Old 04-05-2020, 05:31 PM   #68349
what ducting does it have? i assume you don't have any makeup air coming in?
Mine is ducted to the outside (through the roof). Yep, all the ducting is clear. I crack a kitchen window for makeup air.
humfrz is offline
Old 04-05-2020, 05:46 PM   #68350
When we did our kitchen remodel two years ago, I insisted the microwave NOT be over the stove for this very reason. We ducted the stove through an outside wall, out the garage, through a 6 inch duct. It works pretty well, but that isn't going to solve smell problems if you cook something particularly fragrant. That would require an industrial level fan and maybe a booth.
Dadhawk is offline
The Following 4 Users Say Thank You to Dadhawk For This Useful Post:
humfrz (04-05-2020), korhun (04-06-2020), soundman98 (04-05-2020), Ultramaroon (04-05-2020)
Old 04-05-2020, 05:54 PM   #68351
soundman98
ProCrastinationConsultant
soundman98's Avatar
I'm in for a pound on this. Will vent to outside. Studying WA state residential code now.
I expect it to have the capacity to suck the smoke from a full-on oven catastrophe.
i usually come in after the homeowners pick a model that looks pretty. then i just follow the manual, which gives ducting and electrical requirements, as well as finished mounting heights and clearances to the range top.
the big models all require a 6" duct with as few bends as possible, and usually have a trigger output of some sort to go to a makeup air vent that's installed on the other side of the kitchen-- usually just a electrically powered 3-6" ducting shutter.
and then i tell them that they can't fit a 40" hood in a 36" space, they get angry that no one brought it up before, and i offer them my sawzall.
soundman98 is offline
humfrz (04-05-2020)
Old 04-05-2020, 06:37 PM   #68352
Yep, something like this, 24" whole house fan, installed in the ceiling or wall of the kitchen would take care of even burnt up food smells.
humfrz is offline
korhun (04-06-2020), Ultramaroon (04-05-2020)
Old 04-05-2020, 06:39 PM   #68353
We have the one that my wife picked. It looks pretty. I'll have to either go through or remove the overhead cabinet. I'm hoping to keep the hood and light fixture because it's matchy-matchy.
I plan on being able to move a LOT of air with it wide open, enough to need an open window for full effect. I know that it will be loud because of the small cross sectional area.
Ultramaroon is offline
humfrz (04-05-2020)
Old 04-05-2020, 06:54 PM   #68354
To stay in line with the matchy-matchy thing and if that's an outside wall, you could mount a whole house fan in the space behind the cabinet doors, then just open the doors when it is turned on.
humfrz is offline
Old 04-05-2020, 07:40 PM   #68355
hmmmm
humfrz is offline
The Following 5 Users Say Thank You to humfrz For This Useful Post:
Boomerang (04-05-2020), Dadhawk (04-05-2020), korhun (04-06-2020), Spuds (04-05-2020), Ultramaroon (04-05-2020)
Old 04-05-2020, 08:08 PM   #68356
Right there with you. The basement stairwell is behind that wall. but I was thinking if I can't put a big squirrel cage in the attic right over the cabinet, it can always go inside it.
humfrz (04-05-2020)
Old 04-05-2020, 08:19 PM   #68357
ls1ac
ls1ac's Avatar
As a side light, we found that a drawer microwave by Sharp worked really well and at lower counter height my wife was happy. (read short)
ls1ac is offline
Old 04-05-2020, 10:31 PM   #68358
Leonardo
Country Boy 4 Life
Leonardo's Avatar
My car won't start because the battery is dead. The news says 1/2" hail is falling just a few miles from my house. My window is open a bit because I opened the door. And, I can't find my battery charger right now...
On a positive note, I'm on day 12 of no smoking. I was actually able to get real sleep last night for the first time since I quit.
I LIKE TIRES!
Leonardo is offline
Old 04-05-2020, 11:15 PM   #68359
cjd
cjd's Avatar
Drives: 2017 BRZ
I want to install an effective exhaust over my kitchen range. Reaching out for some of that fam wisdom.
No microwave, no cabinet above it, allow plenty of space. If you can, 3" wider each side than the stove. Go to a specialty shop.
Old house had a 600cfm 30", was awesome till it started having issues. I could roast coffee inside. If we ever get back to normal and can again think of remodeling the kitchen... I can't wait. But need to...
cjd is offline
The Following User Says Thank You to cjd For This Useful Post:
Ultramaroon (04-06-2020)
Old 04-05-2020, 11:39 PM   #68360
soundman98
soundman98's Avatar
do you have significant problems with spilling hot liquid with those? that's always been my biggest concern.
but i seem to be clumsier than most.
Old 04-06-2020, 12:08 AM   #68361
mancini
Drives: toyota corolla
I feel confused..Do we have to move planet "Mars" to avoid this hell Virus "Corona"
mancini is offline
Old 04-06-2020, 03:22 AM   #68362
Captain Snooze
Because compromise ®
Captain Snooze's Avatar
Drives: Red Herring
How would moving Mars help. That's a lot of mass to shift around.
Captain Snooze is offline
soundman98 (04-06-2020)
