Drives: 86 Hakone
2020 86 Stereo Info
Hi,
There seems to be an extreme lack of info on the stock stereo head unit that came with my 2020 86. The system appears to be a JBL/Harman unit.
Let me caveat this post with a few points.
I thought I'd update this original post with my experiences with Android Auto
#2 |
Professional Mechanic
Drives: 2017 86 6MT Oceanic
European models have had a JBL audio option for some time, yes? I don't think I've seen that option on north american cars, or at least in canada. The JBL site lists some C pillar speakers that I've never seen, even on loaded BRZs.
The old head unit from 2017 was made by Pioneer, and I would have expected the 2020 radio, which looks mostly similar except for the buttons, to be made by them also. |
#3 | |
Drives: 2020 Hakone Edition, 2015 FR-S
The 2020 unit has tone controls which appear to do almost nothing. If I set +5 on Bass and -5 on mid-range and treble, it still has very little effect and not much bass or musical resonance. The 2015 unit has quite a bit of equalization control and the three positions for Natural, Hear, Feel have a significant impact. So I decided to listen to my local classical music station today on the 2020. As usual, the sound was tinny. I stopped the car, opened the drivers side door and put ear next to the door speaker. Guess what? NOTHING!. No sound at all coming out of door speakers. The rear speakers and the mid/tweeter in the dash work, but the "woofers" in the door are inop. Wiring issue, head unit? The Pioneer had an amp under the rear seat. Is that an issue? I only have 350 miles on the 2020 so I will have the dealer look into this at the first service. Doug PS I am a professional musician with 60 years experience playing low brass, so I consider my "ear" pretty educated... |
| The Following User Says Thank You to etherdude For This Useful Post: | Myriad (03-13-2020) |
#4 |
Drives: 2016 Scion FR-S Release Series 2.0
Along the lines of this radio, has anyone pulled it out and taken photographs of the connectors? Is this a direct swap into the older vehicles?
#5 | |
Drives: 86 Hakone
That would explain a lot. Definitely missing bass. - I suspect the AMP. - I had cranked up the 'limited equalizer' to 5 also. Sure wish they had an 11. - Hopefully we can push for an update. BTW I have a 2020 Hakone as well. Under 300 miles for me (so far). |
#6 | |
Drives: 86 Hakone
My guess is no. If in the course of exploring why the audio quality is so poor on the 2020s I will try to get/obtain some photos. My guess to your second question is yes. Looking through Crutchfields's website for compatible head units shows the same wiring harness for the 2017 & 2020 units on the Sony XAV-AX5000 receiver. Of course Crutchfield may be wrong but I've had extremely good luck with them. |
| The Following User Says Thank You to Bobharp For This Useful Post: | reh8388 (03-12-2020) |
#7 | |
Drives: 2020 86GT
| The Following User Says Thank You to QHawk For This Useful Post: | reh8388 (03-12-2020) |
#8 | |
Drives: 86 Hakone
Did not have a lot of time. Went searching for the AMP. Found it in the trunk. See attached images. Checked the connections & did not see any obvious loose wiring. |
#9 |
Drives: 2019 Toyota 86 GT
Quick question to both Hakone owners, when you put the car in reverse, does your rear view camera show up on the head unit’s screen or the rear view mirror? Thanks!
#10 |
Drives: 2020 Toyota 86 Hakone
I found this thread searching for info after pulling my stereo, so here's pic of the back of my Hakone's stereo:
![]() The left three plugs are used, and the far right ones are antenna and USB. The remaining middle one is unused. Regarding the reverse camera, it is indeed in the mirror. |
| The Following 2 Users Say Thank You to rikka For This Useful Post: | Bobharp (03-19-2020), burgeralert (03-17-2020) |
#11 |
Drives: 86 Hakone
| The Following User Says Thank You to Bobharp For This Useful Post: | burgeralert (03-17-2020) |
#12 |
One more question, how is the Apple Car Play on the OEM unit? I assume you have to have your iPhone plugged in to the input adjacent to the pocket for it to work. Thanks again.
#13 | |
Drives: 86 Hakone
Sorry. Not an Apple user. For some unknown reason, Android auto requires both Bluetooth and USB connections. - still on the fence on Android auto at least with this head unit. + Google maps is way better on my phone. |
#14 |
Drives: 86 TRD
| Tags |
| audio, head unit double din, mp3, stereo, usb port |
| 2020 86 TRD info? | Vr4gasmtt | Scion FR-S / Toyota 86 GT86 General Forum | 18 | 08-27-2019 02:41 PM |
| Android based stereo vs. stereo w/ Android auto | redlined600 | Electronics | Audio | NAV | Infotainment | 12 | 02-24-2019 02:53 AM |
| 2013 BRZ Nav Stereo For 2016 BRZ Starlink Stereo | brzsubarusti13 | Audio/Visual, Electronics, Infotainment, NAV | 11 | 02-27-2016 06:33 AM |
| Stock FRS stereo on Toyota 86 - Wiring problem position lights turn on/off the stereo | dssence | Electronics | Audio | NAV | Infotainment | 0 | 01-27-2015 06:43 PM |
| Brz Info/Specs (helpful info for questions asked often) | Gaen | BRZ First-Gen (2012+) — General Topics | 0 | 05-24-2012 10:09 PM |
