go_a_way1, MisterSheep
Old 02-19-2020, 12:05 AM   #21561
jflogerzi
jflogerzi's Avatar
Finalized my tune with some Dyno pulls. Here is a link to a video of a run. In dynojet numbers put me right at 300whp and 250 wtq. Lower lines are a baseline stock brz.
2013 Series 10 FRS #553
The Following 3 Users Say Thank You to jflogerzi For This Useful Post:
JesseG (02-24-2020), Kestrel (02-29-2020), MJones_RB (02-19-2020)
Old 02-20-2020, 04:32 PM   #21562
mazeroni
Drives: 2013 Scion FR-S Series 10
I did what you're not supposed to do: Go to a dealership out of warranty.
I developed that issue where on take off and deceleration in 1st and 2nd there is a metal pinging noise. I told them to drive the car to hear it (easily reproduced) and then re-torque all of the bolts in the rear because that is what everyone on here has recommended. I wanted to eliminate that as an issue before we talk about a bad axle or CV joints or anything.
$140 later, nothing. I was at the dealer for 2.5 hours. They don't hear the sound but they claim to have re-torqued the bolts. As I pull away from the dealer, I hear the noise repeatedly. Great! Maybe it is the e-brake issue that at least one person had? Whatever it is, it is super annoying.
The best part is they told me my front brake pads are "2" and "Red" and I need new ones and I need to replace the front rotors as well...
Except that last May when I got the PS ECU replaced, they did a full inspection and marked all pads as "8" and "Green." Firestone never found an issue with pads or rotors and I've been to them a few times recently. How, in one year, did my pads lose 80% of their life? I should have said something. I only put like 5K miles in the past year. The rear pads are at 8, by the way.
Also, they brought up the "carbon deposit" on the intake manifold that they can clean for just $150!!! I found a thread on here that shows you can wipe that up with a paper towel.
Two years ago when I was at the dealer, they told me there was rust in my brake fluid and they wanted to charge $125 to flush the system. I went to Firestone and they did it for $60, and the tech said my fluid was fine. The tech used to work at Toyota and said he left because of how shitty they are.
I feel stupid for not going to an independent shop or Firestone or anywhere else, and for letting these dingbats look at my car. I honestly have zero idea if they even did anything. I'm eager to go home and check my dashcam to see if they just parked it and forgot I was there, and just drove it back into the parking bay, claiming to have done something. /rant over.
mazeroni is offline   Reply With Quote
The Following User Says Thank You to mazeroni For This Useful Post:
Impureclient (02-20-2020)
Old 02-20-2020, 05:21 PM   #21563
Impureclient
Drives: 2015 FR-S
They don't call them stealerships for nothing. Make sure you give them an appropriate Google review, businesses should be punished for bad service and nothing does it better than a bad Google review.
Old 02-20-2020, 10:15 PM   #21564
Contender
Drives: 2017 Toyota 86
Changed my transmission and rear differential oil with Motul Gear 300 also put in Mtech springs and Whiteline shift kit.
Contender is offline   Reply With Quote
The Following User Says Thank You to Contender For This Useful Post:
trvth (02-26-2020)
Old 02-20-2020, 10:17 PM   #21565
Kestrel
Kestrel's Avatar
Drives: 2015 Ultramarine FR-S AT
Continuing my quest for GT3FRS lol
Kestrel is offline   Reply With Quote
The Following 5 Users Say Thank You to Kestrel For This Useful Post:
BigHugeFatGuy (02-28-2020), JesseG (02-24-2020), jflogerzi (02-21-2020), Kiske (02-29-2020), MJones_RB (02-21-2020)
Old 02-27-2020, 05:55 PM   #21566
Ashikabi
Ashikabi's Avatar
Refilled the coolant today. Got this coolant refill vacuum kit on eBay for like$30. Uses compressed air to suck the air out of the system then the vacuum pulls coolant in till full. Should completely eliminate air pockets. Also shows if you have a leak in the system
Sent from my ONEPLUS A5010 using Tapatalk
The Following 2 Users Say Thank You to Ashikabi For This Useful Post:
chaoskaze (03-01-2020), weederr33 (03-01-2020)
Old 02-28-2020, 03:53 PM   #21567
RToyo86
RToyo86's Avatar
Drives: 17 Asphalt 86
Finally slapped on a TRD sticker I had laying around for the useless center button on the TSC panel. Along with a quick wipe down.
Then cleaned off my winter mats as they were filthy. Did a one over with powerclean then hit it with some opti-seal afterwards.
..I actually peeled off a layer of salt from the driver side mat. I did not know that was possible lol.
Edit I also stuck on the FT86Club sticker. I need to go over it to seal the adhesive around the lettering.
Old 02-29-2020, 01:02 PM   #21568
StraightOuttaCanadaEh
Wes
Cleaned and re-oiled my K&N filter. The amount of dirt and leaves that came out was moderately alarming. No wonder the car’s been feeling wheezy lately (could be weather too of course, but that was A LOT of junk)
Instagram: @gt86ws
The Following User Says Thank You to StraightOuttaCanadaEh For This Useful Post:
humfrz (02-29-2020)
Old 02-29-2020, 02:02 PM   #21569
That reminds me, I ought to take a look at mine - after my nap -
StraightOuttaCanadaEh (02-29-2020)
Old 02-29-2020, 07:34 PM   #21570
Ashikabi
Ashikabi's Avatar
Wrapped my interior silver pieces with Avery Dennison brushed aluminum vinyl. It's not a drastic interior change but I think the brushed look is much classier than painted silver
Forgot, I wrapped my radio bezel and passenger dash panel with Avery carbon fiber vinyl too
Old 02-29-2020, 08:28 PM   #21571
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
Started tearing the old bitch down... Time to build the block; why not, right? Of course since I wanted to do this on my day off, it had to be 10 degrees out. Hopefully by summer I'll have all the money saved up for it
mrg666 (03-01-2020)
Old 03-01-2020, 10:39 AM   #21572
Got a pic? I've thought about doing this myself (carbon fiber vinyl). I want to use a red/black wrap carbon fiber wrap but haven't been able to find one I'm happy with. I want it mostly black with a red accent thread. Can find it in actual cloth but haven' been able to find it in Vinyl.
Old 03-01-2020, 04:01 PM   #21573
mrg666
pessimistic skeptic
mrg666's Avatar
Rebuilding the engine is the hardest thing you can do on this car. Will you do machining to upgrade oil pump as well? Good luck to you.
Old 03-01-2020, 04:29 PM   #21574
DarkPira7e
DarkPira7e's Avatar
I might do the reimax gear just for peace of mind, nothing else though. I'm not planning on making much if any more power, I just want to lower the amount of things that may fail.
I'm sure rebuilding the block is easier than getting the timing cover off. It's 12 degrees F here and even with a propane torch, I can't get the fujibond to let go. I've given up for today after spending 2 hours trying to pry it off and breaking one of the ears
