| Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack Specific topics relating to wheels and tires. |
#603 |
Only users lose drugs.
Drives: All the time
Is the profile of the wheel barrel itself different from other wheels to facilitate this?
"To know a thing well, know it's limits. Only when pushed beyond its tolerances will true nature be seen." Amtal Rule
#604 |
#605 | |
Drives: C5, GT-86, '24 Colorado TrailBoss
Never heard of them. Any weights on the the wheels they carry. I read their intro thread and some of the weights seemed heavy. Defeating the purpose in most cases of going smaller/lighter |
#606 | |
For a lightweight 16 inch wheel, the Enkei 16x7 RPF1 is a good way to go. I have those Enkeis and a set of 17x8 BRAIDs for my own car. - Andrew |
#607 | |
They're a longtime manufacturer/supplier of wheels for the rally community. Strength over light weight is what's valued there. Top quality wheels; not cheap.
| The Following 2 Users Say Thank You to venturaII For This Useful Post: | Racecomp Engineering (10-16-2018), why? (10-16-2018) |
#608 |
Oops...what the other Andrew said...lol
| The Following User Says Thank You to venturaII For This Useful Post: | Racecomp Engineering (10-16-2018) |
#609 |
Only happy when it rains.
Drives: series.blue
yes, Braid does have a line of forged wheels, but finding out actual weights is next to impossible.
#610 |
| The Following User Says Thank You to SuperTom For This Useful Post: | Racecomp Engineering (10-17-2018) |
#611 |
Drives: 2014 GT86
.. for rally crowd .. which makes them good choice for winter wheels. Extra strength may help on bad roads, good brake clearance may allow running smaller diameter wheels, in turn allowing usage of cheaper winter tires with also higher profile for more comfort/compliancy/wheel protection.
| The Following User Says Thank You to churchx For This Useful Post: | Racecomp Engineering (10-17-2018) |
#612 |
Drives: Safari build FR-S
#613 |
Dysentery Enthusiast
Drives: 2017 toyota 86
16x7" +35 sportline P4 Rims, advertised weight was over 16 I scaled mine at 15.7, The Tires are 225/60 General GMax-AS-05, on the scale at work the tire combination weighed 6.8 pounds less per wheel/tire. I've had them on for a few days my impression of the 225/50r16 vs 215/45r17 is that the 16 inch wheel and tire set up is much more planted in the corner and during acceleration. There is a little loss in the steering response that was noticeable at first after driving the car for an hour or two I don't notice it anymore. Also once you start to get loose in a corner it's much easier to recover by backing off a little. Over all the 225 on a 16 is far better feeling than the 215 on a 17. Total cost for rims and tires was less than $1k. This comparison is vs the stock wheel and tire setup. I'm sure there is some better 17" or 18" rim setup with 295's on 1/2" tall sidewalls, it took me quite a bit of deliberation to go with the 16" wheel over a 17" wheel. At the end of the day I wasn't going to go over a 225 tire most likely or larger than a 7" rim. It would have cost me nearly 175% more to do that with a 17" wheel and keep the weight of the wheel and tire I have with the 16" wheel. Last edited by RuyGuy2; 03-13-2020 at 12:54 PM. |
| The Following User Says Thank You to RuyGuy2 For This Useful Post: | why? (03-13-2020) |
#614 |
Here is a link to the photos if they don't show up in the post, https://photos.app.goo.gl/ig4ij6awJpFWx7eg8
#615 |
Drives: series.blue
not one of those pictures work.
| The Following User Says Thank You to why? For This Useful Post: | venturaII (03-13-2020) |
#616 |
Most rally wheels are more than 20lbs. A lot of subie guys use them as winters because weight and performance matter less. But summers you want lighter wheels.
| Wheel Directory: Styluz S006 18x7.5 +40 | Pavel | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 23 | 01-22-2014 04:16 PM |
| FS [SYD] 16 inch GT wheels and tires! | luv85 | Australia Classifieds | 3 | 11-04-2012 06:15 AM |
| Help! Two 10 inch vs One 10 (or 12) inch | cyntage | Electronics | Audio | NAV | Infotainment | 7 | 09-27-2012 11:20 PM |
| I need 19 inch wheels today! | benqld7 | AUSTRALIA | 16 | 08-07-2012 08:33 AM |
| 16 inch wheels for the base model!!! | Blokatos | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 2 | 12-07-2011 11:17 AM |
