Old 03-22-2019, 03:42 PM   #29
RickyRacer
RickyRacer's Avatar
Drives: 13 FRS
i have the opposite problem...
No concerns opening / locking my doors with the key FOB electronically
but the door won't open with the manual key. no matter how much i wiggle, push, pull, turn left, turn right, grease, lube, nothing works. I tried both keys. Had to replace the battery before I could get back into my car..
now i walk around with a spare battery attached to my key chain because the physical key itself does not work on my door lol
RickyRacer is offline   Reply With Quote
Old 03-24-2020, 10:46 PM   #30
JohnJuan
JohnJuan's Avatar
Drives: 2013 FR-S, Hot Lava; 2012 Z1000 CBO
Originally Posted by InspGadgt View Post
I was able to figure out how to get the lock actuator out of the door without taking out the glass. But after examining the housing I couldn't find a way to safely take it apart to fix the motor so it looks like I'll be replacing the actuator as well. Any idea what the part number is? I've found used ones on e-bay but they don't list the part number and I'd like to try O'Reiley or Napa to see if I can get a remanufactured part.
Hey, I know it's been a minute, but how did you get it out without removing the glass?
JohnJuan is offline   Reply With Quote
Old 03-25-2020, 11:50 AM   #31
JohnJuan
JohnJuan's Avatar
Never mind. It slips right out behind the window rail.
I did disconnect the bar that connects to the outside by just dropping the latch down and pulling up a bit on the bar.
The Following User Says Thank You to JohnJuan For This Useful Post:
CokeSlap (07-12-2020)
Automatic Door Lock? LostSalad Cosmetic Modification (Interior/Exterior/Lighting) 22 01-24-2019 04:52 PM
best way to repair this door? edigeek Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 28 08-21-2016 12:05 AM
Lock door with fob while car is running? jhh3000 BRZ First-Gen (2012+) — General Topics 2 06-05-2014 01:04 AM
Door lock issue BRZ323 Scion FR-S / Toyota 86 GT86 General Forum 3 04-13-2014 11:07 PM
Request: Magnetic seat belt lock funbeatsfast DIY (Do-It-Yourself) Guides 3 03-15-2013 12:11 AM
