Old 03-12-2020, 01:10 PM   #21617
MJones_RB
MJones_RB's Avatar
Drives: Scion FR-S Series 10 #2462
Originally Posted by new2subaru View Post
Cleaning the engine bay. I have a bunch of parts removed and cleaned and did the timing cover so far.
Somoniz aluminum wheel cleaner works great but smells like horrible!! I'll mask up next time.
Wow. Not all heroes wear capes.
MJones_RB is offline   Reply With Quote
The Following User Says Thank You to MJones_RB For This Useful Post:
new2subaru (03-12-2020)
Old 03-12-2020, 09:13 PM   #21618
new2subaru
Weight Weenie
Drives: 15 FR-S
It doesn't really take much to clean it. I like taking things apart to see what's what.
I'm also doing so polishing while I'm in there and may do some wiring tucking. It'll give me an idea on what I want to do next winter. The combined engine/body harness drives me crazy...
The Following User Says Thank You to new2subaru For This Useful Post:
MJones_RB (03-13-2020)
Old 03-14-2020, 01:06 PM   #21619
alex87f
Meow
alex87f's Avatar
Drives: GT86 (now sold)
Put some sound deadening in the trunk - I was chasing a rattle coming from the rear and started removing elements to eliminate them as potential sources. Didn't find the rattle (think it's coming from the outside ), but thought I might as well put some insulation before putting everything back together.
alex87f is offline   Reply With Quote
Old 03-14-2020, 01:09 PM   #21620
jflogerzi
jflogerzi's Avatar
I am curious to hear your feedback on how much of a difference sound levels are vs stock
2013 Series 10 FRS #553
Old 03-14-2020, 08:44 PM   #21621
Breadman
Breadman's Avatar
Drives: 2017 BRZ w/PP
Installed a perrin 22mm front sway bar, racerx endlinks, and spc camber bolts
[ame]https://www.youtube.com/watch?v=VoF0-OTiojw[/ame]
The Following User Says Thank You to Breadman For This Useful Post:
MJones_RB (03-16-2020)
Old 03-15-2020, 09:55 PM   #21622
dnieves
Drives: FR-S 10 Series
Drove from Long Island NY to Delaware and back yesterday (nothing more fun than a long road trip in the FR-S). Take a quick trip today then on the way back upon turning on the ignition I get CEL and Slip lights (never had that before). After inconclusive OBD scanning (P0018 & C1201) and research I dis/reconnected the battery to see if it comes back.
Car is completely stock and 44k mi.
Fingers crossed.
Inconclusive because the P0018 is indicative of a crankshaft problem and C1201 ECS malfunction. On this site I've read threads about this and changing out the ECS (which didn't work), engine work, slip sensor replacement, and etc. I don't want to spend $150 for a Toyota tech's best guess.
dnieves is offline   Reply With Quote
The Following User Says Thank You to dnieves For This Useful Post:
humfrz (03-16-2020)
Old 03-16-2020, 07:12 PM   #21623
MJones_RB
MJones_RB's Avatar
Blacked out all of the silver painted trim.
The Following 4 Users Say Thank You to MJones_RB For This Useful Post:
beltax90 (03-16-2020), humfrz (03-16-2020), RToyo86 (03-19-2020), StraightOuttaCanadaEh (03-16-2020)
Old 03-16-2020, 09:30 PM   #21624
Well, that may be better (cheaper) than just throwing parts at it -
Old 03-16-2020, 09:33 PM   #21625
If the trim would have come from the factory blacked out, would you have painted it silver?
MJones_RB (03-17-2020)
Old 03-16-2020, 10:44 PM   #21626
dnieves
From what I read here that's what the Toyota techs do: change the crankshaft position sensor then the error may/may not go away. Then when it returns they change the ECU. Then after that they take your camshaft apart charging you $$ every step along the way until you get a $6k bill at the end.
What a pain, this car has been trouble free (minus crickets/condensation in the tail lights/leaky cam plate) but being babied and with so few miles I didn't expect a CEL that keeps coming back.
With zero warranty left would I have better luck at a Subaru dealership? These engines aren't the servicing nightmare of a rotary but I don't want to finance guesses.
humfrz (03-16-2020)
Old 03-16-2020, 10:46 PM   #21627
new2subaru
Weight Weenie
Drives: 15 FR-S
Got my new dash panel
The Following 6 Users Say Thank You to new2subaru For This Useful Post:
MCTeeJ (03-17-2020), MJones_RB (03-17-2020), RToyo86 (03-18-2020), smoke86 (03-18-2020), Tcoat (03-17-2020), trvth (03-25-2020)
Old 03-16-2020, 11:38 PM   #21628
Oh, I reckon I'd look at the $150 spent at the dealership as a "second opinion". Whether it's at your Toyota dealership or a Subaru dealership would depend on how comfortable you feel at that particular dealership.
What would I do? Well, I would take my car up to the local auto shop that I've done business with for the past 25 years and tell the manager what the symptoms (codes) were and ask them to evaluate the situation. If they think they can fix it they will tell me so. Then I would ask for an estimated cost.
If they can't fix it, they would tell me so and I would have to take it to the dealer or up to a tuning shop that works on these kinds of cars.
I hope you get it sorted out and fixed soon.
dnieves (03-17-2020)
Old 03-17-2020, 12:59 PM   #21629
MJones_RB
MJones_RB's Avatar
Hah, good point. The only thing missing is the dash panel, but because it's a 10-series it has that illuminated logo behind it so I'm stuck with it.
humfrz (03-17-2020)
Old 03-17-2020, 11:10 PM   #21630
Impureclient
Drives: 2015 FR-S
Not today but when we are all stuck inside for sure which is probably about to happen, I'm stripping the car all down of the sealant and waxes on it, doing paint correction and a ceramic coating with Armor Shield IX.
The Following 4 Users Say Thank You to Impureclient For This Useful Post:
MJones_RB (03-18-2020), new2subaru (03-19-2020), RToyo86 (03-19-2020), smoke86 (03-18-2020)
