Old 02-20-2020, 10:26 AM   #15
wparsons
wparsons's Avatar
Originally Posted by Fred E View Post
What noise do camber plates eventually make during those low speed turns? I'm getting some popping-type noises now while turning the wheel when stationary (mostly when turning the wheel while transitioning between reverse and forward in a parking lot) and was wondering if it was coming from the camber plates or something else. Currently on Tarmac 2s.
The popping noise is usually the spring winding up and releasing as the strut is turned. If the upper mount bearing is working you shouldn't have this, but if you don't have a bearing in the upper mount it's expected. Could be as simple as cleaning/greasing the upper mount bearing.
You can buy thin needle bearings to put on above or below the spring to stop it as well.
flickr
Fred E (02-20-2020)
Old 02-20-2020, 02:35 PM   #16
Leonardo
Country Boy 4 Life
Leonardo's Avatar
So, After looking at everything, I am wondering if anyone has info on the difference between B6 + RCE Vs. B14 The cost is almost exactly the same.
Just curious I guess, because they are comparable in price and spring diameter.
After the comments here, I will be going with the Pedders top hats.
Thanks again for all the responses.
I LIKE TIRES!
Old 02-20-2020, 04:54 PM   #17
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
Staggered spring rates on the B14's instead of square on the RCE's, B14 spring rate is close to the yellow up front but stiffer in the back, they're rated as progressive but are fairly close to the stiff end of the range when it matters (4.5k/mm F, 7.0k/mm R). Ride comfort is comparable to stock imho, I have no experience with the RCE's.
B14 springs taper down to 60mm at the spring perch, RCE/B6 will by 90mm ID at the lower spring perch so if increased tire clearance is your jam the B14 will be beneficial there, more camber from camber bolts available, -2.6 with 17x9+40's, can probably hit -3 with 17x8's, bolts, and enlarging the small upper hole.
http://www.ft86club.com/forums/showp...&postcount=780
ineedyourdiddly
Leonardo (02-20-2020)
Old 02-20-2020, 11:33 PM   #18
BlueWhelan
BlueWhelan's Avatar
Drives: 2013 Blue Subaru BRZ. 6 Spd manual
I can vouch for the Pedders top hats as well. Combined with PP springs/dampers and the OEM non-adjustable crash bolts, I landed at -2.1 in the front. Caster also went from 5.5 to 6 degrees, which is an added bonus. Been about 3k miles so far...no noise. I'm very happy considering its my daily.
BlueWhelan is offline   Reply With Quote
Old 03-07-2020, 12:42 PM   #19
mrg666
pessimistic skeptic
mrg666's Avatar
I had eibach Prokit springs in the past. I am not sure that I want a progressive spring again...
Can you tell why you don't like Eibach Prokit?
The Following User Says Thank You to mrg666 For This Useful Post:
Leonardo (03-07-2020)
Old 03-07-2020, 12:56 PM   #20
Leonardo
Country Boy 4 Life
Leonardo's Avatar
Wanting to try non progressive springs like RCE yellows, doesn't mean that I didn't like the ProKit springs. ProKit springs are great! I drove 65k miles with them and enjoyed them very much. I have been 5k on my coils and parts with pillow ball suspension, and I'm ready for a change.
I LIKE TIRES!
mrg666 (03-07-2020)
Old 03-07-2020, 02:33 PM   #21
mrg666
pessimistic skeptic
mrg666's Avatar
Thanks! I will be installing the Eibach Pro springs and Bilstein B6 next week. My stock system is already starting to feel mushy at 6 years and this new suspension is waiting in the garage since last summer. I bought progressive springs thinking that they could be more comfortable for street driving than linear springs. Do you think that expectation was right?
Old 03-07-2020, 05:31 PM   #22
Leonardo
Country Boy 4 Life
Leonardo's Avatar
Yes, the Eibach ProKit springs are very comfortable. You will like them.
I can't suggest enough the whiteline bumpsteer roll center kit. I noticed a big difference lowered 1". If you get it, you will like it too.
I LIKE TIRES!
mrg666 (03-07-2020)
Old 03-07-2020, 06:25 PM   #23
mrg666
pessimistic skeptic
mrg666's Avatar
It seems not so hard to install. I will do. Thanks for suggestion.
Old 04-03-2020, 07:05 PM   #24
wolffbite
Just the tip
wolffbite's Avatar
Drives: 2017 DGM BRZ
Got my pedders top hats installed last Friday.
Due to working from home for the moment, I have done very little driving... but I can confirm they are 100% noise free on slow speed turning, or dry steering. No pops, clunks, or spring bind. Hopefully it lasts!
wolffbite is offline   Reply With Quote
The Following User Says Thank You to wolffbite For This Useful Post:
Leonardo (04-03-2020)
Old 04-03-2020, 08:48 PM   #25
Leonardo
Country Boy 4 Life
Leonardo's Avatar
I haven't left my house in weeks now. I put my car in storage. The suspension project will just have to wait.
Luckily, I have been making pretty decent financial decisions for a few years. So, I'll be ok. And, once I get back to work, I will be ordering the Bilstein, Pedders, and springs.
Until then... I'll be posting on here and wandering around my house bored out of my mind.
Stay safe, Wash your hands!
I LIKE TIRES!
The Following 4 Users Say Thank You to Leonardo For This Useful Post:
Capt Spaulding (04-06-2020), new2subaru (08-26-2020), Racecomp Engineering (04-03-2020), wolffbite (04-04-2020)
Old 04-06-2020, 08:07 AM   #26
sneaky_pete
Drives: MY14 86 GTS Manual Velocity Orange
I second this. I have the TRD springs (same as Eibach Prokit) and the ride is very similar to stock = comfy. you only notice the stiffer springs when you hit larger bumps. I don't know how much difference they made in terms of cornering as I installed the TRD swaybar kit at the same time. my car sits nice and flat through corners.
sneaky_pete is offline   Reply With Quote
Old 08-26-2020, 02:40 PM   #27
wolffbite
Just the tip
wolffbite's Avatar
Just to update, I have put ~8000KMS of street driving on the pedders mounts with Eibach pro-kit and they are still 100% noise free.
Old 08-26-2020, 09:19 PM   #28
BlueWhelan
BlueWhelan's Avatar
Same here. Perfect solution for me.
Suggestions on spring rates GrabTheWheel Suspension | Chassis | Brakes -- Sponsored by 949 Racing 2 01-10-2019 02:51 PM
Suggestions on suspension upgrade over BC Lakitu Suspension | Chassis | Brakes -- Sponsored by 949 Racing 86 09-06-2018 09:42 AM
Wheel Color Change... Suggestions? srizzors25 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 12 06-25-2015 03:49 PM
DFW Spring cruise 2015 planning route! Open to suggestions! carbonBLUE Southwest 101 04-27-2015 09:47 PM
suspension suggestions please teamred Suspension | Chassis | Brakes -- Sponsored by 949 Racing 16 07-13-2013 09:00 AM
