Old 03-15-2020, 02:34 PM   #67621
JD001
JD001's Avatar
Drives: Subaru BRZ
Looking back on limited edition 86/BRZ. We had more than 20... if you count worldwide. That’s pretty good rec, I think.
The standard run of UK BRZs probably are more "limited" then any of the ones pictured..
JD001 is offline
The Following User Says Thank You to JD001 For This Useful Post:
ichitaka05 (03-15-2020)
Old 03-15-2020, 03:13 PM   #67622
ichitaka05
Site Moderator
ichitaka05's Avatar
Drives: ichi 86 Project
Originally Posted by Clutch Dog View Post
We have some pretty cool ones. and in classic scion branding those limited editions where way cool.
Im still upset that as far as subaru based we didnt get an "S209" or something special package. the highest performance we got was a BRZ TS, which I guess can be akin to the 14R scion.
I also wish the hakone came with the performance package. that woulda been rad.
( says the guy who bought two white 86s...)
Yeah, in Japan it came with it. The guy who was in charge to bring it US said "at least it comes with arm rest." SMH
UK had CS V-3 right? Sadly US never came with those cool ones.
ichitaka05 is offline
The Following 2 Users Say Thank You to ichitaka05 For This Useful Post:
Clutch Dog (03-15-2020), korhun (03-16-2020)
Old 03-15-2020, 03:18 PM   #67623
JD001
JD001's Avatar
Drives: Subaru BRZ
No, I'm talking about the standard BRZ models. When I last looked about 800units had been sold since release date. The GT86 is a different story as they have sold a lot more.. This was due to an agreement between Toyota and Subaru..
JD001 is offline
Old 03-15-2020, 04:13 PM   #67624
All depends on how you plan to use it I guess. I do not need nor want big brakes or performance struts. If the Hakone had the option of getting it with or without them I would go without. For a daily driver street car that will never make use of them it is just costly bling.
Tcoat is offline
humfrz (03-15-2020), Ultramaroon (03-15-2020)
Old 03-15-2020, 05:19 PM   #67625
I am going to cut this one apart carefully and see if I can see what type of failure it is. Could be contamination, grease breakdown from heat, or just wear.
All it takes is one good smack to peen a race. Then it's just a matter of time. Do you have camber plates or anything that could feed a metal-to-metal shock back into the hub. I agree that it is really strange.
Ultramaroon is offline
Old 03-15-2020, 05:33 PM   #67626
I've just started watching the first episode of this. It has made me laugh a couple of times. A show that makes me laugh has to get high ratings from me.
Senior Person: "What made you answer the phone?"
Junior: "Well, the phone was ringing and...I picked it up."
Senior Person: "Your logic escapes me."
American guy: [...blah blah] decredite.
French guy: Discredite.
Old 03-15-2020, 06:42 PM   #67627
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Yes, I do. But my setup up until recently was pretty standard autoX/track setup.
NoHaveMSG is offline
Old 03-15-2020, 08:39 PM   #67628
Are your spherical bearings in good shape? Tight?
Every morning I cross like 10 expansion joints on the Columbia bridge. The concrete in the wheel tracks is eroded at the the joints leaving a sharp transition. I am glad to have elastomeric top hats.
Old 03-15-2020, 11:37 PM   #67629
I would gain too much weight.
But, look how happy you would be -
humfrz is offline
korhun (03-16-2020)
Old 03-15-2020, 11:44 PM   #67630
Saw a twin yesterday. I think that makes 4 now.
I see - a twin in Idaho -
humfrz is offline
The Following 4 Users Say Thank You to humfrz For This Useful Post:
Dadhawk (03-16-2020), korhun (03-16-2020), p1l0t (03-15-2020), Sapphireho (03-16-2020)
Old 03-15-2020, 11:53 PM   #67631
Originally Posted by cjd View Post
Front hubs are sealed bolt-on affairs. There's pretty much nothing you can do (which comes to mind, anyway) to damage it unless you're hammering on the axle. Also no real way to do preventative maintenance.
You mean that I wouldn't need to get a new cotter pin -
humfrz is offline
The Following 3 Users Say Thank You to humfrz For This Useful Post:
cjd (03-16-2020), korhun (03-16-2020), soundman98 (03-16-2020)
Old 03-15-2020, 11:58 PM   #67632
OK, grandpa -
humfrz is offline
Tcoat (03-16-2020)
Old 03-16-2020, 05:42 AM   #67633
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Yes, they are good. No knocking over bumps. I did just change out my entire suspension setup including the top hats though.
I am wondering if it is brake dust contamination wearing away at the seals. It should be fairly obvious if that is the case as the grease will be cakey.
Ultramaroon (03-16-2020)
Old 03-16-2020, 03:20 PM   #67634
ichitaka05
Site Moderator
ichitaka05's Avatar
My work have officially closed til further notice... but sadly I still gotta work from home. Which I'm not complaining. I'm a bit behind on project, so it's nice that I have 2 wks to catch up.
The Following 3 Users Say Thank You to ichitaka05 For This Useful Post:
korhun (03-16-2020), spike021 (03-17-2020), Spuds (03-16-2020)
