#29 | |
Drives: 2017 86 860 Special Edition
But, I still think this panel is just an overpriced piece of aluminum. |
#30 |
I think we are saying the same thing. Down force is both negative pressure under the car and wings or what ever over the car that produce a downward force. I was only talking about adding air under the car thus reducing the negative pressure.
The ground effect cars of the 70s with side skirts that touched the ground demonstrated how very important keeping air out from under the car was. |
#31 | |
Take a look at these advanced front splitters. Among other things, they have steps in the center to force more air into the under body of the vehicle. The secondary function is to stop the underbody from essentially "stalling" out or being choked of air flow if the front splitter bottoms out. Side skirts are used to reduce the amount of high pressure area on the side of the car from being sucked in under the car from the sides. Air flow under the car is at a low pressure, which causes the higher-pressure air on the outside and on the sides of the car to come rushing in diminishing ground effect and downforce. Basically they keep the low pressure region under the car "tunneled" and controlled until it can be effectively and smoothly evacuated from the rear diffuser. ![]() ![]() Maybe we understand the same principal, but saying air dams and skirts are for keeping air out from underneath the car is misleading at best and a gross over simplification. |
#32 | |
Drives: 2013 DGM BRZ, 2020 C8 Corvette
I'm still here! I'm still here! What are we debating?
My DGM BRZ vid: https://www.youtube.com/watch?v=0OL9OhxexAA
My car journal thread: http://www.ft86club.com/forums/showthread.php?t=43402 |
| The Following User Says Thank You to shiumai For This Useful Post: | Tcoat (03-19-2020) |
#33 |
I absolutely agree with grossss simplification. Channeling and bubble effect are a world away from the simple model.
{Wait till we get to trans sonic.} I still think we are on the same page about the low pressure area under the car. As you said The side skirts are there to keep air from getting under the car. Venting air to the underside is putting more air under the car. That was where I started. I will also say that a 120MPH car is much more forgiving than a 200MPH car. I was there when they first found that they had to weld the 160lb man hole covers down. |
#34 | |||
Drives: 2014 BRZ Limited
But it is an interesting discussion of aerodynamics: Quote:
| Beatrush / Laile frame brace | autoCAR | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 28 | 02-19-2016 02:08 PM |
| Dented rear wheel side panel/rocker panel. | Autocon | Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) | 19 | 12-22-2014 11:18 PM |
| Anyone tried the Laile intake? | dave77 | Engine, Exhaust, Transmission | 43 | 06-26-2014 03:12 PM |
| A little bit of Beatrush history (Laile) | Kami Speed | Groupbuys | 1 | 01-13-2014 11:11 AM |
| Laile Intake Kit | JimmyMac | Engine, Exhaust, Transmission | 1 | 08-25-2013 06:49 AM |
