Old 07-21-2012, 03:40 PM   #1
F3dzo
F3dzo's Avatar
Drives: 13 fr-s whiteout
Spacer how to right in your driveway.
So I bought my sparco wheels and got the factory offset because they were in stock and I wanted my wheels now. Anyhow, slapped em on and lo and behold...
So unhappy with the rear fitment results, I opted to purchase a set of spacers for the rear. Pm me if you want brand info or any other questions.
Below I will post pics and some text describing the quick and easy way to get er done.
Tools needed.
remove wheel after raising car. Pre-loosen lugs so that you don't knock the car over on the stock jack when you completely raise the car. At this point the car is raised enough to lift about 25% of the weight off the tire.
Tada!
I know the car needs to be lowered to complete the look. I'm saving up for some tein coilovers. I can't wait
I'll be back!!
F3dzo is offline   Reply With Quote
Old 07-21-2012, 04:50 PM   #2
F3dzo
F3dzo's Avatar
I'll be back!!
Old 07-21-2012, 05:52 PM   #3
CBR600RR
Drives: Raven Black
When you put the coil overs on don't park over the curb like that.
I hate it when I see people doing that in their nice cars and the front lip is meet millimeters above the curb.
The Following 2 Users Say Thank You to CBR600RR For This Useful Post:
armythug (12-23-2012), EvoXDD (08-10-2012)
Old 07-21-2012, 05:54 PM   #4
F3dzo
F3dzo's Avatar
Oh crap good looking out, I have to start getting out of that habit...
I'll be back!!
The Following User Says Thank You to F3dzo For This Useful Post:
faz1 (07-24-2012)
Old 07-21-2012, 07:18 PM   #5
#87
I usually post drunk
#87's Avatar
And plz don't use the trunk jack for working under the car
#87 is offline   Reply With Quote
The Following 2 Users Say Thank You to #87 For This Useful Post:
Fly Guy (07-22-2012), notFRS (07-22-2012)
Old 07-21-2012, 07:35 PM   #6
dori.
Señor Member
dori.'s Avatar
Drives: white BRZ 6MT
Are those safe to use regularly? I was thinking of getting spacers that change the bolt pattern so the wheels I had from my RX-7 don't go to waste
dori. is offline   Reply With Quote
Old 07-21-2012, 07:49 PM   #7
F3dzo
F3dzo's Avatar
Trust me, I was lookin for my mini floor jack...
I'll be back!!
Old 07-21-2012, 07:54 PM   #8
F3dzo
F3dzo's Avatar
I drove 50 miles right after to go to work and it felt the same. They look well made, solid aluminum. Hub centric.
Once I lower the car on coilovers by then I'll be looking into another set of wheels. I get bored pretty quick... :/
I'll be back!!
Old 07-21-2012, 08:16 PM   #9
Silverdub
Boostin'
Silverdub's Avatar
Drives: FRS-T
I was looking into the 25mm adapters from eibach to put in the rear. How many millimeters are yours? I need them bad and im lowered on teins i just dont want the wheels to rub
Silverdub is offline   Reply With Quote
Old 07-21-2012, 08:28 PM   #10
dsgerbc
Drives: BRZ(sold), STI
No. Unless you count wheel bearings as a wear item (and enjoy understeer).
The Following User Says Thank You to dsgerbc For This Useful Post:
danthedirt (07-24-2012)
Old 07-21-2012, 08:30 PM   #11
F3dzo
F3dzo's Avatar
Depending on what offset your current wheels are then you should choose the width of the spacers. My sparco's have a et48 offset and I went with 25mm. I particularly like a little bulge. I'm going to lower the car enough that the wheels don't rub.
I'll be back!!
Old 07-21-2012, 09:26 PM   #12
Khyron686
Drives: 2011 Outlander XLS, 2013 FR-S Blue
Or if you understand shear forces on bolts. Keep them torqued correctly, not just by hand... I don't see a torque wrench in your list of tools....
25mm is insane. 10mm maybe, but better to get the right ET.
OP what was the sparco size? 18x8 ET48?
Khyron686 is offline   Reply With Quote
Old 07-21-2012, 09:36 PM   #13
Silverdub
Boostin'
Silverdub's Avatar
Drives: FRS-T
Im on stock wheels till april next year so im guessing 25mm should do it 4 now thanks!
Old 07-22-2012, 01:03 AM   #14
F3dzo
F3dzo's Avatar
Yea I meant to torque them! I'll do it this weekend. 17x7.5 et48
I'll be back!!
Shot these on my driveway last night Hanzo BRZ Photos, Videos, Wallpapers, Gallery Forum 108 04-02-2013 09:09 AM
wheel spacer to 5x114 derka-derka AUSTRALIA 12 07-02-2012 11:27 PM
mines13's living in the 90's boosted street DA build. My soon to be FRS driveway pal mines13 Other Vehicles & General Automotive Discussions 16 03-30-2012 03:30 PM
