Old 01-15-2020, 04:44 PM   #85
tarzan_nojane
tarzan_nojane's Avatar
Drives: 2014 FR-S
3rd Brake Light Delete Fillers for FRS/BRZ/86 Rear Shelf
link
Finish it off with a new piece of dark gray felt from JoAnn Fabrics and some contact cement, then install the CDC 3rd Brake Light kit and up with this:
tarzan_nojane is offline   Reply With Quote
Old 01-16-2020, 02:28 PM   #86
spike021
spike021's Avatar
Anybody have a ceiling microphone housing cover replacement that fits the Pioneer unit cylindrical microphones?
Instagram: @spike.grc
spike021 is offline   Reply With Quote
Old 01-24-2020, 01:47 PM   #87
pudniskool
Drives: 2013 Scion FR-S Series 10 #1731
Id love one as well
pudniskool is offline   Reply With Quote
Old 01-24-2020, 04:28 PM   #88
tehShirt
tehShirt's Avatar
Drives: 2014 Subaru Forester
I'll make one and post it on here. I'll try and have it within a week.
tehShirt is offline   Reply With Quote
Old 01-25-2020, 12:50 AM   #89
gpvecchi
gpvecchi's Avatar
And One for Kenwood, plz!
Old 01-25-2020, 10:00 AM   #90
tehShirt
tehShirt's Avatar
If you can make a sketch of the Kenwood mic with dimensions, I'll make one too. It would help though if I had the Kenwood mic myself to test the fit.
There was a STL file linked on the forum for a JVC mic, in case the Kenwood is similar.
Old 01-25-2020, 11:09 AM   #91
daviddgaf21
daviddgaf21's Avatar
Drives: 2014 Scion FR-S
Someone should recreate the Toms Cupholder but for left hand drive cars. I would love you long time and pay you for one lol.
https://www.86worx.com/tom-s-cup-holders.html
daviddgaf21 is offline   Reply With Quote
Old 01-25-2020, 03:31 PM   #92
gpvecchi
gpvecchi's Avatar
Thanks, JVC and Kenwood should share the same mic, but the JVC sketch covers side holes of the microphone, this muffles the voice A LOT, making it useless...
Old 01-25-2020, 05:38 PM   #93
tehShirt
tehShirt's Avatar
If you have an idea of how you want the area around the mic to be, show me and I'll try to make it.
Old 03-09-2020, 12:54 AM   #94
BoozaB
Drives: 2012 Toyota 86 GT
If anyone is interested in the below I can send them the STL file for printing.
I have wanted to make use of the blanking plate on the 86 for a USB & microphone. Fitment is OEM flush. Only issue is the tabs on the item aren't as strong as the original unit as I couldn't built gussets to support them as space didn't permit.
The microphone is press fit into place - I used the supplied Sony microphone and took off the plastic shroud to reveal the microphone (6.5mm dia). I was concerned it wouldn't pick up my voice but on testing found it to pick my voice up really well.
The USB from the Sony XAV-5000 was inserted into socket and used super glue to keep it in place.
3D Printer - Creality Ender 3 Pro
Images below:
BoozaB is offline   Reply With Quote
Old 03-23-2020, 03:16 PM   #95
mrjj
Drives: GT86 2013
Phone mount compatible with Brodit holders
I installed a larger (8") head unit and a single piece dash trim so I needed to design a new phone mount.
I opted for adhesive / double sided tape for easy installation. I have not tried to remove it yet, but I hope it will be possible without leaving any marks.
I published the design here:
https://www.thingiverse.com/thing:4237813
mrjj is offline   Reply With Quote
Old 04-04-2020, 08:19 AM   #96
tehShirt
tehShirt's Avatar
Pioneer mic adapter
I attached a zip with the STL files for the Pioneer mic adapter I made. I have printed two of these now, one for myself and one for @spike021 on a luzbot mini in PLA. I was only able to test it with the mic style pictured. If you have the dimensions for other types I can modify my files for you.
There are three files, one male side, and two female sides. If your mic still has the ball on it, you can use the "with hole" option to retain the ball. If you have castrated the microphone, use the other side.
Old 04-04-2020, 10:55 AM   #97
gpvecchi
gpvecchi's Avatar
If you cover side holes of the microphone the sound will be muffled A LOT, they have to be left open. I have my mic under the grill, but with side holes open and it's perfect.
Old 04-04-2020, 11:30 AM   #98
tehShirt
tehShirt's Avatar
There is a little over 2.5mm gap between the walls and the mic side openings. The walls don't interfere with the capabilities, I tested to make sure before I finalized the design.
Official DTM Autobody Services Thread for FT86Club! DTMAUTOBODY Southern California 9 12-31-2013 02:09 PM
Official FT86Club Chatroom? wrxgoose Site Announcements / Questions / Issues 13 09-15-2012 05:26 PM
Official FT86Club decal idea? Hanzo Scion FR-S / Toyota 86 GT86 General Forum 71 06-21-2012 08:09 PM
