Old 03-09-2020, 03:34 PM   #15
Stephen W.
Stephen W.'s Avatar
Drives: 1993 Caterham HPC Evo
Originally Posted by BlueWhelan View Post
Not to mention the aero.
You mean the lack of the areo bits on the 2020 tS, right?
The Following User Says Thank You to Stephen W. For This Useful Post:
Tcoat (03-09-2020)
Old 03-09-2020, 04:01 PM   #16
BlueWhelan
BlueWhelan's Avatar
Drives: 2013 Blue Subaru BRZ. 6 Spd manual
Aw that’s right! The 2020 doesn’t have the stupid wing!! My bad. Lol!
BlueWhelan is offline   Reply With Quote
Old 03-09-2020, 05:12 PM   #17
Stephen W.
Stephen W.'s Avatar
Ya use bad... You may not like the wing but it is part of the 2018's aero package along with the front spliter, side skirts and rear deflectors.
Clutch Dog (03-09-2020)
Old 03-09-2020, 07:17 PM   #18
yurikaze
yurikaze's Avatar
Drives: 2018 BRZ tS (CBS), AE86 GT-S, MA70
I have a 2018 tS, and my dad has a 2017 Series.Yellow which comes with the PP. I've noticed that when both are stock, the tS has better feel and turn in, and the stability control isn't as intrusive.
However, the biggest difference I've noticed is once you start to mod them.
If you put the coilovers and wider wheels/tires on the tS, it actually responds much better to the mods than a standard PP.
The tS draw stiffeners and flexible v-braces are a good match if you're running a more aggressive and grippier setup, and the stability control comes pre-tuned for a grippier setup than the regular PP.
So I'm going to go against conventional wisdom and say if you're planning on improving the handling, the tS is actually the better car to start with.
BRZ tS 160/500
yurikaze is offline   Reply With Quote
The Following 5 Users Say Thank You to yurikaze For This Useful Post:
BlueWhelan (03-09-2020), Stephen W. (03-10-2020), Tcoat (03-09-2020), Thefalls (04-13-2020), WolfpackS2k (03-10-2020)
Old 03-09-2020, 07:30 PM   #19
He means "my bad" as in "my mistake" or "my screw up" not that the wing is bad even if he thinks it is stupid.
Damn old guys don't understand modern slang.
Old 03-09-2020, 10:08 PM   #20
rcm47
rcm47's Avatar
Drives: 13’ FRS (traded), 18’ CWP BRZ tS
I traded in my 2013 FRS for the 2018 BRZts because it had everything I wish my FRS had and it was all under warranty. The difference in handling was very noticeable and I’m a fan of the aero pieces that came with the 2018 ts.
rcm47 is offline   Reply With Quote
The Following 2 Users Say Thank You to rcm47 For This Useful Post:
Busybee (11-17-2021), Tcoat (03-09-2020)
Old 03-09-2020, 10:14 PM   #21
BlueWhelan
BlueWhelan's Avatar
Indeed, though I really don’t have problem with the wing per se. It serves an actual function so it’s fine. I’m just not a fan of how it looks, IMO.
Old 03-12-2020, 12:17 AM   #22
DumbUglyDragon
Drives: 2018 BRZ tS
Originally Posted by nextcar View Post
Another thing to consider on the tS...
The 18 inch wheels supplied are heavy. Did you notice the tS is rated for 2MPG less than the limited with PP? Identical drivetrain and gearing... The lowered fuel economy is largely weight related - and the wheels are a significant contributor.
This is more likely related to the rolling resistance of the tires. The Michelin Primacy HP tires that come on the standard trims have very low rolling resistance - they are also OEM on the Prius.
You'll notice a drop in MPG when upgrading to a stickier tire from the stockers.
The factory Michelin Pilot Sport 4 that come standard on 'tS' are significantly sticker than the Primacy HP's and have greater rolling resistance, which means less Miles per Gallon, but more Smiles per Gallon.
DumbUglyDragon is offline   Reply With Quote
Old 04-02-2020, 05:08 PM   #23
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
Is performance package same manufacturing year? Personally, I would prefer the '20 tS which is a newer model and has improvements in different areas. It is not just of changing the tires. If they could also make it lighter …
Old 04-02-2020, 07:28 PM   #24
N_Raged
Drives: 2019 BRZ Sport-Tech RS
Does anyone have the part numbers for the STi Draw Stiffeners and Flexible V-Braces?
Tempted to put those on my 19' RS.
Edit: nevermind, I assume this is it on STi's website? https://www.sti.jp/en/parts/subarubr.../ST20118AS000/
N_Raged is offline   Reply With Quote
Old 04-02-2020, 08:02 PM   #25
Yoshoobaroo
TRACKBREAD
Yoshoobaroo's Avatar
Careful, I the draw stiffeners are different for Ts cars, they have a different subframe
Old 04-02-2020, 10:45 PM   #26
N_Raged
Thanks for calling that out. I did some searching and found this thread.
https://www.ft86club.com/forums/showthread.php?t=134087
You are correct that the 2018 tS draw stiffeners only fit the tS subframe. But interesting to know that the JDM STi draw stiffener is different and should fit regular Twins.
The Following User Says Thank You to N_Raged For This Useful Post:
Yoshoobaroo (04-03-2020)
Old 04-03-2020, 02:09 PM   #27
Jordan Silveira
Jordan Silveira's Avatar
Drives: 2016 Subaru Series.HyperBlue #631
I can confirm I have the non-2018 STI draw stiffeners. I have the JDM 2013-2016 STI Draw Stiffeners on my 2016 and they mated up perfectly to the subframe
Jordan Silveira is offline   Reply With Quote
The Following User Says Thank You to Jordan Silveira For This Useful Post:
Old 04-03-2020, 02:58 PM   #28
BlueWhelan
BlueWhelan's Avatar
Thanks for confirmation! You feel much of a difference?
AT vs MT WHP difference JDM4E Engine, Exhaust, Transmission 48 04-06-2020 06:43 PM
cat/no cat hp difference? EN2_Squirrel Engine, Exhaust, Transmission 6 11-17-2013 09:32 PM
Group Buy Limited Limited Limited Edition 57Xtremes in KY color vividracing Groupbuys 0 10-14-2013 07:22 PM
BRZ vs BRZ limited? what is the difference? Bangduk Scion FR-S / Toyota 86 GT86 General Forum 1 08-07-2012 03:36 PM
