Old 03-12-2020, 12:58 PM   #15
MaverickMonk
Drives: 13 BRZ Limited
I have not run that tire. But, here is my experience with MPSS in 225 and 245 on 8" and 9" wide wheels.
I ran 245's on 8" wide wheels. The steering went all mushy, I hated it. I removed them and installed 225's. The steering was much better. I then bought 9"wide wheel and installed the 245's. The steering with 245 +9" wheels feels very similar to 8" wide wheels and 225's.
Agreed, little bit of wobble at limits of traction and a little bit of steering mush for me with 8” wheels and 245 PS4s
MaverickMonk is offline   Reply With Quote
Old 03-12-2020, 04:03 PM   #16
Vital
Drives: 2015 BRZ
Originally Posted by BlueWhelan View Post
Ahh, it’s the 40 offset and the spacers that’s are saving ya the extra clearance. How much you got with that setup?
I have the same exact setup as jflogerzi. RCE Yellows on stock shocks/struts and Konig Dekagrams 17x8 +40 on 245/40/17 Firehawk Indy 500 and there is absolutely no need to run spacers in front. Im not sure why he's using spacers, but there is lots of clearance up front and i got -1.6 camber with camber bolts.
As far as answering this question, i didnt notice any detrimental effects from that tire size. It honestly feels really solid and planted i like the feel. I may try out a 225/45/17 after these tires wear out...
The Following User Says Thank You to Vital For This Useful Post:
mrg666 (03-22-2020)
Old 03-12-2020, 05:24 PM   #17
bradyhuutch
bradyhuutch's Avatar
Drives: 2019 WRB BRZ PP
Originally Posted by jflogerzi View Post
Running 245's on my 17x8 rims. No issues so far. Stock dampers and rce yellows with crash bolts up front and lca in rear. Less the 2 degrees of camber up front. Offset is 40 and I have a 3mm spacer up front and rear. Front brake clearance and rear just because poke
Did you get RCE Yellow kit from FT86SpeedFactory? I've been thinking of getting it myself..
bradyhuutch is offline   Reply With Quote
Old 03-12-2020, 05:47 PM   #18
jflogerzi
jflogerzi's Avatar
Yes but that was a while back
2013 Series 10 FRS #553
Old 03-12-2020, 06:43 PM   #19
86TOYO2k17
Drives: 2017 toyota 86
Generally speaking with a 17x8 wheel a 245 will be a little faster then a 225 around a track. But a 225 might “feel” better to most drivers even if technically its slower.
With that said you would also need to look at the specific tire as some brands 225s are wider then other brands 245s, or vice versa If its a specific tire that runs narrow, normal, or wide.
The Following User Says Thank You to 86TOYO2k17 For This Useful Post:
pogofx (03-12-2020)
Old 04-19-2020, 07:46 PM   #20
TeamBadger
Drives: 2016 Brz Limited
Tests I've seen in the past from Andy Hollis have shown that matching tread width to wheel width is a good rule of thumb. The wider tire isn't effectively used on a narrow wheel as the sidewalls are "pinched".
TeamBadger is offline   Reply With Quote
Old 04-20-2020, 08:42 AM   #21
Jpembry
Drives: 2019 Subaru BRZ Series.Gray
Not all tires are the same width as well. So some 225’s may run as wide as a 245. I know the PS4S and indy 500 for instance are on the narrower side and those in 245 have the same tread width as an RS4 or RSRR in 225.
Jpembry is offline   Reply With Quote
Old 04-24-2020, 12:04 PM   #22
CatDaddysBBQ
Drives: '13 FR-S
I run 235/40 on a 17x8 wheel for the past few seasons and feel it's a really nice middle ground. Steering feel is (generally speaking) better than a 245 and more grip than a 225.
I do not believe that the RE71R comes in that size though. But if you're not totally set on that exact tire, this could be a really good option.
CatDaddysBBQ is offline   Reply With Quote
Old 08-22-2020, 11:05 PM   #23
jflogerzi
jflogerzi's Avatar
Never saw this but because bbk
Old 08-24-2020, 11:59 AM   #24
CrowsFeast
CrowsFeast's Avatar
Drives: 2013 BRZ Sport-Tech
My track setup is 17x9 with 255 RS4's all around. The wheels are +40 and I have 3mm spacers installed up front. I have camber plates and both top and bottom camber bolts with stock struts and springs. Maxed the plates out to give the most clearance between the fender and the springs then dialed it in at -3* camber using the bolts.
I didn't see or hear any signs of rubbing but I only got 3-4 laps in before my motor went. (stupid '13 )
My previous car I ran 255 RE71R's on an 8.5" wheel. The tires were definitely pinched and I wouldn't recommend it so I definitely wouldn't recommend a 245 on an 8" wheel either.
CrowsFeast is offline   Reply With Quote
APR GT250 67 Inch wing w/ 7 Inch risers on SEIBON CSL Style CF Trunk Tony.86_ Exterior Parts (Aero, Lighting, Etc.) 5 01-03-2020 11:03 PM
Brembo club racer BBK with 332mm rotor on 17 inch wheel? GrabTheWheel Suspension | Chassis | Brakes -- Sponsored by 949 Racing 6 09-30-2019 03:04 PM
Anyone can recommend a good 16 inch wheel? qqzj Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 53 09-14-2019 09:03 PM
235 on 8 inch wheel? perryair Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 11 12-11-2017 11:16 AM
8.5 inch wide wheel tire size? ChrisP Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 9 01-26-2016 05:07 PM
