
The link he posted was broken, this one is corrected.
If you want though i can still get mine working for ecuteck datalogs
Old 04-12-2020, 07:27 PM   #7
dholloway543
Software Hobbiest
Drives: 2015 FRS
The software has been updated to include OFT logs and ECUTEK logs.
Same download link
Old 04-13-2020, 07:42 PM   #8
Kodename47
Kodename47's Avatar
Drives: UK GT86
Thanks, fixed it. The good thing about VGI's one is that it removes throttle changes, just averaging cells can get you into issues on areas that are typically for tip in. Also yours will only do closed loop sections of the MAF.
.: Stealth 86 :.
Kodename 47 DJ:
dholloway543 (04-14-2020)
Old 04-14-2020, 09:48 AM   #9
dholloway543
Software Hobbiest
Drives: 2015 FRS
No Thats understandable, and definitely something that people should know. Im just trying to be a good person. It got my fuel trims within 2% for closed loop so I though id share it for other people to use. There are other solutions available but if people who know how to code they can use it for their own needs as well as its open for people to change for how they need. Ive changed the values from maf to coolant temp sensor to help get a ball park of my cold start
Old 06-30-2020, 03:43 PM   #10
brosifSmith
brosifSmith's Avatar
Drives: 2015 BRZ Limited
I think stuff like this is helpful. thank you for posting it! I had to create a whole excel macro in VB to be able to reliably re-scale the MAF sensor after I boosted my car.
brosifSmith is offline   Reply With Quote
Delicious Tuning - Q&A EcuTeK ProECU Tuning and Maps DeliciousTuning Software Tuning 1213 06-17-2025 04:02 PM
R/T Tuning & R/T Tuning Speed Shop Review Thread R/T Tuning User/Vendor/Sponsor Reviews, Feedback, Comments 37 10-03-2014 02:23 PM
Mann Engineering 2nd Quarter Tuning Days April 25th & 26th by Bill (Delicious Tuning) DesertFrs Northern California 14 04-24-2014 03:15 AM
Delicious Tuning - Dyno Tuning Weekend at Mann Engineering's (San Jose, CA) DeliciousTuning Announcements, Contests, Giveaways 6 09-19-2013 05:55 PM
Visconti Tuning - Latest Forced Induction Tuning Info Visconti Forced Induction 340 04-30-2013 06:33 PM
