Old 02-26-2020, 07:13 PM   #15
p1l0t
p1l0t's Avatar
Old 02-26-2020, 09:31 PM   #16
ToySub1946
ToySub1946's Avatar
Drives: 15FRS, 05MustangGT, 85Toyota truck
This is normal sound of high pressure fuel pump:
[ame]https://www.youtube.com/watch?v=B8NgXU8rU-g[/ame]
ToySub1946 is offline   Reply With Quote
Old 02-26-2020, 09:35 PM   #17
soundman98
ProCrastinationConsultant
soundman98's Avatar
LOL You are new here. Expect several dozen more responses saying the same thing. Also expect some dude(s) without a clue to tell you your engine is about to blow up, you need to use different oil, get a louder exhaust, turn up your radio, oh I could go on all day. Then, two years from now somebody will reopen the thread and say "I have this problem as well did you ever find a fix?".
and after the first 6 honest responses, the regulars will come in and spiral the thread into an unforeseen direction for no apparent reason.
Old 02-27-2020, 08:33 AM   #18
What? That would never happen
Old 02-27-2020, 02:18 PM   #19
g e
No BRZ/86 in pic
Post disqualified
g e is offline   Reply With Quote
Old 02-27-2020, 02:28 PM   #20
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Drives: '15 ultramarine
Worst fuel pump design ever!
Old 02-27-2020, 02:37 PM   #21
Originally Posted by g e View Post
No BRZ/86 in pic
Post disqualified
When we go off topic we do it RIGHT!
Old 03-08-2020, 03:51 PM   #22
2020BRZtS
2020BRZtS's Avatar
Drives: '20 BRZ tS (15/300) / '09 Scion tC
Originally Posted by DarkPira7e View Post
Just wait until you think you slowly rev the engine out above 6k RPM- it sounds like an orchestra being conducted by someone with cerebral palsy
As a session drummer with Cerebral Palsy who has sat in with the likes of Cinderella and Bon Jovi, been driving manual for 30+ years and never replaced a clutch or TOB that is quite the compliment.
2020BRZtS is offline   Reply With Quote
Old 03-08-2020, 04:12 PM   #23
norcalpb
norcalpb's Avatar
Originally Posted by radroach View Post
@Kubie715 The injectors should make a nice steady ticking sound, you'll get used to them. At this point I count that if I can hear them and they sound alright then that's a good thing. One side tends to sound different / louder than the other, maybe just by having different resonance on that side. No use in trying to quiet the injectors, with 8 injectors in a 4 cylinder it's just going to sound the way it does. Sometimes will make a chirp or a chooching sound during the summer.
A used up clutch throwout bearing can create plenty of resonating tapping from the transmission. They just go bad after ~30-50k miles. The new revised clutch throwout bearing is much improved. I'm on my 3rd one at 120k mile.
Gear whine can be because of the transmission or differential possibly needing a fluid change. Before I changed out the stock differential fluid when I was still ~30k my car made sounds like the millennium falcon on deceleration. Otherwise, yes this car will sometimes make gear whine. If you add in a whiteline transmission mount you'll get even more gear whine and cabin NVH! Fun!
The driver side fuel rail cover has sound deadening whereas the passenger side fuel rail cover is just a regular price of metal.
Old 03-08-2020, 05:24 PM   #24
extrashaky
Drives: 2014 BRZ Limited
Originally Posted by Kubie715 View Post
I’m almost positive it’s not supposed to sound like this lmao.
This question was famously settled in 2014:
Originally Posted by nickhabi View Post
Does the FRS have a distinguishable engine sound that makes ones stomach uneasy if the car passes by you on the highway? Is the FRS Engine roar distinguishable between several cars on the road? Or is it just like any ordinary car, similar to a Toyota Camry passing by?
Originally Posted by NWFRS View Post
It sounds like you've been passed by a sewing machine.
Old 03-08-2020, 07:12 PM   #25
I do not get the sewing machine reference.
It is clearly Russian farm tractor!
Old 03-09-2020, 10:55 AM   #26
edwardl
Drives: 2018 BRZ
I don't have any of these noises..
edwardl is offline   Reply With Quote
Old 03-09-2020, 11:05 AM   #27
You either have injector noise or your car is serious broken!
The injectors on these things are what messes with most peoples head since they are so loud they just don't sound "right" even though they are fine.
Old 03-09-2020, 12:34 PM   #28
p1l0t
p1l0t's Avatar
In SOVIET Russia tractor plows YOU!
brz, subaru
something doesn't look right with my rom kaluce Software Tuning 2 07-30-2016 10:07 PM
Knocking doesn't sound good :-(. TheMarkness Issues | Warranty | Recalls / TSB 41 02-04-2015 10:38 PM
Drone (Worn Wheel Bearing SOund) Sound From Rear qbzee007 AFRICA 8 11-14-2014 01:04 AM
What color would you want the FRS/BRZ to have that it doesn't have? Wilsonk227 BRZ First-Gen (2012+) — General Topics 142 05-17-2013 08:26 PM
MT doesn't like 2nd gear Nubbs Issues | Warranty | Recalls / TSB 18 08-30-2012 08:15 PM
