Old 03-06-2020, 04:37 PM   #15
JCC
Drives: 2016 ice silver metallic
This is the one I am looking at on the Subaru parts website:
https://parts.subaru.com/p/Subaru__B...1010CA100.html
These are the ones I am considering through Subispeed:
STI JDM Short Shifter (6MT)
https://www.subispeed.com/sti-short-...-6mt-2013-ft86
(is a Subaru part, from what I understand, and may be the same as above)
FT-86 Speedfactor Short Throw Shifter
https://www.subispeed.com/ft-86-spee...fter-2013-ft86
recommended addition of MTEC Shift Spring Kit
https://www.subispeed.com/mtec-shift-spring-kit
JCC is offline   Reply With Quote
Old 03-06-2020, 08:46 PM   #16
tehShirt
tehShirt's Avatar
Drives: 2014 Subaru Forester
I would avoid the FT86 Speedfactory version, myself and other members on here have purchased it and had issues. Mine rattled constantly, and the reverse lockout would strike the retainer plate bolts. Even if I was holding the lockout up to avoid the bolt, the shifting was overly stiff. Another member had the "ball" come loose.
The MTEC springs and a polyurethane shifter stay bushing improve the feel of the stock shifter, notably the centering return and engagement into the gears. I'd suggest trying that combo before buying a shifter. If you want to take it a step further, the shift lever bushings can be replaced as well. https://www.rallysportdirect.com/par...tainer-bushing
There was a new part number for the shifter for 17+ models, but I've yet to read if there is actually a difference.
tehShirt is offline   Reply With Quote
The Following User Says Thank You to tehShirt For This Useful Post:
JCC (03-07-2020)
Old 03-07-2020, 12:19 AM   #17
JCC
I appreciate the feedback. Definitely leaning toward the STI version possibly along with the springs. As far as I know, they can be used together. Please let me know if anyone knows.
Sent from my SM-N950U using Tapatalk
Old 03-08-2020, 09:02 PM   #18
tehShirt
tehShirt's Avatar
The springs are inside the transmission, they won't affect your choice of shifter.
Again, I would suggest the springs, stay bushing and even the lever bushings before buying the STi shifter. You may find stock is adequate with the action firmed up.
JCC (03-08-2020)
Old 03-08-2020, 09:07 PM   #19
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Just an FYI, but the springs are not a fun install. Be patient or you will cross thread the retaining plugs.
JCC (03-08-2020)
Old 03-08-2020, 09:07 PM   #20
JCC
I appreciate it. I feel like I would still like the shorter throw as well as any firming up.
Old 03-08-2020, 09:09 PM   #21
JCC
What are the other part numbers besides the springs and will those part work with any shifter including the STi?
Old 03-14-2020, 01:55 AM   #22
2020BRZtS
2020BRZtS's Avatar
Drives: '20 BRZ tS (15/300) / '09 Scion tC
@LancePower - Here is the 3rd gear angle shot you requested.
2020BRZtS is offline   Reply With Quote
The Following User Says Thank You to 2020BRZtS For This Useful Post:
LancePower (03-14-2020)
Old 03-14-2020, 05:06 AM   #23
JCC
What does your Start buttons say?
Old 03-14-2020, 05:53 AM   #24
LancePower
Drives: 2020 BRZ tS
STI
Engine
Start
Stop
LancePower is offline   Reply With Quote
Old 03-14-2020, 11:55 AM   #25
JCC
nice
Old 04-06-2020, 01:53 PM   #26
JCC
Found this thread which makes it seem like it would work on all BRZ models.
https://www.ft86club.com/forums/showthread.php?t=132813
FS: STI JDM short throw shifter steel86gt Southern California 7 12-11-2018 11:52 PM
FS: Stock Short-Throw Shifter, Springs, and Rear Shifter Bushing bergy Transmission and Driveline 8 10-20-2016 10:57 PM
Six speed manual transmission 17k miles, kart boy short shifter AZ Cross Transmission and Driveline 9 12-12-2014 08:37 PM
wtb short throw shifter SciOnDrifTtSlIdeR Canada Classifieds 7 02-11-2014 09:24 PM
TWM Short Throw Shifter UltraFRS Engine, Exhaust, Transmission 12 01-28-2014 02:56 PM
