Old 03-14-2020, 11:04 PM   #15
Mr Breeze
Drives: 2014 BRZ Limited, 2018 Crosstrek
Originally Posted by Alpha86 View Post
This is my first year I've ever run true snow tires - used Blizzak WS80s that still look great. From day 1 I've noticed they have a lot of wandering when accelerating moderately hard on dry pavement compared to the stock Potenza all-seasons. Is this normal just because of how soft the compound is? It gets slightly better the colder it is, and in the wet/snow its not noticeable. Thanks.
This was one of the reasons I replaced my Blizzaks with all season UHP tires. They ride and handle much better above 20 degrees than Blizzaks, and there are many days where those conditions are common where I live.
Mr Breeze is offline   Reply With Quote
Old 03-16-2020, 05:05 PM   #16
Ktse
Drives: 2017 BRZ WRB
Originally Posted by RayRay88 View Post
It's the WS80's, honestly some of the shittiest tires in dry/wet that I've ever had the displeasure of driving on. They're incredibly soft and the tire carcass itself is way too compliant for a chassis of this nature. I can literally hop into the next lane if I give the car more than 70% throttle in the dry.
Upside is they were amazing in the snow, but now on its almost 3rd season, the microcell/swiss cheese compound is all but gone and they're just horribly average.
Next year i'm going to try the Conti Wintercontact SI's.
I ran a new set of Contis this winter and I'll say that they are pretty soft in dry and temperatures above 0 celcius but great in the snow. In previous years, I used the first generation Michelin X ice which felt a little more solid in the dry but not as confident in the snow.
I'd argue that almost any tire that's really good in the snow will feel pretty sluggish in the dry since they will have softer compounds and more sipes to get more traction in the snow. The X Ices felt better in the dry because it has less sipes and a slightly harder compound in the cold. It's all a compromise.
Sent from my SM-G970W using Tapatalk
Ktse is offline   Reply With Quote
The Following User Says Thank You to Ktse For This Useful Post:
Tcoat (03-18-2020)
Old 03-18-2020, 12:20 PM   #17
Ernest72
It depends on the year. This year in NY with very little snow, all seasons would have been fine for me. But I like knowing that I can go anywhere during a blizzard with out issue. The sacrifice is a squishy feeling at 75mph and loss of turn in from soft tires. But I also have a BRZ with all seasons for good weather days. If global warming keeps up I might just go back to all seasons. Time will tell.
Old 03-18-2020, 12:57 PM   #18
ZDan
ZDan's Avatar
Drives: '23 BRZ
Pirelli Sottozero III are surprisingly good in warmish weather (dry or wet), and are quite responsive with stiff(ish) sidewalls. However they are not quite as good in snow as some of the better dedicated winters. But much better than all-seasons in that regard.
Old 03-18-2020, 01:52 PM   #19
venturaII
Only users lose drugs.
venturaII's Avatar
Drives: All the time
You don't know what wandering and slip angle are until you run dedicated snows with studs, and an aggressive alignment...lol. The car is f-ing hilarious to drive...
"To know a thing well, know it's limits. Only when pushed beyond its tolerances will true nature be seen." Amtal Rule
Old 03-18-2020, 02:27 PM   #20
RayRay88
Drives: 2017 86 860 Special Edition
It's the over all tire construction, it's just horrible. The car wanders over any road imperfection and violently lurches on any aggressive part throttle application. Dry performance is basically non existent. Like I said, now that the outer layer has worn down, snow performance is below average. I've had other winter tires that have been miles better and last much longer.
RayRay88 is offline   Reply With Quote
Old 03-18-2020, 05:19 PM   #21
This ^
Snow, AS, summer, performance, any tire no matter what cost!
Remove P4S tires from my stock BRZ PP wheels and mounting snow tires? jredders Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 9 10-26-2019 12:30 AM
Snow tires StarFox101 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 22 01-03-2017 09:41 PM
WTB: Snow tires TheDetailer718 Want-To-Buy Requests 0 11-22-2016 06:13 PM
Stay safe in snow 86ers. Don't go out with crap stock tires, only snow tires stockysnail Northwest 36 12-19-2013 02:12 PM
Snow tires? smbrm CANADA 12 05-27-2012 02:20 AM
