Engine, Exhaust, Transmission Discuss the FR-S | 86 | BRZ engine, exhaust and drivetrain. |
#15 |
ProCrastinationConsultant
the tensioner bouncing isn't really a cause, it's not really a symptom either. it's doing its job.
tensioners take up the slack. if you rev any other motor, you'll see the tensioner bounce momentarily as the crank pulley yanks on the belt. that's what's happening here, except all the time. because what is literally happening is the crankshaft is speeding up and slowing down drastically over a very short time. some moments, there's slack, other moments, there's not. and the tensioner pully is adjusting for either scenario. the answer here is you're screwed one of two ways. 1. pay to take the motor apart. in the first video, it sounds like a connecting rod slapping around, which would be an out-of-tolerance bearing. if you can prove it's related to the recall and not a user error, despite the fact that they already noted a low oil level, all the costs will be covered. but it takes some investing of ghost money. 2. install a used motor, costs more than option 1, but ensures you wouldn't be on the hook for a $10k motor install on top of a $1500 diagnosis. discuss core charges, or consider selling the old motor to recoup a small amount of funds--if the blocks bearing surfaces are still good(meaning the connecting rod and crankshaft are the problem), some rebuilders might be interested in it.
#16 | |
It should be an easy fix.
#17 |
The Dictater
Drives: '13 Red Scion FRS
You could get a mechanics stethoscope to try to track down the ticking more precisely. The thing you touch with it that makes the noise the loudest is probably broke.
The Following 2 Users Say Thank You to Spuds For This Useful Post: | Opie (04-18-2020), soundman98 (04-12-2020) |
#18 |
Drives: 13 Crystal Black Silica BRZ
I'm gonna be so damn happy if it's actually the vaccume pump. I found a vid of someone with very similar noise and it was the vaccume pump. For the cost compared to an engine is say it's worth a try replacing it, worse case I have a new one. Install seems simple enough also
The Following User Says Thank You to DJ92 For This Useful Post: | humfrz (04-12-2020) |
#19 | |
#20 |
The Following User Says Thank You to humfrz For This Useful Post: | Opie (04-18-2020) |
#21 | |
The Following User Says Thank You to Tcoat For This Useful Post: | Ultramaroon (04-12-2020) |
#22 | |
chicken tonight
The Following User Says Thank You to Ultramaroon For This Useful Post: | Tcoat (04-12-2020) |
#23 |
pessimistic skeptic
I would just get a reliable used engine and swap the whole engine. These engines are too much work to take apart, too tricky to put together. It is not worth the trouble compared to swapping the engine unless you want to rebuild it
#24 |
An easy way to check the timing of the tick is to use a timing light. If the tick is in time with the light it is probably a valve issue, if twice as fast a rod, if random an accessory.
edit: I know someone is going to say no dist, use a noid on the wire to the coil pack or use an extension with a spark indicator on the coil output. It is the principle of watching the light timing VS the sound. Heck, put a paint mark on the crank pully and use a long screwdriver to listen and watch. Last edited by ls1ac; 04-12-2020 at 10:12 AM. |
#25 | |
Alright I did some more stuff. Took a rev video, a warm up video, and did some very effective screwdriver listening. Warm Up Revs I did put the screwdriver on the vaccume pump and you can clearly hear the tick through it. Weather or not it's the source not sure but you can also hear it deep in the center of the engine, on the top of the front of the engine under the intake manifold. Could just be the normal sound I suppose people talk about with these engines. I always thought it was the right side but when my mechanic looked at it he was pretty sure the source was passenger side back. I also tried the timing light with my phone and an app but it wasn't quite lining up with the mark. |
#26 |
chicken tonight
Textbook vacuum pump failure. Did you find the relevant section in the service manual? It's in an odd place.
![]() https://demos.starbase7.net/t3Portal...0159C017X.html
The Following User Says Thank You to Ultramaroon For This Useful Post: | Spuds (04-18-2020) |
#27 | |
I was actually gonna ask, was looking through it and didn't see it. THANK YOU for the help I'm really thinking this is it. My brake pedal is also a rock and sounds like that's another symptom. I'm ordering the part and I'll install when I get it and definitely update |
#28 | |
chicken tonight
...but you should do the engine swap just to be sure. ![]()
The Following User Says Thank You to Ultramaroon For This Useful Post: | BRZ Guy (04-15-2020) |
Tags |
bearing, broke, engine, knocking, motor |
Rocker arm broke and broke my valve cover... | j0hnnykthx | Issues | Warranty | Recalls / TSB | 9 | 08-07-2020 08:12 AM |
Need advice, dealership says I need new engine | spdsk8race | Issues | Warranty | Recalls / TSB | 22 | 04-11-2018 02:23 PM |
Need some advice on engine guys! | dsteezy86 | Northern California | 23 | 01-19-2017 07:33 AM |
Engine noise... advice? | hyperpunx | Issues | Warranty | Recalls / TSB | 8 | 09-28-2012 12:57 PM |
