Old 03-18-2020, 10:00 AM   #15
tehShirt
tehShirt's Avatar
Drives: 2014 Subaru Forester
Originally Posted by jkwan View Post
From those instructions, it looks like that amp jumper is supposed to be used with this headunit. Maybe that's the reason the door speakers aren't working in the other thread?
tehShirt is offline   Reply With Quote
Old 03-18-2020, 12:10 PM   #16
jkwan
Drives: 86 TRD
Just guessing that cable might be related to aux functions which don't exist in the 2020?
jkwan is offline   Reply With Quote
Old 03-18-2020, 12:49 PM   #17
Terrymcfadd
Terrymcfadd's Avatar
Drives: 2020 86 Hakone Edition
Thank you for sharing!
Terrymcfadd is offline   Reply With Quote
Old 03-18-2020, 01:29 PM   #18
Terrymcfadd
Originally Posted by burgeralert View Post
One more question, how is the Apple Car Play on the OEM unit? I assume you have to have your iPhone plugged in to the input adjacent to the pocket for it to work. Thanks again.
Correct, Carplay for iPhone requires USB connection on this HU. Bluetooth will get you access to your music library, but not Carplay unlike some other full feature units.
The Following User Says Thank You to Terrymcfadd For This Useful Post:
burgeralert (03-18-2020)
Old 03-18-2020, 01:39 PM   #19
Bobharp
Bobharp's Avatar
Drives: 86 Hakone
Originally Posted by Bobharp View Post
That would explain a lot. Definitely missing bass.
- I suspect the AMP.
- I had cranked up the 'limited equalizer' to 5 also. Sure wish they had an 11.
- Hopefully we can push for an update.
- I took my 86 in to the dealership to have a look at this audio anomaly.
- It seems that those yellow wires and plug is an included accessory to bypass the amp. They just plugged it in.
- Hopefully the photos show as follows;
+ Bypass wire assembly
+ Head unit/speakers plugged into the amp
+ Head unit/speakers plugged into the bypass
+ Rich audio goodness with deep bass via Dire Straits
- So in summary - Just bypass the amp
Bobharp is offline   Reply With Quote
The Following 2 Users Say Thank You to Bobharp For This Useful Post:
etherdude (03-19-2020), johnowow (04-27-2023)
Old 03-18-2020, 03:28 PM   #20
FR-S2GT86
Master Collaborator
FR-S2GT86's Avatar
Looks like the “Mystery of the Silent Door Speakers” has been solved. And I highly suspect this is a dealer-caused problem and not a factory-caused problem for the simple fact that the installation instructions for the Harmon head unit are in english and not Japanese.
FR-S2GT86 is offline   Reply With Quote
The Following 2 Users Say Thank You to FR-S2GT86 For This Useful Post:
etherdude (03-19-2020), soundman98 (03-18-2020)
Old 03-19-2020, 08:13 PM   #21
MightySouvlaki
Drives: 2017 BRZ PP
My 2017 BRZ was in the same situation. Factory HU and no sound at all from the door speakers.
Bypassing the amp was worth trying but a quick search for Toyota amp plug part number PT296-18191 shows it selling for an insane $75-$95!
I ordered a Metra 70-1761 harness plug from Amazon for only $5. All you need to do is connect the harness wires then plug it in and enjoy surprisingly decent sound.
Thanks to all the contributors for providing the information, pinouts and pictures to make this a quick, easy, good enough solution.
MightySouvlaki is offline   Reply With Quote
The Following 3 Users Say Thank You to MightySouvlaki For This Useful Post:
Bobharp (03-20-2020), phm14 (04-23-2020), soundman98 (04-29-2020)
Old 03-30-2020, 03:35 PM   #22
vitriumGTS
Drives: 1986 Corolla GT-S Hatchback
Mighty good information provided by all here.
I was confident before a picture of the back of the head unit connectors was shown, but now its confirmed that this is basically (mostly) plug and play for not just older FR-S/86s, but any one who retrofitted older OEM units.
The 28pin connector is the microphone + steering wheel controls, the 24 pin connector was originally for rear camera. I wonder if it still works on older models with the proper harness adjustments?
I was starved for a proper OEM android solution and now I got it. Will update if and when I install
-Curtis
vitriumGTS is offline   Reply With Quote
Old 04-27-2020, 05:52 PM   #23
Bobharp
Bobharp's Avatar
Drives: 86 Hakone
Updatied the original post in this thread with some notes.
In summary - Toyota posted the manual for this head unit.
- Trying Android Auto after an app update.
Old 04-29-2020, 03:44 AM   #24
saltywetman
Drives: 2020 Toyota 86 GT 6M
boo, no flac support = I will likely stick with bluetooth connection rather than AA
saltywetman is offline   Reply With Quote
Old 04-29-2020, 09:46 AM   #25
Bobharp
Bobharp's Avatar
Drives: 86 Hakone
Yeah. FLAC is the best. It's what I use for audio at home LMS (https://forums.slimdevices.com/forum...h-Media-Server).
I don't mind mp3 for the car.
Android Auto's requirement for playback via Bluetooth is just plain crazy.
I'll will probably just go back to just Bluetooth.
I really wish the OEM unit had RCA input.
Still looking for the specifications of the unit.
Old 04-30-2020, 07:00 AM   #26
Wally86
Be Kind
Wally86's Avatar
Drives: 2020 86
Guess who got speakers in his 2020 86 on day 18? LOL
I think the best part is the connector for the speakers was zip tied to the harness. What a weird oversight by Toyobaru.
Thanks to you guys for making me look back there. I had been screwing with the EQ thinking something was horribly wrong with the system.
If someone doesn't have the connector and needs the metra connector listed above, let me know. I may have ordered it already and it might have already been on its way before I looked in my trunk so I have a free one.
[Insert clever signature here]
IG | WhiskyBlog | Photography
Wally86 is offline   Reply With Quote
Old 05-01-2020, 10:00 AM   #27
Bobharp
Bobharp's Avatar
Drives: 86 Hakone
Trying (in vain it seems) to get more details/specifications on the 2020 86 OEM head unit.
PN: pt296-18190-20
Looking for specs like peak output, touchscreen type, display contrast ratio, etc.
I reached out HarmanKardon support (harmankardon.com) and after a lengthy chat session I got nowhere. I related to them that it's incomprehensible that they don't have the information of a product they manufacture. I'm sure they do but are unwilling to provide them.
Anyway, they (HarmanKardon) said that the details would have to be supplied by Toyota.
The manual for the unit (linked in the fist post) does not contain specs.
I hope to get out this weekend to run some 'critical errands' and get some more 'Android Auto' testing in.
Old 05-01-2020, 10:31 PM   #28
soundman98
ProCrastinationConsultant
soundman98's Avatar
not surprising they don't have specs. most oem radio's don't.
audio, head unit double din, mp3, stereo, usb port
2020 86 TRD info? Vr4gasmtt Scion FR-S / Toyota 86 GT86 General Forum 18 08-27-2019 02:41 PM
Android based stereo vs. stereo w/ Android auto redlined600 Electronics | Audio | NAV | Infotainment 12 02-24-2019 02:53 AM
2013 BRZ Nav Stereo For 2016 BRZ Starlink Stereo brzsubarusti13 Audio/Visual, Electronics, Infotainment, NAV 11 02-27-2016 06:33 AM
Stock FRS stereo on Toyota 86 - Wiring problem position lights turn on/off the stereo dssence Electronics | Audio | NAV | Infotainment 0 01-27-2015 06:43 PM
