Old 03-05-2020, 05:28 PM   #5307
ML
ML's Avatar
Drives: 13 White MT FR-S
before anyone gets their torches out, this is just a test...of intake temps...because I want to verify what I read online. I have multiple hot things in my engine bay...
The Following User Says Thank You to ML For This Useful Post:
CSG Mike (03-05-2020)
Old 03-06-2020, 12:31 AM   #5308
tfp
tfp's Avatar
Drives: 2017 BRZ WRB with PP
At Jackson racing... Any time frame for the c38 carb sticker for the 17 subaru brz?
I bought that with my setup last summer as it was listed on your site at the time of purchase.
Sent from my SM-N960U using Tapatalk
tfp is offline   Reply With Quote
Old 03-06-2020, 09:58 PM   #5309
Bones36
Bones36's Avatar
Drives: 13 Brz Jrsc
Originally Posted by Jackson Racing View Post
Check your idlers to make sure the bearings are in good condition and check your belt. The belt will go 30-50k miles depending on environment and use, so it may be that time.
too late supercharger seized up. do you guys rebuild them or do i have to purchase a new one?
Bones36 is offline   Reply With Quote
Old 03-07-2020, 02:50 PM   #5310
mrg666
pessimistic skeptic
mrg666's Avatar
There is a thread someone showed rebuilding one. But I didn't see how long it worked after that. If I were you, I would just order a new one.
Old 03-07-2020, 09:11 PM   #5311
MilkyWitness
Drives: fdsgh
asdf
MilkyWitness is offline   Reply With Quote
Old 03-08-2020, 08:08 AM   #5312
mrg666
pessimistic skeptic
mrg666's Avatar
Originally Posted by MilkyWitness View Post
So I found a used C38 kit on someones 2014 FR-S. They are willing to swap it over to a new buyer. I am interested in it, but I own a 2019 BRZ. Are these kits universal across all model years, or is the 2013-2016 model year different from 2017-2020?
Would a C38 kit on a 2014 FR-S fit a 2019 BRZ when swapped over?
Fitting intercooler pipes behind the bumper cover can be a problem. You can ask JR the updated pipe fittings for 2019.
Old 03-08-2020, 08:16 AM   #5313
mrg666
pessimistic skeptic
mrg666's Avatar
Attachment 185313
I also thought about insulating the intake pipe connecting to throttle body. But I thought it would not help much with the heater hose connected to throttle body anyway. Do you see improvement in power?
Old 03-08-2020, 08:47 PM   #5314
steved
Drives: 2013 FRS
Originally Posted by peaches View Post
Second, if I don't run with the heater on full blast it'll overheat. Got a code a few weeks ago at Sebring... low voltage for the coolant sensor. So far I'm ok, but not taking that risk again. Need to get the dedicated cooler.
@peaches @Jacksonracing
So I bit the bullet and bought the JR dedicated track oil cooler. Hit Mission raceway yesterday ambient temp 45F, track slippery as all hell.
I purchased a gauge and an oil temp/pressure sensor to verify stock oil temp coming from ecu and saw 246-250F on both displays.
Pretty disappointed in that.. My guess is if ambient is closer to normal summer peaks of ~90F I'm not going to see any improvement over the dual rad.
Bit lost at this point to be honest.. going to verify later in May with higher ambient but my guess is I'll be parting it out.
steved is offline   Reply With Quote
Old 03-08-2020, 10:03 PM   #5315
mistople
mistople's Avatar
Drives: 2017 BRZ (Sold), 2023 GR86
I hit 265+ in 80 degree ambient with the track cooler. Was super disappointing to me as well.
mistople is offline   Reply With Quote
Old 03-08-2020, 11:49 PM   #5316
HaXx
Drives: jrsc_brz
If not the JR, what's the go to oil cooler?
HaXx is offline   Reply With Quote
Old 03-09-2020, 02:17 AM   #5317
mistople
mistople's Avatar
To be clear, the JR oil cooler is/was perfect running NA. I think I stayed around 220-230. It was only after installing the JRSC that my temps skyrocketed. I mean, I expected them to go up. I just didn’t expect that much.
Old 03-09-2020, 10:02 AM   #5318
peaches
Drives: '14 BRZ Limited
@steved @mistople that is very discouraging, what were your coolant temps? The front of the car is kind of crowded with all those cores, the only thing I can think of is making a shroud with a fan for the oil cooler but I'm pretty sure there's no room.
Best guess is the JR cars that ran with SCCA and won had stock-ish headers\exhaust, that would produce less power and less heat. I don't want to spend another $500 to find out it'll still overheat.
peaches is offline   Reply With Quote
Old 03-09-2020, 11:52 AM   #5319
steved
Drives: 2013 FRS
@peaches
For the record, my car setup is completely stock engine/exhaust wise + JRSC + JR track cooler, and I'm running the factory tune.
Coolant temp was ~12F below oil temps but honestly I wasn't keeping a close eye on coolant temp this time around so that isn't a good number to base anything on.
Agreed, strapping a fan to the oil cooler would be an interesting test, but you're right there really isn't any room in that area. I had some thoughts of relocating the cooler above the cooling stack and opening up 'nostrils' in the front bumper for airflow but I'm getting tired of spending money on track events to test cooling, and just want to drive the course.
Someone mentioned to me that maybe the oil cooler thermostat isn't opening properly at temps but if @mistople was seeing into the 230's with NA engine then all hope is lost and I should just cut my losses now.
Its really bothering me that our experiences are the exact opposite of what vendors in this thread are stating. I think we need a new thread focused on JRSC cooling at the track so there is more awareness in the forums as I suspect many people don't track their cars and the vast majority of user experiences/information is not applicable.
Old 03-09-2020, 01:51 PM   #5320
peaches
@peaches
Well that blows... I love how the car drives now but I'm leaning towards going back to NA, it does suck to pay for a track weekend and not be able to go all out.
Jackson Racing Rotrex Supercharger System Info and Discussion Jackson Racing Forced Induction 827 04-06-2020 04:56 PM
Jackson Racing Supercharger Press Release and Info CounterSpace Garage Forced Induction 110 01-03-2017 09:04 PM
jackson Racing engine oil cooler - modular to fit the Jackson Racing Supercharger! CSG Mike Forced Induction 24 04-27-2016 12:59 PM
Jackson Racing supercharger NoppyNop Forced Induction 241 06-26-2014 03:05 PM
Jackson Racing Supercharger Pre-Order Sale, $200 off! Xero-Limit Forced Induction 2 03-05-2014 04:14 PM
