Old 03-29-2020, 10:23 PM   #1
beyondjv
Drives: 2015 Scion FR-S TRD
Smile NEED HELP WITH SPEC D HEADLIGHT INSTALLATIONS
So, i’ve recently bought some spec d headlights, because the ones that were currently in the car are cracked with water in them. With doing so, i wasn’t aware my frs had a 8 pin headlight harness. The Spec D headlights come with a 6 pin. Instead of cutting, splicing and rewiring these bad boys at a shop (i’m bad with wiring, first timer) i wanted to just plug and play. Then i could just t tap the spec d wires into where it’s needed. Where could i find some 8/6 pin headlight harness adapters that would fit ? I found a website which is strictly australia only and one on ebay, which seems a bit sketchy.
beyondjv is offline   Reply With Quote
8/6 pin headlight harness, brz, frs, spec d headlights
Spec-D headlight DRl Mod amngmac Cosmetic Modification (Interior/Exterior/Lighting) 4 01-30-2016 01:50 PM
WTB Spec D headlight mythhelios1 Want-To-Buy Requests 1 09-22-2015 04:42 PM
Spec d headlight. Chen Cosmetic Modification (Interior/Exterior/Lighting) 20 07-21-2015 03:10 AM
Spec-D Headlight Question iStanley Cosmetic Modification (Interior/Exterior/Lighting) 2 05-10-2014 06:44 AM
Disconnecting battery for installations i_4got Electronics | Audio | NAV | Infotainment 2 11-21-2012 01:04 AM
