Old 03-21-2020, 04:34 AM   #1
jau
Drives: 2013 frs raven
rich idle deatschwerks 700cc injector
hey guys,
i have installed 700cc injector on my turbo frs. plugged in the data recommend from their website and im getting 13.8afr when idling and itll stable at target 14.7 afr after 30 seconds.
any idea how to limit the rich idle?
Thanks
Jau
jau is offline   Reply With Quote
Old 03-21-2020, 05:06 AM   #2
tomm.brz
Drives: brz 2017 hksv2
what did you write in the port injector scaling cc table?
what s your LTFT?
DarkPira7e (03-21-2020)
Old 03-21-2020, 12:32 PM   #3
jau
what s your LTFT?
i wrote 700cc/min initially and diabled back to 670cc/min. it makes the idle stabilized to target afr faster but seems not much effect when dial back further...
LTFT is 0
Old 03-21-2020, 03:20 PM   #4
tomm.brz
if LTFT has been disabled by you, then what is STFT during the rich phase?
a smaller value in the port scaling table will tend to richen up things
From the technical datasheet and the pressure at which PI run with, i would put AT LEAST 780cc/min
Did you modify PI% tables and injector latency table, and reduced cranking fuel?
Old 03-22-2020, 12:14 AM   #5
jau
The short term fuel trim is steady around 0 to +3%
i tried from 700cc/min to 650cc/min, the time it takes to return 14.7 from 13.8 has been shortened but when i dail it further down to 590cc.min, the time it takes remain the same.
should i go higher value instead of lower?
what is the fuel pressure in Frs?
i did modify all the latency, pi% table and reduced the crank fuel table as per the data sheet
Old 03-22-2020, 05:59 AM   #6
tomm.brz
it s about 55-58psi
Try with 750-780cc value
Old 03-22-2020, 06:31 AM   #7
tomm.brz
can you do a log starting it before cranking with ignition on?
Old 03-23-2020, 01:24 AM   #8
jau
attached log file. injector scale 650, it will take idle for about 30 seconds to get back to 14.7 afr after running the car.
FS: DeatschWerks 700cc Injectors mitim3 Engine, Exhaust, Bolt-Ons 3 11-08-2016 12:43 PM
Deatschwerks 700cc Injectors $250 Shipped calispec Engine, Exhaust, Bolt-Ons 9 03-10-2014 03:02 PM
