Old 03-26-2020, 06:48 AM   #1
TokyoDrift
Drives: 2018 BRZ|Edelbrock E-Force E85
Smile Cold Air Intake on Edelbrock Supercharger for extra whine
Hi guys,
I have a 2018 Subaru BRZ with an Edelbrock E-Force Supercharger, Remark muffler delete, and ST coilovers. I got installed a while back. I am loving the additional power coming from the car, but I am dying for a loud whine from the supercharger. People have recommended me to get a cold air intake to increase the whining noise. Can anyone recommend an intake that would be compatible with my supercharger? Also, does the supercharger allow for these aftermarket intakes to be installed? I have been eyeing the Perrin CAI for a while but I am unsure what to buy because I'm scared it won't fit my car. Hopefully, some of you more experienced BRZ/FRS owners can tell me. Please if you have any advice on how I can increase the whine in this car let me know.
Thank you for your guys' time!
Last edited by TokyoDrift; 03-26-2020 at 07:04 AM. Reason: Didn’t feel right with my initial wording of what I wrote.
TokyoDrift is offline   Reply With Quote
Old 03-26-2020, 01:22 PM   #2
StraightOuttaCanadaEh
Wes
I would suggest you post this in the Edelbrock thread but the lack of whine is a good thing.
Instagram: @gt86ws
Old 04-04-2020, 05:12 PM   #3
shr133
shr133's Avatar
Drives: 2013 FRS
I don't think anyone make an intake for the Edelbrock... It still won't whine it's just too quite, that's the way it is.... Stealth mod...
Enkei TS9 18 X 8, Michelin Sport 4S 225 40 18, Flex Fuel, Edelbrock Supercharger, P & L header, Nameless front pipe, V1 cat back, Aluminum Driveshaft, pvc delete, med duck bill, KW V3, Whiteline 20 and 18 mm bars, Buddy Club and SPL control arms, Toe Arms, motor and trans mounts, Whiteline bushings, SHR stage II tune.
shr133 is offline   Reply With Quote
Old 04-04-2020, 05:38 PM   #4
Yoshoobaroo
TRACKBREAD
Yoshoobaroo's Avatar
The new TVS blowers don’t whine. There’s no way to make them louder because they don’t whine to begin with. The only SC for this car that whines is Sprintex.
Old 06-29-2021, 08:03 PM   #5
TripleTapHK
TripleTapHK's Avatar
Drives: 2016 Subaru BRZ Edelbrock Kit
Originally Posted by TokyoDrift View Post
People have recommended me to get a cold air intake to increase the whining noise.!
The Edelbrock intake is a cold air intake. In fact, the stock intake is also a cold air intake. The blower in these kits just don't make much noise and that's a good thing. It's more efficient. Changing the intake will not add sound that isn't there to begin with.
That being said, I am looking into different intake options just because I find the Edelbrock intake to be poorly designed from a maintenance and usability perspective. 8 bolts and washers, multiple worm gear clamps, and and a bunch of finagling just to clean out my air filter. I drive a decent amount of gravel roads so it gets dusty pretty quick.
TripleTapHK is offline   Reply With Quote
The Following 2 Users Say Thank You to TripleTapHK For This Useful Post:
dpfarr (07-11-2023), SOCON (02-22-2025)
Old 06-06-2022, 08:50 AM   #6
GPhilly
GPhilly's Avatar
Drives: 2020 Subaru BRZ (Edelbrock SC)
Did you find a solution to this? I installed my Edelbrock kit this past weekend and the socket head screws do not fit into the airbox. I have to use my hand to clamp the airbox (really hard!) together just to locate the thread. The fitment sucks, either its the supplied K&N filter or the way the airbox is molded, it doesn't fit together like all the tutorials/instructions. I not sure if its bad to not put all the screws in, because the plastic is literally warping...
GPhilly is offline   Reply With Quote
Old 06-08-2022, 07:21 PM   #7
apatel471
apatel471's Avatar
Drives: 2017 World Rally Blue BRZ
I had the same issue with mine and they ended up sending me an entirely new airbox since the original one was so misaligned and warped, but even with the new one, I had to really force the hardware into place. Although, It has been a year, and no issues with anything though.
apatel471 is offline   Reply With Quote
Old 07-07-2023, 06:18 PM   #8
bokehmon
Drives: 2014 DMG BRZ
The sealing grease is also very susceptible to pushing out of the little air filter channel and getting into the intake. i've cleaned my MAF 3-4 times at this point, and finally took the intake apart... it was definitely flinging grease into the intake and on the maf as it got hot.
bokehmon is offline   Reply With Quote
Old 07-08-2023, 06:50 PM   #9
Muskoka800
Drives: 2016 Scion FRS Release Series 2#439
You must have an early version of the kit. Edelbrock have since deleted the sealing grease from the air box process. I agree that those 8 nice stainless Allen caps crews are an issue as they are too short for easy installation. I simply went to a local industrial supply and purchased 8 (+2 spares) stainless hex bolts a few millimeter longer plus matching small flat washers. Boom! Problem solved for under $10.
Edelbrock S/C with CSG 94 & 91 maps
TRD Short Shifter, CTS-V/EvoX Brembos
Ohlin’s R&T Dampers, Hotchkis F/R Bars, Blox LCA & Toe Arms
235F/245R Conti ECS on TRD/Enkei wheels (street),
245/40 sq. ECF on 17x8 720Form GTF2 wheels (track)
Muskoka800 is offline   Reply With Quote
Old 07-09-2023, 05:14 PM   #10
Irace86.2.0
Irace86.2.0's Avatar
Drives: Q5 + BRZ + M796
Whine = less efficiency.
The Following User Says Thank You to Irace86.2.0 For This Useful Post:
CSG Mike (07-10-2023)
cold air intake, noise, supercharger, whine
Clutch whine during cold start take the cannoli Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 17 09-30-2023 03:09 PM
Supercharger whine too loud?? Olson1288 Forced Induction 20 06-05-2020 07:04 PM
Custom Jackson Racing Supercharger Cold Air Intake Setup CAI C38 C30 HKS Ram JRSC hirollaz Engine, Exhaust, Bolt-Ons 0 08-20-2018 08:34 PM
Edelbrock Supercharger air intake witness89 Want-To-Buy Requests 1 07-01-2018 01:24 AM
Innovate Supercharger/Perrin Cold Air Intake VroomVroom86 Engine, Exhaust, Transmission 9 06-03-2016 12:46 PM
