Old 03-06-2020, 11:04 PM   #3403
Mad1723
Mad1723's Avatar
Drives: Asphalt FR-S
Originally Posted by Decep View Post
seems like an awfully complicated pain in the ass to install that new BV.
One time pain to avoid having to stock up on bypass valves? I'll take it
Sent from my Pixel 4 XL using Tapatalk
Mad1723 is offline   Reply With Quote
Old 03-07-2020, 12:07 AM   #3404
BA9092
Captain Slow
BA9092's Avatar
Drives: '18 BRZ Limited PP 6MT ISM
Well, I was thinking the same thing. But, quite a few people have replaced the original. I wonder if the same "short cuts" they took, without having to remove the supercharger, would apply to this new one?
BA9092 is offline   Reply With Quote
Old 03-07-2020, 12:15 AM   #3405
Mad1723
Mad1723's Avatar
Check the instructions in the post. You have to remove the kit to do the upgrade.
Old 03-07-2020, 12:26 AM   #3406
BA9092
Captain Slow
BA9092's Avatar
I did. However, the ones who've had to replace the bypass valve with a new one, only took a few tools to replace it without having to remove the supercharger:
http://www.ft86club.com/forums/showp...postcount=2368
I may just bite the bullet and see how long mine lasts and then just replace it with the same part number if it's easier.
I'd hate to have to remove and reinstall the supercharger! Especially if the current valve's still working.
Old 03-07-2020, 09:42 AM   #3407
Mad1723
Mad1723's Avatar
That's the older model. That job is a simple 3 nuts job. The new instructions require to remove the bracket from underneath and then shim the bypass blade whilst holding the vacuum open. Pretty sure you can't do that with the kit on the car.
Old 03-07-2020, 01:15 PM   #3408
BA9092
Captain Slow
BA9092's Avatar
Ah, gotcha. That makes sense. I appreciate the clarification.
I've only had mine on for 500 miles. Guess I'll wait to see how long my BV lasts. I'd hate to do a whole reinstall unless I had to.
Old 03-11-2020, 11:31 PM   #3409
Z06ZN6
Drives: 2017 Toyota 86
E-Force + AC service = Fail
I am not sure if this has been discussed before, but due to some trouble I ran into, I wanted to leave a warning for E-Force users that you may run into some similar difficulty in the future getting your AC serviced. Again, this is based on my experience, but maybe others have had better experiences or have more knowledge to come up with better work arounds.
Anyways, after working through some minor install issues with my E-Force, I noticed that the supercharger runners block vertical access to the high side AC port (up by the compressor). So while the SC runners have been relieved to provide generous physical clearance to the port itself, the designer failed to consider port access to attach the high side manifold coupler for service. I brought this to Edelbrocks attention and they clearly realized this was an oversight as they went and confirmed it on their in-house car. What is not clear is if they will revise the kit in the future to correct the issue. I hope they do, but this one may be difficult. So with the kit installed, you cannot properly service your AC system (at least according to the specialists).
I went searching for low profile couplers or some other type of port extenders to help gain access to the port but came up empty. I also bought a couple used AC hoses off eBay and tried carefully welding new high side ports on the hard line sections about an inch or so away from the stock one, but the heat was too much for the soft hoses (which was somewhat of an expected result). The stock ports appear to be soldered in, likely before the hardline is crimped on the hose. Anyways, the next thing I was going to try was welding a new port to the opposite side of the line, adjacent the condenser, but then access would have been really tough, or impossible.
I took the car to the local Toyota dealer over a month ago to see if they would charge it, but they refused without access to both low and high side ports (as expected). One can't even remove the SC to access the port because the car needs to be running for service, which means returning the car all the way back to stock to get access to the port and have it running in order to do "right". That wasn't really an option for me. Nor am I a fan of dealers, and even less of small service shops. I got tired of wasting time and money on this so I just borrowed an AC manifold set and used my old home-made composites vacuum pump to pump down and charge through the low side port only. I am not an AC technician, maybe there is some other creative way to do it, but for me, I got tired of thinking about it and having no AC for three months (even though it's winter) so I put 13oz of R134a in it and called it a day. The AC is as cold as it ever was and running fine so far. Any issues that pop up, ebay used parts for this car are cheap and plentiful. I did find that some small AC shops will agree to charge only through the low side port for those who don't have the equipment or desire to do it on their own. I just don't like others touching my car
Anyways, that was my experience with the recharging the AC on my Eforce equipped 86. I hope it is helpful to someone in the future.
Z06ZN6 is offline   Reply With Quote
The Following 8 Users Say Thank You to Z06ZN6 For This Useful Post:
AKITA (06-12-2020), BertoFT (03-12-2020), brandonblt2 (05-05-2023), FunnyGopher (03-15-2020), Lonewolf (03-14-2020), Mr_Eyo (03-14-2020), nextcar (03-12-2020), shiumai (03-12-2020)
Old 03-18-2020, 08:06 PM   #3410
Rob37072
Drives: Silver FR-S
Originally Posted by Z06ZN6 View Post
I am not sure if this has been discussed before, but due to some trouble I ran into, I wanted to leave a warning for E-Force users that you may run into some similar difficulty in the future getting your AC serviced. Again, ....
I had the same issue. Did the same thing, filled at home with my equipment. If i ever have a more serious issue I'm going to get a new line made. They are pretty inexpensive to have fabricated. I do worry a little about the availability of the metal section that connects to the actual compressor. We'll see if it ever comes to that.
Rob37072 is offline   Reply With Quote
Old 03-19-2020, 08:30 AM   #3411
B T
Drives: 15 BRZ, 2003 MR2, '70 Elky, 06 TBSS
Edelbrocks upgraded bypass actuator kit part number is 15001 and it is available now.
About how much does this kit run? Tried to find the part # listed with no success.
B T is offline   Reply With Quote
Old 03-19-2020, 10:10 AM   #3412
devtec
Drives: 2015 Subaru BRZ Limited
I just ordered it. $55.95 plus shipping.
devtec is offline   Reply With Quote
Old 03-19-2020, 10:40 AM   #3413
BertoFT
Drives: 13 FRS Firestorm
I'm guessing you called to order it; I don't see it on the Edelbrock site.
Sent from my SM-G9600 using Tapatalk
BertoFT is offline   Reply With Quote
Old 03-19-2020, 12:15 PM   #3414
B T
deets?
Old 03-19-2020, 09:17 PM   #3415
shr133
shr133's Avatar
Drives: 2013 FRS
Well I'm finally part of the club, installed it this winter and now I was finally able to drive it. So far it's running great, tune is good, but it's still cold here and it spins like crazy, first gear is basically useless... Shifts weird going into second, that's only real problem so far.
Definitely need a fuel pump to run this kit, F/A ratio was dropping to 14.5 with the stock pump at around half throttle, now it hold steady all the way...
Enkei TS9 18 X 8, Michelin Sport 4S 225 40 18, Flex Fuel, Edelbrock Supercharger, P & L header, Nameless front pipe, V1 cat back, Aluminum Driveshaft, pvc delete, med duck bill, KW V3, Whiteline 20 and 18 mm bars, Buddy Club and SPL control arms, Toe Arms, motor and trans mounts, Whiteline bushings, SHR stage II tune.
shr133 is offline   Reply With Quote
Old 03-20-2020, 07:16 AM   #3416
losito92
Drives: 2017 Series Yellow BRZ
So to put the new bypass actuator you basically have to uninstall the whole supercharger and install again? And if that one is bad you would have to uninstall again that sounds really annoying
losito92 is offline   Reply With Quote
Edelbrock E-Force Supercharger itsibarra Forced Induction 938 07-31-2021 04:48 PM
Most annoyingly over-asked questions on FT86 forums mit_peid Off-Topic Lounge [WARNING: NO POLITICS] 36 01-16-2014 02:48 PM
