Old 03-10-2020, 06:49 PM   #5335
CSG Mike
CSG Mike's Avatar
Originally Posted by tomm.brz View Post
Factoy oem tunes do not drop power against neither coolant or engile oil temperature
Just against air intake temperature
That s why you, me and whoever tune this car need to build custom maps to have timings drop against oil temperature and to blink or flash the CEL
Already integrated into CSG tunes!
Old 03-10-2020, 06:50 PM   #5336
CSG Mike
CSG Mike's Avatar
Originally Posted by J1Avs View Post
Getting the feeling once you cut the Verus vents in, I’ll need a new hood for the Trackspec. Those lines don’t look like they line up all that much, but that’s a guess.
For reference, I’m also running Motul 300V 5W30, and Subaru OEM Coolant. I plan on going to Distilled Water and Water Wetter once the temperatures move towards more consistent warm weather. Should I be running a different oil??
Thanks as always!
300V is totally solid.
Try sourcing a used hood, or swap + cash for your hood with Verus vents. It should be fairly easy to find someone to swap with.
Old 03-10-2020, 06:51 PM   #5337
steved
Drives: 2013 FRS
The purpose is to keep all air entering the front opening going through the cooling stack. Air going around the stack is air not drawing heat away from your coolers.
So B. then?
I've completely boxed in the front end, only the intercooler can take in air.
https://photos.app.goo.gl/meMGxHWvPzmCgpSL8
This seemed to make no difference in temps with my previous Dual Rad config, and if my last temps are any indication I'm going to be in just as bad a place when summer temps hit with this track oil cooler.
steved is offline   Reply With Quote
Old 03-10-2020, 08:49 PM   #5338
AndreC
Drives: Fast track beast
One of the big challenges I've faced with this setup is the fact that the intercooler blocks the entire mouth, so you get lots of heat soak into the rad.
Intercooler => oil cooler & SC cooler => rad
Each cooling element expels heat to the next element, and to the next. And airflow drops after each one as well.
But I've asked before and was told no one ever runs hot, even on track, so I finally ended up making airflow changes on my own.
(the FT86SpeedFactory TA car had similar heat soak issues last summer)
Anyways, so I took out the factory crash beam, and replaced it with a "drift bar" which sits alot higher and now allows airflow to get a straight shot to the rad over the intercooler.
And the whole cooling stack is also boxed out. (it was also before but didn't help much)
Hope this helps anyone else before heating issues hurt your engine.
Sent from my SM-G965W using Tapatalk
AndreC is offline   Reply With Quote
Old 03-10-2020, 09:14 PM   #5339
steved
Drives: 2013 FRS
Ya I've thought about this method as well. Did you custom mount the top side intercooler bracket to the drift bar?
Do you have ambient temp, peak oil, and peak water temps before/after this change?
Old 03-10-2020, 09:22 PM   #5340
86TOYO2k17
Drives: 2017 toyota 86
Why not relocate oil cooler to behind passenger fog light and supercharger oil cooler to behind driver side fog light. I have my oil cooler and AT trans cooler in those two spots. I don’t track my car. But it seems it would help with reducing the stack in the front and heat soaking each other.
Old 03-10-2020, 10:22 PM   #5341
AndreC
My oil temps have been okay, it's the water temps that would build after more than 3-4 race laps. But looking to relocate both coolers to either side this year. So far temps are waaaay down but engine was already pooched (hg leak at coolant passage on first engine, suspect same on current engine in car). I was at least able to finish the season on that engine.
Old 03-10-2020, 10:24 PM   #5342
AndreC
Yes, made a bracket that comes down to the intercooler from the drift bar, you can see it in the pics. I'll be able to record data soon once track opens (in Canada) and once the rebuilt engine is in.
Old 03-10-2020, 10:27 PM   #5343
86TOYO2k17
Un stacking them will help coolant temps a lot.
Passenger side has plenty of space
Driver side i swapped in https://www.chasebays.com/products/c...SABEgKKC_D_BwE to have lots of space on that side. Was pretty easy setup all around.
Old 03-11-2020, 02:57 AM   #5344
CSG Mike
CSG Mike's Avatar
So B. then?
Don't box the intercooler like that. You need the additional air going around the intercooler to cool your radiator.
Old 03-11-2020, 02:33 PM   #5345
RFB
RFB's Avatar
Drives: FRS
Like wise. Heat soak brought me to 260 F so I put the engine oil cooler where my windshield washer was.
My oil temps behaved like a toilet seat in a whore house on a Saturday night in comparison to the stack. When coming off the highway into the city the loss of the rad fan caused much higher temps that took much longer to cool .
Overall , the MAX temp. is much lower, allowing more hot laps. The problem is opening up the fender liner properly for exhaust air. I used plastic grates, slots upward vanes down and as long as I don't reverse at hi speed in mud, the vents stay open.
A must do for tracking !
RFB is offline   Reply With Quote
Old 03-11-2020, 03:37 PM   #5346
86TOYO2k17
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
i used the 5 1/2" by 4 7/8" but you could make the larger one fit, looks pretty clean can hardly tell its there unless you are looking for it. I just cut a square in the liner, and nut and bolt these on from the inside, bolt head coming in from outside, firmly secured, and works perfectly. pretty easy setup. I don't track my car, but nothing i can do on the street even phases my temps (FYI I have sprintex 210 w/ 69mm pulley). I'm sure it would be different on the track though as i don't have the most ideal airflow coming in. but didn't want it to be too good and over cool too much on the street. BRZ bumper fog light would be much easier to have a clean looking setup with much better flow then the 86 bumper.
You could also add in some fans wired off the oem fans to come on same time those do for low speed cooling. or have it on in reverse behind the cooler to "suck" the hot air from the cooler out the back vent.
Old 03-12-2020, 10:45 AM   #5347
RFB
RFB's Avatar
Drives: FRS
There is a plastic removable grate on the front bottom plastic plate under the front bumper that is the correct size, available from Toyota parts dept. and can easily be riveted onto the liner.
Doubt that there would be room for a large enough of a fan in the wheel wells. Perhaps some kind of NACA ducting could work, or just opening the entrance grate larger.
Old 03-13-2020, 01:18 AM   #5348
steved
Drives: 2013 FRS
@AndreC
Is this where you got the idea of opening up the front end?
http://www.ft86club.com/forums/showp...5&postcount=29
I notice Verus put a horizontal panel across the top of the intercooler towards the sandwiched oil cooler/rad.
Once they opened up the top side they saw incredible improvements.. but that oil cooler is massive.
Jackson Racing Rotrex Supercharger System Info and Discussion Jackson Racing Forced Induction 827 04-06-2020 04:56 PM
Jackson Racing Supercharger Press Release and Info CounterSpace Garage Forced Induction 110 01-03-2017 09:04 PM
jackson Racing engine oil cooler - modular to fit the Jackson Racing Supercharger! CSG Mike Forced Induction 24 04-27-2016 12:59 PM
Jackson Racing supercharger NoppyNop Forced Induction 241 06-26-2014 03:05 PM
Jackson Racing Supercharger Pre-Order Sale, $200 off! Xero-Limit Forced Induction 2 03-05-2014 04:14 PM
