Drives: 2014 DGM BRZ 6MT
BRZ with TRD Lowering Springs
Hi all--
Have a '14 BRZ and am strongly considering TRD lowering springs (a la my dealership, just to avoid any headache). The reviews seem strong, anyone have these springs on a BRZ? Would love to see how they look with the Subie's lines. Also, if anyone has had them put on by their dealership, mind sharing approx. how much labor was? Just curious. Thanks! |
#2 |
Drives: 2014 Scion FRS
#3 |
Drives: 2014 BRZ - 2004 GLI
At the dealer, it will vary from $400-600 to put them on. (Including alignment)
#4 | |
Indulgent Tormenter
Drives: 15' LTD Subaru BRZ DGM
Instagram: Gabe.it.the.ole.college.try |
| The Following User Says Thank You to ShadowReaper For This Useful Post: | Plumbus (06-13-2020) |
#5 | |
[insert cool phrase here]
Drives: BRZ Premium
Google could have saved you all this time waiting for a response. 99.9% of BRZ and frs/86 parts are interchangeable. Any idiot with a wrench can install lowering springs. Seriously just YouTube it. All the info is out there. Hell if you don't have tools, rent them at most auto part stores. Given the proper work space, it's a 3-4 hour job with a buddy and a beer in one hand.
Weekend fun/track car - '91 MR2 Turbo Gen3 Old daily driver - '88 MR2 Supercharged |
#6 |
Drives: 2014 GT86
Idiot with wrench won't be able to do proper alignment, which is needed after such work on suspension taking struts out to change springs and also due toe & camber changes from lowering. While DIY alignment is possible, still extra tools for that are needed, outside just wrench scope, and it's major PITA and takes lot of time (even more so if done for first time), making it sense to do alignment in shop with proper alignment rig. And if so, maybe it's simpler/quicker to do spring change there too. Though i'd probably would go for good reputation suspension shop then to dealership, to save on costs and possibly have better quality work (especially if i want non-OE alignment and have non-OE other suspension parts).
#7 |
Drives: '13 FRS - STX
tolerances are very tight unless you have a fucked up car, geometry change up front will be negligible, rear will add some negative camber and toe in, neither will be problematic, I wouldn't hesitate to slap lowering springs onto this chassis as a monkey and let it ride
~I've disassembled and reassembled my suspension probably 20 times on this car, mark any adjustable parts on the car if you're touching them, put them back where they came from (protip; factory stock you don't have anything adjustable to change on you) Edit: applause to mr.ac, yelling at a post from 5 years ago, go get 'em champ |
#8 |
bruh
Drives: Raven 2015 FRS
FWIW I'd recommend RCE Yellows. They match the stock dampers better than any other lowering spring I've seen. You can take them to a shop if you don't want to put them in yourself.
| Tags |
| brz, fr-s, lowering springs, trd |
| TRD lowering springs | LordTaikun | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 68 | 01-29-2017 01:03 PM |
| which lowering springs should I get? | abling2 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 11 | 05-22-2013 03:27 PM |
| For those with lowering springs. | wawro569 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 9 | 03-10-2013 02:36 PM |
| RS*R Lowering Springs Soon to be out! | tintumz22 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 7 | 01-16-2013 03:39 PM |
| Lowering springs? | Jeff Lange | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 12 | 06-11-2012 12:36 AM |
