#43 |
Drives: FRS(sold), AP2, R35, FJC, ED9
OK so if I'm at -1.6 degree with 1/16 toe in per side for the street. Going to -2.6 at the track will net almost zero toe. Have to try this and see if I can get a good measurement off the rim without putting it on the alignment rack. Thx
| The Following User Says Thank You to garfull For This Useful Post: | CSG Mike (07-24-2013) |
#44 |
Drives: Hydra EMS Powered FRS Raven Black
I'm starting to second guess my statement based on my pic here:
![]() Somebody better double check the toe change with camber. I think I'm mixed up with my STi which has tie rods in front of axle and negative camber equals more toe out. The FRS has tie rods in rear so negative camber equals more toe in. My own picture supports that. |
#45 | |
#46 |
Yeah and look at my strut top, there is a huge change in toe with camber (1/8th"). Car needs a bump steer kit!
#47 |
Drives: Toyota GTS 86
Thank you to everyone who contributed to this thread - I've found it very useful. Give me some time (6 weeks or so) and I'll report back with some accurate numbers about camber/caster changes.
2013 Toyota 86: 275rwkW
Coyoda Water-to-air Intercooled Turbo with GTX2863. CP Carillo Rods and Pistons. Motec M150 ECU. Motec C125 Dash. Holinger SG 6 Speed Sequential Gearbox. OS Giken LSD. MCA Reds Coilover. AP Racing Essex Sprint Front Brakes. PWR Radiator and Intercooler heat exchanger. |
#48 |
Drives: Mazda 3
Thanks @FastLane1000 for being thorough and pointing out to me that the part number I provided for the 14mm lower bolt was wrong. I've corrected the original post and will include the correct part # here:
14mm bolt: 81260 SPC EZ Cam XR Camber Bolt Kit |
| The Following User Says Thank You to autobrz For This Useful Post: | FastLane1000 (07-27-2013) |
#49 |
Drives: White FR-S, 6M
no problem bro! I appreciate your help and getting me the right part number and more negative camber on the cheap!
| The Following User Says Thank You to FastLane1000 For This Useful Post: | autobrz (07-27-2013) |
#50 |
Dirt Trackin'
Drives: '13 Raven FR-S MT
So we know more negative camber = more toe IN (approximately -1.0 degree for 1/16" toe in on each wheel). Do we know how many turns on the stock tie rod it takes to toe one of the wheels in or out 1/16" ????
#51 |
Troll Level: Expert
Drives: '13 BRZ, '18 F150 3.5EB, '07 Cayman
Bump. This. Need to know nao
Nick K.
NASA ST5/TT5 #130 Southeast Region |
| The Following User Says Thank You to forwallblakmail For This Useful Post: | smg1138 (04-08-2020) |
#52 |
Drives: 2019 BRZ
#53 |
Drives: unlimited cheap build N/A track car
Im not sure how many turns it takes, but if you sight down the outside edges of the front tires and see how they line up in relation to the rear tires, you can re adjust them after a camber change quite accurately.
#54 | ||
Drives: Miata
If you're setting lap records... I'm impressed. Quote:
There's always the old string alignment.
| The Following User Says Thank You to racingfool For This Useful Post: | CSG Mike (04-13-2020) |
| Adjustable Camber Arms vs. Whiteline Camber Bushings | digital_assassin | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 70 | 06-02-2013 06:06 AM |
| Question about adjustable LCA's vs Camber Plates vs Camber Bolts | djdnz | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 13 | 03-27-2013 11:38 PM |
| Who's tracking their BRZ? | random hero | BRZ First-Gen (2012+) — General Topics | 11 | 08-20-2012 10:30 PM |
