Old 03-16-2020, 06:28 AM   #239
SuperTom
SuperTom's Avatar
Drives: C5, GT-86, '24 Colorado TrailBoss
Originally Posted by WC-BRZ View Post
Any shots of the smooth underbody and how it meets with the rear splitter?
Actually, how about shots of the entire car now that you've put on the SARD wing?
Thanks for you interest both are a work in progress. Im still making the parts underneath. If work shuts down in the next week or so ill have enough time.
Ill take a full shot of car after I get the CF upfront all polished!
SuperTom is offline   Reply With Quote
The Following User Says Thank You to SuperTom For This Useful Post:
WC-BRZ (03-16-2020)
Old 03-24-2020, 05:58 PM   #240
SuperTom
SuperTom's Avatar
Well got some good progress with my underbody plates. I want to split this up into 2 parts. These are made of coroplast which is cheap, lightweight, readily available. Durability and heat resistance will be issues but hey this is a fun Coronavirus lockdown project.
PART 1 - is the plate connected the front of the diffuser which extends past the gas tank and uses the 4 gas tank strap bolts for extra support.
Here is my template. The center is 2 pieces riveted together for strength
Doesn't come out too heavy at 4.5 lbs.
Here are the brackets I made with aluminum heating and bending them on a vice.
Here is how the brackets are used with a black push clip in the bottom
Here is the initial connection to the Velox diffuser. You can see there is a hole from their setup
Riveted in a hole cover
Added aluminum rivnuts to holes that were already on the car
Bolted down with fender washers
So the main issue is that the center will eventually melt. When that happens I will add extra support around the hole.
Pic of some the connections points
Total weight added 4.75lbs
PART 2 making a whole center body plate.
This was easier as it only needed to be a large square. And I only used one layer since there was plenty of connection points underneath
Weight - comes in at 2.5 lbs, Ill say 2.75 with the added fender washers. But also lost 1.5lbs removing the stock plate from the factory. So a net gain in the middle of only 1.25lbs
Connected and overlapping the rear piece
Tried to get a pic from the rear to the front
Pic from front to rear. Will still be connected this middle plate all the way up to the front bumper so haven't used all front connection points
PART 3 will continue on Friday since it will be raining tomorrow.
I already cut out the center of the factory aluminum skid plate and replaced with coroplast. This is not only lighter but gives me easier connection points to the front plate I will be making and also flatter.
Stock Plate weight 4.75lb
New weight 3.25lbs
Underside black was some spraypaint test
Old 03-25-2020, 09:48 PM   #241
iDetail
Drives: AE86
Insane attention to detail. Following.
We come to your house and detail your car to perfection! iDetail - Mobile Car Detailing Toronto
iDetail is offline   Reply With Quote
The Following User Says Thank You to iDetail For This Useful Post:
SuperTom (03-27-2020)
Old 03-27-2020, 12:52 PM   #242
SuperTom
SuperTom's Avatar
Car Gods were on my side today! Deciding while I had the skid plate off I would attempt to install my Perrin Motor Mounts. It was the last thing I bought before the apocalypse was announced. I delayed doing this because I heard people had issues either having to take off their headers or removing the steering rack just to install these.
I had ZERO problems at all. Only thing I did extra was take off the bolt connecting the front pipe to the transmission mount.
I cut a 5" square of wood and simply jacked it up from the oil pan about 2-3".
While under there found my FP to Overpipe bolt had backed all the way out.
With the ace headers the driver side mount came out from the front, the passenger side came out from the back Easily!
These suckers weight 6lbs
Heres the Perrin mounts, 4lbs with all the hardware.
I know everyone is going to ask about NVH. I haven't driven yet since I still have the front in the air. But I did start it up and didn't notice too much more. I had solid mounts before on other cars that could make your teeth rattle. Plus I Save 2lbs of weight off the front!!
Back down to 2350.5lbs !
why? (04-06-2020)
Old 03-27-2020, 02:34 PM   #243
new2subaru
Weight Weenie
Drives: 15 FR-S
That's not a place I even considered dropping weight. Thnaks, Tom!
The Following User Says Thank You to new2subaru For This Useful Post:
Old 04-05-2020, 04:22 PM   #244
SuperTom
SuperTom's Avatar
So im finished for the most part with the whole flat panel underbody project I just finished the front after some heat testing.
To recap with weight changes for the front
Original Skid plate converted to Coroplast saved -1.5lbs
Split the front into 2 panels with a combined weight of 1.75lbs
First heat run of 30 minute spirited drive the clips in the header area did not hold due to distortion of the coroplast. So I added some aluminum strips to use as mounting points
with some hardware im going to up estimate the weight to .75lbs
All done
Finished up front and total car. I may at some point consider a non aggressive splitter but it may not be necessary. Most look very heavy. Carbon fiber one from APR could be a winner and looks damn good https://aprperformance.com/2017_gt-86_brz/
So lost 1.5 lbs on the coroplast skid plate, added in 2.5lbs with the new plates and aluminum mounting. So only a 1lb gain up front
Putting me back up to 2351.5 LBS
EDIT 5/12: Forgot to weight the fiberglass stock cover came in at 1lb. So This section of the aero up front didn't gain any Weight
Last edited by SuperTom; 05-12-2020 at 11:00 AM. Reason: Forgot Weight Stock Fiberglass undertray
q335r49 (04-06-2020)
Old 04-05-2020, 04:30 PM   #245
SuperTom
SuperTom's Avatar
Now that im done with underbody paneling I also started the process of shining up the Seibon Dry carbon parts. I got the passenger door done today so here is a teaser. And you can see the comparison of it up against the fender.
Im mainly just wetsanding with 1000, 1500, 2000, then compound and wax.
Old 04-08-2020, 02:10 PM   #246
SuperTom
SuperTom's Avatar
got all the Dry/Matte CF wetsanded and polished. Im going to go back and readjust things to line up better before taking "glamour Shots"
Wetsanded clearcoat drying up
Finished hood
Old 04-08-2020, 03:16 PM   #247
SuperTom
SuperTom's Avatar
Also made my own TRD "STYLE" trunk aero stabilizer. From a piece of fender rubber moulding left over from a project on my Pathfinder that tapers from low to high
Cost ~$10 compared to $200 for real TRD
Did gain a 1lb of weight though but should at least block all the grime from getting into the trunk lid area and stop air from going into the trunk area
JD001 (04-10-2020)
Old 04-09-2020, 08:15 AM   #248
StraightOuttaCanadaEh
Wes
Ha! Awesome
Instagram: @gt86ws
The Following User Says Thank You to StraightOuttaCanadaEh For This Useful Post:
SuperTom (04-09-2020)
Old 04-10-2020, 10:24 AM   #249
Westen86
Purist
Westen86's Avatar
Drives: 2013 FRS - Hot Lava
It looks perfect! Need more info on what you used.
WTB: Everything Verus
RaceComp SS-1, Complete SuperPro bushings, TR Motorsport FF10 17x9 +45, GruppeS UEL, HKS Hi-Power V2, OFT(93/E85)
Westen86 is offline   Reply With Quote
Old 04-10-2020, 10:39 AM   #250
JD001
JD001's Avatar
Drives: Subaru BRZ
Don't forget don't your dust pan, it's sitting on your parcel shelf...
Old 04-10-2020, 07:07 PM   #251
SuperTom
SuperTom's Avatar
This is what I had ordered. you only need one roll if you can find it sold that way
https://www.aliexpress.com/item/3295...27424c4dHEw1Qh
The Following 2 Users Say Thank You to SuperTom For This Useful Post:
ichitaka05 (04-16-2020), scottman (04-12-2020)
Old 04-14-2020, 01:10 PM   #252
ML
ML's Avatar
Drives: 13 White MT FR-S
Have you driven it with the under body panels? I was going to do the exact same thing but I thought the exhaust would melt it almost immediately.
mothespaceman: 14' Satin White BRZ Build! mothespaceman Member's Car Journals 25 09-19-2014 05:30 PM
White BRZ Limited Build Thread NoFlush Member's Car Journals 4 05-10-2014 02:04 PM
white trd 2013 build Pcharliep04 Member's Car Journals 0 04-24-2014 01:25 AM
Build-thread White Wasp FR-S by Mit_Peid mit_peid Member's Car Journals 7 01-05-2014 07:47 PM
White GT manual Jan Build availlable 86•BRZ AUSTRALIA 2 01-01-2013 11:45 PM
