Old 03-05-2020, 06:42 AM   #15
steve99
Drives: FT86
Originally Posted by 1quickchic View Post
none of this sounds good, and the fact it throws 2 codes after a new ecu that should just be a stock calibration on it is bothersome, is it possible the body control module is having an issue?
also a note about the original ecu which don't know if this would be helpful or not but.
it was attempted to flash a calibration using tactrix, it flashed but then was basically dead, and when we tried to go back it wouldn't even connect. so I am worried if maybe the tactrix messed up something else in the car
Ecu dead as in car wont start or ecu doesnt respond to tactrix read or write requests any more.
If it wont respond to tactrix read or write requests
Did you say yes to correct checksums if ecuflash asked before flashing ?. If you said No the ecuflash flasges rom to ecu with incorrect checksum. When ecu starts it then sees incorrect checsum and shuts down as it detects incorrect checksum.
Or did you flash a rom you edited with a possibly incorrect definition.
If its first one you can usually recover ecu by doing the following
Remove vattery power from car for at least 30 minutes
Have laptop ready to go to reflash a known good rom to ecu, stock rom is best
Replace battery terminal
Turn ignition full on, wait 15 secs then flash ecu with the stock rom
Do this on first turn on of ignition dont try to start.
If its second option ie you flashed edited rom thats likey corrupt. Try above proceedure but it usually fails as ecu is off in some weird loop due corrupted rom image.
You mght recover it with brzedit or ECUTEK systems. But you wont with tactix as its not good at recovering that type of problem.
You best bet is buying another ecu
Old 03-05-2020, 07:42 AM   #16
Kodename47
Kodename47's Avatar
Drives: UK GT86
He did, this is the one with the error codes. Could that be that the ECU hasn't been paired properly?
.: Stealth 86 :.
Kodename 47 DJ:
Old 03-05-2020, 10:03 PM   #17
steve99
Drives: FT86
The pairing and flasging tune is independant. You can flash an ecu in a car without pairing it.
All that happens if its not paired is car wont start
No having it pared wont cause the type of codes being seen here.
You will get a code related to communications\security but not fuel pump or other hardware codes.
A couple of weird issues - fixed? StraightOuttaCanadaEh Suspension | Chassis | Brakes -- Sponsored by 949 Racing 14 05-30-2019 09:25 AM
Weird Bluetooth music issues kravi Electronics | Audio | NAV | Infotainment 3 01-18-2016 12:34 PM
New RPM Calibration TSB... 5AD86D Issues | Warranty | Recalls / TSB 23 01-21-2015 11:50 PM
Weird electrical issues. Need help! Pneub Issues | Warranty | Recalls / TSB 15 09-13-2014 01:38 AM
Weird Blinker Issues sufu05 Cosmetic Modification (Interior/Exterior/Lighting) 0 08-06-2013 11:47 AM
