Old 03-20-2020, 02:13 PM   #5363
CSG Mike
CSG Mike's Avatar
Originally Posted by jacjac3 View Post
Thanks for the info. I already have a JR oil cooler installed. I'm worried about the coolant temps. I've heard they can rise to 240F+. How high are your water temps on track?
There's something else going on if coolant temps get that high.
Check out your local track population for evidence; you have a great resource in 86CUP.
jacjac3 (03-20-2020)
Old 03-20-2020, 04:48 PM   #5364
mistople
mistople's Avatar
Drives: 2017 BRZ (Sold), 2023 GR86
Well everyone, it was (mostly) fun while it lasted. Back to NA + A350. I'll be putting up a lightly used JRSC C30 kit shortly if there's any interest.
mistople is offline   Reply With Quote
The Following 2 Users Say Thank You to mistople For This Useful Post:
CSG Mike (03-22-2020), HaXx (03-22-2020)
Old 03-21-2020, 02:34 PM   #5365
mrg666
pessimistic skeptic
mrg666's Avatar
It is your decision and good luck to you. But I can never imagine my car without JRSC. I would keep JRSC and use the factory tune, throw everything else away.
The Following User Says Thank You to mrg666 For This Useful Post:
Old 03-21-2020, 07:22 PM   #5366
mrg666
pessimistic skeptic
mrg666's Avatar
Has anybody replaced the mass air flow extension cable? Are there any recommendations?
Edit: Found here
https://www.bmotorsports.com/shop/pr...d/3307%7B2%7D5
sroby (03-22-2020)
Old 03-22-2020, 11:48 AM   #5367
steved
Drives: 2013 FRS
Depends on how many overheating issues you're having, and how successful you've been at overcoming them I'd say.
Like mistople my car is primarily for the track and as a track car if you can only get in a few hot laps before you hit north of 260F oil temps the entire purpose of the JRSC is moot.
I'm about a half step behind mistople, except I won't be keeping the car if it happens - the tracks I frequent are too large to be running a car with 200 hp so I'll be getting rid of it.
steved is offline   Reply With Quote
The Following User Says Thank You to steved For This Useful Post:
mistople (03-22-2020)
Old 03-22-2020, 03:45 PM   #5368
mrg666
pessimistic skeptic
mrg666's Avatar
Heat problems with even unmodified cars are also known on track like Corvette and Camaro. Check Speed Academy videos, they had very similar heat issues you have mentioned with their JRSC FRS. They found that the location of the heat sensor was not ideal for reading the temperature under racing conditions. They resolved the heat problem and ran a complete series of races and won in the end. You could also contact JR technical support to ask about their race cars. Good luck!
The Following 2 Users Say Thank You to mrg666 For This Useful Post:
CSG Mike (03-22-2020), new2subaru (03-22-2020)
Old 03-23-2020, 02:05 AM   #5369
steved
Drives: 2013 FRS
This isn't really directed at you personally but I've found a lot of these comments are a bit bs and are traded around pretty freely as fact:
-The speed academy guys were sponsored by JR, which ties their hands in making honest assessments (I enjoy their content, but they're a business)
- If I remember correctly their temp reading was inaccurate because they placed their sensor in a non optimal place, I'm picking up from obd2 and oil filter sandwich plate
- the speed academy guys run time attack-like sessions on a small track, sub 1:30 ( I used to live in Ontario and ran TMP many times) which doesn't correlate to temps on big momentum tracks or long sessions (20-30 min).
- the JR products are titled in a very misleading way which makes it easy to misunderstood their intended usage. ie: Track oil cooler, JRSC = insufficient cooling for most non-race track duty.
I was also going to add comments about some vendors who post in this thread for inaccurate and misleading information but it seems of little value to get into a flame war. My only real contribution I can make to this forum is to let others know how greatly this kit will let you down if you drive on track.
You can read through the last 3-5 pages and see anyone who tracks this car with a JRSC and an oil cooler built to JR spec and mounting location is having overheating issues and has to make some considerable changes to their bumper, air flow, and cooler mounting locations to get more then a few hot laps in, and most is fingers crossed best guess if there will be an improvement. Go read JR documentation and see if that's listed anywhere.
Old 03-23-2020, 11:54 AM   #5370
mrg666
pessimistic skeptic
mrg666's Avatar
To me, that is called track prep. It is not supposed to be easy, cheap, and quick. If you are not ready to solve those problems and even swap the engine at some point, racing should not be considered. In my opinion, you are failing not the kit. I am sure you can get upset with me but this is my opinion. I will not turn this thread into a flame show. So, good luck again.
Old 03-23-2020, 12:29 PM   #5371
mistople
mistople's Avatar
Old 03-23-2020, 09:21 PM   #5372
steved
Drives: 2013 FRS
Yikes.. I'm not getting upset with you, I just want people who read these comments in the future to know what they're getting themselves into.
1. Track prep in the context of lapping is pads, fluid, and tires, not cutting a bumper. Im prepared to, and have, been deeper into it, but track prep is not what it is.
2. I'm not racing, I attend lapping events
3. I never said it should be easy or quick, and it's definitely not cheap
4. It's a kit.. with one way to mount it. As in I paid JR for their engineering just like I paid KW for my coilovers.. and my suspension works as advertised.
Old 03-23-2020, 11:17 PM   #5373
wheelhaus
wheelhaus's Avatar
I’m a little surprised at the recent spike of overheating issues after this kit has been available for so many years. I was under the impression this was one of the only FI options that doesn’t overheat on track without extensive heat mitigation effort. What gives? Conspiracy theories aside, who here is *actually* pushing this kit under high stress for 20-30 minute sessions and achieving manageable temps?
Old 03-24-2020, 03:37 PM   #5374
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Define overheat though? Some people are under the impression that 260F oil temp is end of the world bad. I'd say if you are doing UOA's and they are coming back fine, and you are maintaining oil pressure at temp then what are you worrying about
Old 03-25-2020, 01:47 PM   #5375
mrg666
pessimistic skeptic
mrg666's Avatar
I would do the followings if I were trying to reduce the temperature on track.
- Check Oil pump working fine, are oil channels open, oil pressure okay
- Check coolant circulation, thermostat opening properly
- Sufficient air flowing through the radiator. Air guides behind the bumper cover installed properly
- Radiator upgrade and racing thermostat
- Install Oil cooler
- Install hood vents
- Get a proper tune. This does not mean the tune for highest power. The system can be too rich.
- Upgrade short block with better oil pump and widened oil channels
I know the last option is expensive and buying a different car can be considered instead. I might just buy a C7 Grand Sport instead.
Old 03-26-2020, 11:26 AM   #5376
AndreC
Drives: Fast track beast
I'll say this. I posted a few times over the last few years asking if anyone was having cooling issues running the JR kit for track use. Crickets.
Now, all of a sudden the data is coming out confirming my own experiences, which are probably finally now resolved but with extensive reworking to front end airflow, but unfortunately causing HG issues with both my engines before solved.
I've raced and chatted with Dave and Pete at Speed Academy and they have not had any overheating such as I have, but as mentioned they're also not running 30+ min races at full pin like I am.
So yes, extensive reworking is necessary to gain proper airflow through all cooling components and eliminate heat soak with the way the kit is set up.
I've now rebuilt my first engine, so maybe after all this Corona shit is done I can track test and confirm all overheating is behind me. I also have no plans to remove the JRSC unless I convert to an LS swap. Food for thought.
AndreC is offline   Reply With Quote
Jackson Racing Rotrex Supercharger System Info and Discussion Jackson Racing Forced Induction 827 04-06-2020 04:56 PM
Jackson Racing Supercharger Press Release and Info CounterSpace Garage Forced Induction 110 01-03-2017 09:04 PM
jackson Racing engine oil cooler - modular to fit the Jackson Racing Supercharger! CSG Mike Forced Induction 24 04-27-2016 12:59 PM
Jackson Racing supercharger NoppyNop Forced Induction 241 06-26-2014 03:05 PM
Jackson Racing Supercharger Pre-Order Sale, $200 off! Xero-Limit Forced Induction 2 03-05-2014 04:14 PM
