Old 03-31-2020, 06:18 AM   #1
gt7877
Drives: turbo frs
Question how to swap manual to auto
Dear
How and what I need to swap from manual to auto transmission??
I have 2014 manual FRS
But because of traffic it's hard for me
I need to swap
I don't want to swap whole car
Any idea
I have an salvage auto Scion here all parts available
But I would know what I have to change
Thnx
gt7877 is offline   Reply With Quote
Old 03-31-2020, 08:53 AM   #2
Originally Posted by gt7877 View Post
Dear
I need to swap
Any idea
Thnx
There is a lot to it.
I know you said you didn't want to swap the car but it will be considerably cheaper and easier in the long run.
Old 03-31-2020, 10:21 AM   #3
mrg666
pessimistic skeptic
mrg666's Avatar
^^ Agree
Dear
I need to swap
Any idea
Thnx
I would start with removing the automatic transmission while tracing all of the different harness, vacuum, coolant, oil connections to engine. After transferring transmission and making the extra harness connections, you will probably need to transfer pedal shifters and probably the ECU as well since AT has different software.
I haven't seen such a transplantation before. I would ask in the engine swap forum. They should know better. You can also ask @Opie and @Dave-ROR in their thread.
Old 03-31-2020, 10:53 AM   #4
Rabrooks
Rabrooks's Avatar
Drives: 2020 Subaru BRZ
You will need to swap the engine bay harness and the dash harness along with ecm and bcm and transmission ecm. Transcooler and piping and abs module. This will require removal of console and dash. Its pretty major. But if you have the time and parts its not hard on the brain
Rabrooks is offline   Reply With Quote
Old 03-31-2020, 12:18 PM   #5
StraightOuttaCanadaEh
Wes
Why is it hard? Do you pin the clutch while you're pulled over? Just put it into neutral and relax. I live in Toronto and even with our traffic I have no issues
Instagram: @gt86ws
Old 03-31-2020, 12:39 PM   #6
Ernest72
I agreed with this.
After reading a number of threads like this over the years, I would advise against it. Easier to return to stock, sell car, buy new car and put aftermarket parts on.
If you go with the switch you better like a project. Likely take some time and money. I personally hate wiring, so that alone would stop me.
I thought about doing this on my 04WRX except going auto to manual. After my research it was not worth the effort. Money better spent elsewhere.
Good luck.
Old 03-31-2020, 12:51 PM   #7
Why is it hard? Do you pin the clutch while you're pulled over? Just put it into neutral and relax. I live in Toronto and even with out traffic I have no issues
Wasn't gonna be the guy to say it but now that the cat is out of the bag...
Originally Posted by Ernest72 View Post
I agreed with this.
Good luck.
Everybody keeps talking about the electronics but there are several mechanical changes to the engine as well (i.e. the brake booster vacuum pump). Not just a matter of swapping trannys hooking up some wires and driving away.
Old 03-31-2020, 01:10 PM   #8
Milhouse86
Noob
Milhouse86's Avatar
Drives: 13' FRS, 13' F150, 17' A4, 69' 442
How much do you like wasting time? S*** it might be easier to fix up the salvage car depending on how bad it is lol. Sounds like you have two cars there.
Sent from my Pixel 4 XL using Tapatalk
-2013 FRS/Black (Motor Blown/Under Construction)
http://www.ft86club.com/forums/showthread.php?t=135599
-1979 Trans AM/Black (Sold) -1969 Olds 442/Orange with white racing stripes - 2017 Audi A4/Black
Milhouse86 is offline   Reply With Quote
Old 03-31-2020, 01:33 PM   #9
Wes
it seems to be the politically incorrect thing to say, but if you're sitting bumper to bumper and there's nowhere to go anyway, what's the point in always being ready to move? Plus the first time I got rear ended was the one time I took my eyes off the rear view mirror, as Murphy's law would have it. Wouldn't have made a difference if I had my foot on the clutch or not (iirc I was in an auto car anyway). The other time I got rear ended, the guy bent over to get something from the glovebox and the car crept into my bumper. I had nowhere to go and there was literally nothing I could do but wait for that thud. So I always put it into neutral and relax.
Instagram: @gt86ws
Old 03-31-2020, 01:51 PM   #10
new2subaru
Weight Weenie
Drives: 15 FR-S
This will give you an idea of whats involved.
http://www.ft86club.com/forums/showthread.php?p=3042965
I personally would not run away from it. I would not trade a car just to not do the get involved but that's me. It is a lot of screwing around. I can also afford for the car just to sit in case shit goes south and I have people I can lean on for help.
Old 03-31-2020, 02:28 PM   #11
gt7877
Drives: turbo frs
Thnx to all of you guys ❤️
Old 03-31-2020, 02:32 PM   #12
86TOYO2k17
Drives: 2017 toyota 86
Probably easier going mt swap to auto vs auto to mt. Especially if you have an auto to pull parts. If you can swap the engine, trans, driveshaft, ecu, tcu, wiring harness, brake booster, instrument cluster, and the entire gear selector and gear selector trim from the auto to the MT then should pretty do able.
Old 03-31-2020, 03:25 PM   #13
shiumai
shiumai's Avatar
Drives: 2013 DGM BRZ, 2020 C8 Corvette
Trade your manual with someone who has an auto who wants the more 'engaging' experience - can't hurt to inquire around
shiumai is offline   Reply With Quote
Old 03-31-2020, 06:46 PM   #14
86TOYO2k17
Looks like he’s turboed so probably doesn’t want to find someone who wants an “engaging” left foot with slower shifting.
How to: Manual Swap FRS/BRZ darthfrs DIY (Do-It-Yourself) Guides 15 12-06-2023 02:32 PM
Auto to Manual Transmission Swap MenoSkyz Engine, Exhaust, Transmission 20 03-16-2018 01:54 AM
Transmission swap: auto to manual... itdansharpe Engine, Exhaust, Transmission 39 02-12-2018 04:53 PM
Looking for Swap or trade 2013 86 gts manual to auto Xylon Australia Classifieds 0 12-16-2015 11:12 AM
SWP and WRB Limited/Manual, WRB Premium/Manual + SS Prem Auto available in Colorado huma BRZ First-Gen (2012+) — General Topics 15 06-14-2012 11:33 AM
