Old 03-31-2020, 08:56 AM   #1
Milhouse86
Noob
Milhouse86's Avatar
Drives: 13' FRS, 13' F150, 17' A4, 69' 442
Engine rebuild
Well I had some family emergency stuff going on for the past few weeks so I have not had the opportunity to get bored quite yet. Things are finally settling down and its clear I do not have much work that I can get done for another month. I don't sit still well, it's why I have a few businesses, so I want to learn a new skill.
I blew my stock motor last fall. Was going to send it to @Element Tuning but with everything going on I am going to wait till I blow up the next one before I go full send. I already have done a good bit to the car and I am still a new track driver. So I was looking to toss a used motor in but I was waiting for the right time. Figured this summer.
So now I am thinking about braking my engine down and seeing what's what. If I go slow, document the entire process and take pics. Keep all parts together and in baggies. How hard can it be? I took a motor down to the bare block and put it back together when I was 18, but it was in a classroom and I have not done it sense.
My thought is if I just go slow and when I am done the worst case is I am NOT able to put it back together and I still just go buy a used motor.
What am I missing here? Bad idea?
Sent from my Pixel 4 XL using Tapatalk
-2013 FRS/Black (Motor Blown/Under Construction)
http://www.ft86club.com/forums/showthread.php?t=135599
-1979 Trans AM/Black (Sold) -1969 Olds 442/Orange with white racing stripes - 2017 Audi A4/Black
Milhouse86 is offline   Reply With Quote
Old 03-31-2020, 09:21 AM   #2
iluvfatchix
Drives: 2013 frs
It sounds like you don’t mind if you can’t put it back together. It would be a really good learning experience without the stress of messing something up and being SOL. I say SEND IT
iluvfatchix is offline   Reply With Quote
Old 03-31-2020, 09:48 AM   #3
Go for it. It is just an engine and they are all basicly the same. As you said just document as you go long.
Now, to more important matter tell us about the 442 in the background!
Old 03-31-2020, 10:11 AM   #4
Milhouse86
Noob
Milhouse86's Avatar
Right! I am normally always worried about messing up something I still need. This seems perfect
Old 03-31-2020, 10:19 AM   #5
Milhouse86
Noob
Milhouse86's Avatar
Haha it's my dad and my project car from when I was in highschool. It's all numbers matching and I found the original build sheet on the car when we pulled the gas tank.
We pulled the motor and had it rebuild, balanced yada yada. It's got an RV cam, hooker headers, full 2.5 inch exhaust I made on a buddy's mandrel bender, vortex mufflers, Edelbrock intake, berry Grant speed demon 650 carb. Springs from a Olds Hurst for the rear end to keep dog walking to a minimum when you launch it. It's fun and sounds amazing.
It's for "sale" if anyone is interested lol
Old 04-01-2020, 03:33 PM   #6
PenGun
Drives: Red 2019 Subaru BRZ
Memories. My 69 Cutlass had a 502 I put in it. Factory crate motor making 480 hp and 560 ft/lbs. Great fun but hard on the Gatorbacks.
PenGun is offline   Reply With Quote
Old 04-01-2020, 06:42 PM   #7
ls1ac
ls1ac's Avatar
As said go for it. You have the space and now the time and not your only transportation.
When you get it apart you will have a greater knowledge and only time invested. If block is ok then a rebuilder can put it back together if you are not felling like it. (just do not expect them to discount the build because you took it a part.)
Old 04-01-2020, 06:57 PM   #8
Milhouse86
Noob
Milhouse86's Avatar
Haha come on man I did half the work!!! Jkjkjk
Yah I run a business, wouldn't try to pull that bs.
Ok so does anyone know what of any specialty tools I may need? I would assume not till re assembly but idk.
Old 04-01-2020, 07:13 PM   #9
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
Your biggest challenge will be getting the timing cover off. Enjoy!
Old 04-01-2020, 07:14 PM   #10
Milhouse86
Noob
Milhouse86's Avatar
Mmm ok I'll watch that part of the videos carefully. Any tips? Any videos you particularly like?
Old 04-01-2020, 07:55 PM   #11
DarkPira7e
DarkPira7e's Avatar
It's just that the sealant is like super glue, you need to pry it off using the little tabs they give you with a prybar. I don't have any advice other than make sure it's in a very warm place to loosen the sealant!
Old 04-12-2020, 02:21 PM   #12
Milhouse86
Noob
Milhouse86's Avatar
Haha just pulled the bolts and started getting a good look at where we can pry carefully. Thanks for the heads up.. might try to heat it up a bit.
Old 04-12-2020, 02:22 PM   #13
Milhouse86
Noob
Milhouse86's Avatar
So I have not started looking but I found this during disassembly. What am I looking at and what happened? Looks like it burnt off...
Old 04-12-2020, 02:42 PM   #14
DarkPira7e
DarkPira7e's Avatar
The OCVs rust fast and those plastic ends break off super easily. I'm buying 4 new ones for my build and getting the covers for them from racer x Fab or perrin
Looking for Best Shop for Engine Rebuild lc300 CANADA 5 10-09-2019 05:11 PM
chance AC condenser getting damaged during engine rebuild? msaikhan Engine, Exhaust, Transmission 17 04-07-2019 01:01 PM
P0335 after engine rebuild Greg555 Issues | Warranty | Recalls / TSB 10 12-27-2017 11:32 PM
Engine won't start after rebuild septonb Engine, Exhaust, Transmission 7 05-26-2017 10:48 PM
For the engine rebuild gurus puma Engine, Exhaust, Transmission 9 09-08-2016 06:33 AM
